XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 12-09-2008, 04:44 PM   #1
Ziwro
Ziwro's Avatar
Send a message via MSN to Ziwro
Asus P6T Deluxe Discussion Thread
http://www.asus.com/products.aspx?l1...93&modelmenu=1
New Era for Extreme Overclocking! The Best Intel® Core™ i7 Platform
* Intel LGA1366 Platform
* Intel®X58 chipset
* Triple-channel DDR3 1600(OC)/1333/1066 MHz
* True16+2 phase Power Design
* ASUS TurboV
* ASUS EPU
* ASUS Express Gate SSD
* SAS Onboard
* SLI and CrosFireX on Demand
* 100% High-quality Japan-made Conductive Polymer Capacitors! (5000hrs VRM, over 5 years operation lifespan)
Overclocking Intel's Core i7 920 With Asus P6T Deluxe and the MSI X58 Eclipse ;
http://www.bit-tech.net/hardware/200...-core-i7-920/1
Bios ;
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1366/P6T_Deluxe/
__________________
Intel i7 920 @ TR Ultra 120 Extreme (Waiting) || | MSI Eclipse SLI @Bios 1.4B4 || 3*2 GB OCZ Platinum @ 1333MHz || CoolerMaster CosMoS " S " || ATI Sapphire 4870 || Enermax Infiniti 720W || Samsung 7200.11 "AS" Serisi , 640GB + 750GB + 1 TB || Samsung 22'' 226BW || Creative X-Fi Extreme Music @ Logitech Z-2300 ||
|| Logitech G15 V2 @ Logitech MX Revolution @ Logitech Cordless RumplePad 2 || || Sony PSP Slim&Lite {5.00} @ Sony 8GB Ms Pro Duo || Apple Ipod Touch 8GB @ SENNHEISER CX-500 ||
Ziwro is offline   Reply With Quote
Old 12-09-2008, 05:04 PM   #2
003
Xtreme Mentor
003's Avatar
Can anybody confirm if the Thermalright HR-09 MOSFET heatsinks fit on the P6T Deluxe? DangerDen is making a new top for my P6T Deluxe for my MPC-X38 so I can use it on the NB, and I will have an Enzotech C1B-S1L on the SB. But unfortunately, the stock MOSFET coolers are part of the stock NB and SB cooler, so if you take those off, the MOSFET cooling goes as well. This is unlike the Rampage Formula, where the MOSFET heatsinks are not attached to the NB and SB.
__________________
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
003 is offline   Reply With Quote
Old 12-09-2008, 05:26 PM   #3
eternal_fantasy
eternal_fantasy's Avatar
They might not fit, as the 2 MOSFET heatsink slots are not the same size.
EK made a set of waterblock for the P6T, and they have different lengths;
__________________
ASUS Rampage II Gene MicroATX Socket 1366
Intel Core i7 965 EE QuadCore
Watercool HK CPU LGA1366 Rev. 3 Nickel Plated
EK GTX-480 Full Cover Nickel + Acetal
Killer M1 NIC
Check out the For Sale section for great deals on the above hardware!!! [UK Shipping Only]
Originally Posted by creidiki View Post
We are a band of fearless modern-day alchemists who, for fun, run solutions through sophisticated, if overpriced, separator setups, and then complain when we succeed in separating said solution.
eternal_fantasy is offline   Reply With Quote
Old 12-09-2008, 09:40 PM   #4
003
Xtreme Mentor
003's Avatar
Hey, is anybody able to accurately measure the distance between the mounting holes for each set of MOSFETs?
__________________
Old 12-10-2008, 04:20 AM   #5
eternal_fantasy
ASUS P6T Deluxe BIOS 1003
__________________
Killer M1 NIC
Old 12-10-2008, 04:59 AM   #6
sxs112
sxs112's Avatar
Send a message via MSN to sxs112 Send a message via Yahoo to sxs112
ASUS P6T Deluxe 1003 Beta Bios
[ 1003 ]
ASUS P6T 0112 Beta Bios
[ 0112 ]
sxs112 is offline   Reply With Quote
Old 12-10-2008, 05:35 AM   #7
BlaZ1n.420
Anyone making NB SB waterblocks for this yet?
BlaZ1n.420 is offline   Reply With Quote
Old 12-11-2008, 12:46 PM   #8
roller11
I would like to know whether or not anyone has tested the P6T to see if it does Vista sleep mode properly, and the results of those tests. With the giga x58 mobo, sleep mode works if and only if hyperthreading is enabled. If HT is disabled, system goes into sleep mode, but hangs with blank screen upon resume. Make sure that 'suspend type' is set to S3 in BIOS and test sleep mode with HT both enabled and disabled.
roller11 is offline   Reply With Quote
Old 12-11-2008, 12:57 PM   #9
killermiller
killermiller's Avatar
Send a message via MSN to killermiller
I have never had a mobo that woke from sleep properly when overclocked.
I'd like to forewarn everyone about a boot up/POST issue with the P6T Deluxe.
Here is my thread that no one has posted in
killermiller is offline   Reply With Quote
Old 12-11-2008, 01:44 PM   #10
Etherwolf
Etherwolf's Avatar
Do you work for GCI? I'd sure like to get access like that!
Etherwolf is offline   Reply With Quote
Old 12-11-2008, 02:03 PM   #11
Extigy
as it is only the northbridge that seems to get really hot, i was thinking of just removing that black heatspreader and putting a water block on that (obviously remove the whole heatsink assembly, clean and reapply some good thermal paste). Trouble is, i am not sure how effective it would be given there is about 5mm of copper between the water block and the NB chip. Any ideas ?
Extigy is offline   Reply With Quote
Old 12-12-2008, 02:18 PM   #12
roller11
Since vista came out in Jan.2007, I've tested SM in eleven different mobos and they have all done SM properly OCed or not. And the giga does SM properly if and only if HT is enabled. I have no reason to believe that the
P6T is flawed and will not do SM if hyperthreading is disabled, but I would like to know for sure before I swap my giga for the P6T.
Old 12-13-2008, 09:30 AM   #13
FZ1
FZ1's Avatar
What kind of RAM are ppl running on this board? Corsair seems to be good but I hear others are having issues with other brands. Of course, Asus has no official RAM compatibility list (unless I missed it).
__________________
RAM in my sig for sale!
i7 920 @ 3.8GHz 1.29v
Asus P6T Deluxe BIOS 1003
Corsair Dominator PC3-12800 3 x 1GB
Noctua NH-U12P
Coolermaster ATCS 840
Corsair 620HX
XFX 9800GX2 Black Edition
300GB Velociraptor HDD
SB X-Fi Titanium Fatal1ty Pro
FZ1 is offline   Reply With Quote
Old 12-13-2008, 04:20 PM   #14
killermiller
The Qualified Vendor List(compatible memory list) is in the manual. I personally have never bought memory on a QVL and never had an issue. This is the fisrt board I have ever bought where is may be an issue.
Old 12-14-2008, 04:46 PM   #15
FZ1
FZ1's Avatar
I checked the manual online...nothing. They have a link to the QVL but when you click it, it brings up a list of all downloads associated with the board and the QVL is not among them. They had one for the WS version...I guess they are the same but who knows. On their forum people were complaining that the QVL is taken from an older board and is not accurate.
__________________
Noctua NH-U12P
Corsair 620HX
Old 12-14-2008, 05:15 PM   #16
Guacamole
Guacamole's Avatar
I have run both Patriot 1600 cas9 as well as Corsair Dominator 1600 cas 8 haven't had any problems whatsoever actually the Corsair is just sick memory and they can run almost anything you throw at it.. Also I don't niotice the NB getting hot at all but it is winter so my room is always cold..
Has anyone actually tried the new bios 112 or whatever and can anyone here get 4.0Ghz stable on their 920 I can run 3.985 for days but I BSOD or freeze at 211Bclk I really want to get 4.0 but I'm stuck at 210 on bios 804???
__________________
Gaming Rig:
QX9650 / Striker Formula/ Evga 280GTX SLI / 4GB 2X2GB OCZ 1066 / 2X RaptorXRaid0/ MM Duality / EK / Fuzion / Thermochill /
Processing Rig:
i7 920 / Asus P6T-Deluxe / Antec 850W PSU / GTX260(216) SLI / 6GB Corsair 1600Cas8 / Stacker 830
Guacamole is offline   Reply With Quote
Old 12-14-2008, 05:20 PM   #17
Aivas47a
Aivas47a's Avatar
3gb of OCZ Platinum 1333 C7 worked great for me.
__________________
W3520 @ 4.4 ghz | DFI UT X58 | Swiftech GTZ | 6G Kingston 2000 | 4870 | PCP&C Silencer 750w | Win 7 RC
Aivas47a is offline   Reply With Quote
Old 12-14-2008, 06:18 PM   #18
DarthBeavis
Infected with the Ewe Flu
DarthBeavis's Avatar
Testing on air
Should have NB/SB/Mofset blocks and CPU block by Tuesday
__________________
Special-needs modder
DarthBeavis is offline   Reply With Quote
Old 12-14-2008, 10:09 PM   #19
SmokeyTheBandit
SmokeyTheBandit's Avatar
I can run 212 BCLK om mine, wich is prime stable.
19x 212 = 4025Mhz @ 1.29Vcore Prime stable
LLC Enabled
Vdimm @ 1.68V
Rest @ Auto
__________________
Cpu: Core i7 930 @ 4.5 Ghz 1.4V (24/7)
Mainboard: Classified E760 @ B3 X58 + EK Waterblock
Memory: 6GB Kingston Hyper @ 2150Mhz 8-8-8-28 -> 1.72V
Graphics Card: HD5870 + EK-Waterblock
Soundcard: Auzentech X-Fi Forte
Boot HDD: WD Velociraptor 300 GB
Stuff HDD: 4x 1TB Samsung HD103UJ @ Raid5 (Perc 5i + 512MB)
PSU: Corsair 1000Watt Modulair
Water Cooling Setup: WC Setup --> Swiftech Apogee XT / Black Ice 360 GTX / 3x Triebwerk TK-122 / 2x DDC 355 Plus + XSPC Dual Top / EK-Spin Bay Reservoir
All build in a Corsair Obsidian 800D
SmokeyTheBandit is offline   Reply With Quote
Old 12-15-2008, 12:22 AM   #20
bowman
bowman's Avatar
3x2GB Micron here. The simple, cheap kind without heat spreaders. Works just fine but whether or not they'll clock well remains to be seen.. TRUE bracket arrives today.
__________________
bowman is offline   Reply With Quote
Old 12-15-2008, 12:25 AM   #21
NaeKuh
Chasing After Diety
NaeKuh's Avatar
meep...
i just went though hell and back to get my system up...
Having issues with my SAS controller card tho... I'll post more later as i load vista on it...
Right now im typing from splash box.... its not that bad honestly..
Oh i can confirm something for you guys tho... X58 will take Neha-EP chips..
As i said i am typing from asus splashbox with one in it right now.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Its my fault.. and no im not sorry about it either.
NaeKuh is online now   Reply With Quote
Old 12-15-2008, 06:00 AM   #22
JCGhz
JCGhz's Avatar
Originally Posted by DarthBeavis View Post
Testing on air
very nice
JCGhz is offline   Reply With Quote
Old 12-15-2008, 06:02 AM   #23
JCGhz
JCGhz's Avatar
I hope I didnt make a mistake asking for this board for xmas..
Old 12-15-2008, 07:49 AM   #24
FZ1
FZ1's Avatar
I'm waiting for my cooler and RAM to arrive so I can build it and crank it
__________________
Noctua NH-U12P
Corsair 620HX
Old 12-15-2008, 06:12 PM   #25
Guacamole
Guacamole's Avatar
Dude this board is awesome on all accounts the P6T Deluxe has the least amount of issues by far... Excellent board easy to use great OCer very happy and I had the Gigabyte but just not as good...
__________________
Gaming Rig:
Processing Rig:
Reply
Tags
asus p6t deluxe, p6t dlx
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
