Hi all!
So as you see in the title, I'll be doing a rev.1 of my watercooling system. I chose the LL PC-P80 because of its gorgeous size and design.
I'll obviously be modding this case, as it has a lot of possibilities.![]()
I have access to a laser cutter and engraver, so I would like to do a nice design for the side panel, but no ideas as for now!![]()
Computer hardware:
> ASUS P6T6 WS Revolution
> i7 920 @ 4GHz
> Corsair 12Gb 1600MHz CL8
> EVGA (obviously!) GTX 285 (later an SLI)
> Be Quiet DPP 1200W
> 3 HDD
Watercooling equipment:
> 2x Swiftech MCP-350 w/ Ek topv v2
> 2x TC PA120.3
> EK Supreme plexi CPU block
> EK FC-GTX285 plexi GPU blocks
> TFC red, purple, black and green cooling fluid(still don't know which one I'ma gonna use
> TFC 10/13 Clear non-UV and white hose
> Koolance 10/13 fittings
> Some Tacens Ventus 120
||| UPDATE 1 |||
my favorite
sorry for the dust
and some sleeving
||| UPDATE 2 |||
polishing of the clamp for the CPU block
||| UPDATE 3 |||
Finally got the case!!!
some pics.... (as always)
||| UPDATE 4 |||
dead Dremel....![]()
||| UPDATE 5 |||
rez mounting test (thanks SNiiPE for the idea!)
||| UPDATE 6 |||
aaahhhh!!!!
Don't know how it happened, but the TC isn't straight!I measured like 10 times, and it was all OK, but only after the cut (of course, the action had to be done), I realized the error. Anyway, you don't see it from the side
||| UPDATE 7 |||
||| UPDATE 8 |||
Again a big update
Lightroom
P6T6
Finally Xonar D2X!!!!![]()
||| UPDATE 9 |||
||| UPDATE 10 |||
Only 2 pixes of ma new 45° swiveling Koolance fittings for the moment
||| UPDATE 11 |||
Some pictures of my order from Performance-PCs
Special pix for mib
Thanks for reading!
