Page 1 of 3 123 LastLast
Results 1 to 25 of 72
Thread: Watercool Heatkiller GPU-X2 (Waterblock for GTX 285) launched
    May 2007
    Germany
    Hi guys.
    Just received my new Heatkiller GPU-X2 GTX 285 from www.watercool.de !
    That is really a nice one.
    The load temp was 45-47°C on GPU while water was at 29-30°C. My clocks reached 792/1420/1650 with a Palit GTX 285
    Empty your mind. Be formless, shapeless. Like water. You put water into a bottle and it becomes the bottle. You put in a teapot, it becomes the teapot. Water can flow, or it can crash.
    ...be water my friend
    Worklog - Lian Li PC 343b built with 2 Triple-Rad-Loops
    Mar 2008
    Jakarta, Indonesia
    i'd be damned
    that is one hell of facinating FC block i've ever seen...
    bit confuse how the top is mount...is it only the middle top
    May 2007
    Germany
    Water flows throuh the middle part with the "X" on it, that is right. This is mounted to the Plate, which covers the Mosfets etc. In the plate there is milled a structure, where the water is pressed through. That gives a real good cooling performance
    I will take a look for pics from inside. Mine is installed yet
    Mar 2008
    Oslo, Norway
    I really like the looks of the HK blocks. Looks very industrial and serious if you ask me.
    I Are DuneCat
    I Controls The Spice
    I Controls The Universe
    Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
    D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
    Apr 2007
    Gothenburg, SWEDEN
    Looks good. Seems to be a two-slot solution. As far as I can understand German there seems to be a sli-solution. This SLI-solution is mighty cool!
    Feb 2008
    Australia, Perth
    HOLY AWESOME BATMAN!
    They look SICK!!!!
    May 2007
    Germany
    Yes and it ist pretty more stable, when installed with these SLI-Links. Your Board will be thankful
    Apr 2007
    Gothenburg, SWEDEN
    Quote Originally Posted by peebee View Post
    There isn't a day when I ask myself, "Is my board thankful today?"
    May 2007
    Germany
    The inner pics of these coolers can be found here: PC-Masters.de
    Mar 2008
    Dallas, TX
    wow the internals of this waterblock are really interesting, they look pretty restrictive i think though?.. combining a FC style block with a CPU style fin layout under it.. i like it a lot
    "fightoffyourdemons"
    Engineering The Xtreme
    Feb 2007
    MA, USA
    PARALLEL
    lest history repeat itself once more, don't let NaeKuh see this thread!!!
    Mar 2008
    Oslo, Norway
    So parallel is not recommended? I was thinking of buying HK's 4870 CF solution.
    I Are DuneCat
    Feb 2007
    MA, USA
    the way parallel works the block farther from the barbs gets less flow by a factor of the length between the blocks, its all in Bernoulli's equation
    someone had a nice diagram of it before but I cant seem to find it now....
    Jan 2009
    +1 for the series and make it for 2 x 295's
    [3960X 4.8GHz 1.35v] [32GB G.Skill Ripjaws 2133] [EVGA GTX 680 SLI] [ASUS RIVE] [Samsung Spinpoint F1 1TB R0]
    [EK Supreme HF] [EK RIVE Full Board Kit] [Coolgate 120.3 + 120.1] [4 x Scythe GT D1225C12B5AP-15] [BitsPower Compression] [MCP655]
    [3 x Acer S231HL LED 5760 x 1080 2d Surround]
    Mar 2008
    Oslo, Norway
    I was looking at the internals of the HK. Gorram! It looks extremly restrictive! The fins seems to be perpendicular to water flow.
    I Are DuneCat
    Jan 2009
    Can someone post the internals? I cant navigate in german.
    Mar 2008
    Oslo, Norway
    Note that this is for the R670 GPU. They might have done changes. It's hard to know since they seem to not post the internals on their site.
    I Are DuneCat
  18. #18
    May 2007
    Germany
    Okay this might be a little bit restrictive, but for the GPU it works very well. In a test this block for the GTX 280 beats the EK-Block by 4,1°C better cooling. The flow with the EK-block was 292,2 litres per hour and the flow with the Watercool block was 253,2 litres per hour.
    (1 Litre = 0,264172052 Gallons)
  19. #19
    Mar 2008
    Oslo, Norway
    Could you post internals of your block?
    I Are DuneCat
  20. #20
    Dec 2008
    But for a single card solution, it's gorgeous.........and look at the prices! For the 4870, 35 Euros, or $45 U.S.
    The GTX 285 block is 40 Euros, or $52 U.S.
  21. #21
    Jul 2006
    I'm fairly positive that you can run Watercool GPU coolers in series:
    http://www.aquatuning.de/product_inf...y-Adapter.html
    You'd have to buy one for each GPU block you buy.
  22. #22
    May 2007
    Germany
    Quote Originally Posted by Zehnsucht View Post
    I am sorry, but I am already running my card in my system now and I want to leave it in there. I reached 792/1620/1485 stable now.
    I will arrange some pics for you. I contacted the support already.
    Quote Originally Posted by Humminn55 View Post
    I think you must be looking at the upgrade Kits right?
    Usually you buy one GPU-X2.The first GPU-X2 costs around 89,90€ and if your card changes, you can just buy the different Bottom plate in an upgrade kit. That is around 35-40€.
    Quote Originally Posted by alejo View Post
    But if using SLI, why buying these single 4-way Adapters? Ah let me guess... to separate them in different loops? Or to feed the blocks with water like you want it and not not like the links do?
  23. #23
    Jul 2006
    Yes, I think most people here prefer to run their cards in series and not parallel. I don't really care myself as I only run one card at time.
  24. #24
    Mar 2008
    Oslo, Norway
    Looking forward to it!
    I Are DuneCat
  25. #25
    Xtreme Batrachian
    Jan 2007
    Eastbourne, UK
    I had a look @ their solution for the 4870x2 and, to my taste, that's one sexy block...
    And the price is in the same bracket as the Razor...
    However, it doesn't have stand-offs, inlet-outlet are rather close (might cause problems with certain fittings, which IMHO has no excuse given that these cards are as long as it gets) and once I close the case I don't see a sausage (no windows, yes acoustic foam FTW! :P ) so is yet another no-no for me... Function > Form...
    Quote Originally Posted by fart_plume View Post
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
Tags for this Thread
