Hi everyone, this is my first build so thought i would share it with you,
I was using an old Thermaltake case that wasn't cutting it any more
after moving into water cooling.
So my search for a case that would meet my requirements began.
Here's my 2 favorite cases
Silverstone's Tj-07
I love the lower section this case has.
MM-UFO Horizon
This case has so much room in it.
But neither of those cases were right for me.
So I set out to designing a case that would suit my needs.
This case would utilize all the skills i've learned as a cabinet maker, and my newest career as a Mechanical Engineering Technologist.
I decided on a case size of 20"wide x 20"deep x 24"high.
I wanted a lower section to hide as much of the water cooling gear as i could.
Here's the case frame.
I used a jigsaw to cut the aluminum 1x1x1/8" angle, and cleaned the cuts up with a lot of filing.
I pre-drilled using 7/64" drill bit and tapped for 6-32 threads
Using a 2" piece of aluminum as the corner braces.
showing the frame that supports the middle panel, as well as the 90degree
brackets that i made from scrap cut-offs.
I was really surprised how sturdy the frame was, to only be stronger when all
the panels are attached.
Home made 5x5.25 drive bay
Masking tape protects the finished side of face plate.
See what it looks like without masking tape.
Hope you enjoyed the pic's.
I'll post some more pic's tomorrow.
