Results 1 to 25 of 46
Thread: **Official BIOSTAR TPower X58 Review/Overclock/Guide Thread**
Threaded View
    Sep 2006
    Grimsby, UK
    Post **Official BIOSTAR TPower X58 Review/Overclock/Guide Thread**
    Official Biostar Forums
    Novatech Forum - Official Biostar TPower X58 Review/Overclock/Guide Thread**
    The Rebels Haven Forum! (Unofficial Biostar Forums)- Biostar 64 Bit Intel S1366 Motherboard
    Reviews
    Biostar Tpower X58: the alternative! @ matbe.com
    Compatable Air Cooling List (NOTE: Doesnt take into consideration case sizes)
    Thermalright Ultra-120 eXtreme-1366 RT
    Thermalright Ultra-120 eXtreme + LGA1366 Bolt-Thru-Kit
    Noctua NH-U12P SE1366
    Zalman CNPS9700 LED Aero Flower + ZM-CS4A LGA1366 Clip Kit
    Compatable Ram List - Bootable with default voltage to bios
    'CLICK HERE' - BIOSTAR'S Official Compatable Ram List
    OCZ 6GB Platinum DDR3 PC3-1600 (3x2GB) CAS7
    OCZ 3GB Platinum DDR3 PC3-1600 (3x1GB) CAS7
    Corsair 6GB Dominator DDR3 PC3-1600 (3x2GB) CAS8
    Corsair 3GB Dominator DDR3 PC3-1600 (3x1GB) CAS8
    Official BIOS
    WARNING:- DO NOT USE THE WINDOWS FLASHMENU METHOD TO UPDATE YOUR BIOS, HIGH RISK OF BIOS FAILIURE!
    How to update the BIOS via USB Flash Stick/Drive
    What should I do If the system BIOS was corrupted after the flashing process ?
    CPU support list
    AFUDOS 4.23
    Bios Flashing Procedure
    BIOS ID: IX58A304
    1. i7 core "D0" CPU Revision compatability.
    2. Supports XMP memory and improved some memory compatibility with more memory.
    3. Release Date: 4th March 2009
    BIOS ID: IX58A210
    1. Fix Hardware Detection to resolve FAN5 issue.
    2. Release Date: 10th February 2009
    BIOS ID: IX58AC25
    1. Added bootflash screen prompts.
    2. Release Date: 25th December 2008
    BIOS ID: IX58C10
    1. Adjustment 3pin/4pin CPU smart fan options.
    2. Release Date: 10th December 2008
    BIOS ID: IX58AC01
    1. Initial release.
    2. Release Date: 1st December 2008
    Beta BIOS
    DISCLAIMER:
    Biostar will not be held responsible or liable for any damage made with using a BETA BIOS.
    Please proceed with discretion and do not attempt to use unless you know what you are doing!
    BIOS ID: IX58A604 *NEW*
    1. Fix XMP1 & XMP2 EX clock function.
    2. Release Date: 11th June 2009
    Instruction Manual
    English Version (1st Edition) Dec 2008 - 3rd February 2009 *NEW*
    DRIVERS - Last checked 4th August 2009.
    INTEL Chipset Driver v 9.1.0.1007 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 8th December 08
    RAID/AHCI Software - Intel® Matrix Storage Manager v 8.9.0.1023 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 17th July 09 *NEW*
    32-bit Floppy Configuration Utility for Intel® Matrix Storage Manager - 17th July 09 *NEW*
    Creates floppy disk for 32-bit OS with Intel® Matrix Storage Manager 8.9.0.1023 files - used to preinstall RAID driver (F6 during Windows* setup).
    64-bit Floppy Configuration Utility for Intel® Matrix Storage Manager - 17th July 09 *NEW*
    Creates floppy disk for 64-bit OS with Intel® Matrix Storage Manager 8.9.0.1023 files - used to preinstall RAID driver (F6 during Windows* setup).
    JMicron SATA Driver V 1.17.49 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 24th July 09 *NEW*
    Realtek 8111C Gigabit Lan V5.718 Driver for Win9x/Me/2000/XP/2003 - 21st July 09 *NEW*
    Realtek 8111C Gigabit Lan V6.225 Driver for Vista 32bit / Vista 64bit - 21st July 09 *NEW*
    Realtek High Audio Definition R229 Driver for 2000 / XP / XP 64bit / 2003 / 2003 64bit - 23rd July 09 *NEW*
    Realtek High Audio Definition R229 Driver for Vista 32bit / Vista 64bit - 23rd July 09 *NEW*
    Utilities
    Biostar TPower II v0.9.5.6 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 9th April 09
    BIOScreen v0.9.0.1 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 25th February 09
    G.P.U( Green Power Utility) v0.9.0.5 for 2000 / XP / XP 64bit / 2003 / 2003 64bit / Vista 32bit / Vista 64bit - 25th February 09
    i5 2500K @ 4.9GHz MSI Z77 MPower G.Skill Trident 8GB 2400C10
    EVGA GTX 1070 SC 8GB @ 1784/4004MHz Corsair HX 750 PSU
    Samsung 830 256GB Creative ZxR Thermalright Silver Arrow
    NEC 24WMGX3 24" TFT Fractal Design Define S Win 7/10 64bit
