Results 1 to 3 of 3
Thread: My Stacker
    Aug 2008
    My Stacker
    Nothing fancy, just about $25 in paint and a couple rivets. just a little sneak peek for now, weather went from 85 and sunny yesterday to snow as i type this lol. ill post new finished pics once i get the front mesh, side panels, and top finished.
    for the record i used Valspar primer, Valspar Flat Black, Valspar Berry Gloss, and Valspar Flat clear. the flat clear over the gloss gave it a nice satin finish
    the reason for this is because my blue on black scheme just wasnt working, so instead of just painting the mesh i wanted to do something a little more for my classified build. enjoy.
    CM Stacker 830 Classified Scheme *In Progress*
    Antec TPQ-1000
    i7 950
    OCZ Reaper 3x2gb 1066 7-8-8
    Crucial C300 128gb
    HD5850
    Asus Xonar Essence STX
    Aug 2008
    *reserved*
    and by the way... i had never read this anywhere so i wasnt sure if many people knew it but you can actually change the way the back panel is setup on these by taking it apart, you can have a upside down mobo config and keep the mobo on the same side... if that makes sense. food for thought i guess.
    Antec TPQ-1000
    i7 950
    Crucial C300 128gb
    HD5850
    Aug 2007
    Stackers are great. Good luck with your project.
