I have a few questions that maybe you can help me figure out before i go forward with a build.
Heres the hardware im thinking about,
Mushkin Ram DDR2 4GB Kit XP-8500 Ascent
Sapphire 4850 SVGA (PCI-Exrpess, 1GB)
Lian Li PC-V350B Black (Cube, HTPC Case)
Asus P5E-VM HDMI (S775, DDR2, G35, VGA)
Intel Core 2 Duo 8600 (s775/3 ,33) Tray
While this is a good system, i want to bring over my 4 hdds. (first problem occurs here, there is only space for 2 and a third if i use the converter for a 5.25 bay device)
Now the real problem, Id like to watercool it. Cause i love building watercooled pc's.
I was thinking of using 2 - 240 rads (TFC with shrouds), mounted to the top of the case next to each other. Now, i think, without being 100% sure i think they both fit. i would mount the fans under the rads pulling air out of the case through the rads into open air. but im not sure if all 4 holes would have a clear passage way into the case without the cd drives interfering. But it does solve my hdd problem cause i can order some Mountain mods hdd fan brackets to mount my hdds externally. allowing me more working space on the interior for pumps and res.
as for pumps i was thinking a laing d5 with no aftermarket top mounted internally and a koolance res mounted on the rear... (using the 80mm mounting brackets available)
as for blocks i was thinking to use a fusion v2 and a ek4850 block. barbs im thinking 1/2" with 3/8" tygon so there is no need for clips.
now i know u might think this is a very ugly build, i think if done correctly it could look KILLER, and perform the same.
Heres what i came up with in sketchup: (yeah the rads are pa120.2's and the res is some random res i found, also the case is the previous v300 but i think they dont differ too much in size)
so now for my questions:
1) do u think the 2 240's would be sufficient to cool the cpu and gfx with a mild overclock in place?
2) do u think with the selected hardware there would be sufficient clearance within the case for the pump + tubing aswell?
3) do u think the NB would heat up, and need some sort of block aswell? if so, what blocks fit this motherboard?
Thanks for bearing with me and my endless questions (multiple times),
Barf
i fell in love with tremoloes build - such a great build :P
THe mockup looks good, those PA's will do the job no probs.
Crunching XS:
