XtremeSystems Forums
View Poll Results: Which fan category best matches your fan preference?
Ultra Slow Speed Fans - 1000RPM 25mm - 36cfm 40 31.25%
Slow Speed Fans - 1350RPM 25mm - 47cfm 45 35.16%
Medium Speed Fans - 1550RPM 25mm - 70cfm 36 28.13%
High Speed Fans - 2000RPM 38mm - 88cfm 22 17.19%
Ultra High Speed Fans - 2930RPM 38mm - 136cfm 6 4.69%
Multiple Choice Poll. Voters: 128. You may not vote on this poll
Reply
Old 07-04-2008, 10:29 AM   #1
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Poll Fan Noise Preferences
In my radiator testing, I purposely test the following fans. I didn't really pick these because I think they are the best, more than anything I just wanted a wide range of fan "Power" to test on the radiator to compare with. The Yate loons happen to be extremely well performing fans at a low cost and the Kazes are low cost, but not nearly as good as many other. Rather than voting for brand I was more looking to get a feel for a more generalize "I like this RPM range fan and happy with the amount of noise it produces".
Yate Loon D12SM12 120mm x 25mm - 70.5cfm/1350 RPM/33 db (open air)
  • Ultra Slow Speed Fans - Undervolted 25mm to 1000 RPM - 36+- Open air CFM
  • Slow Speed Fans - Undervolted 25mm to 1350 RPM - 47+- Open air CFM
  • Medium Speed Fans - Voltage 25mm adjusted to 1550 RPM - 70+- Open air CFM
Scythe Ultra Kaze DFS123812-3000 - 136cfm/3000 RPM/45.9 db (open air)
  • High Speed Fans - Undervolted 38mm to 2000 RPM - 88+- Open air CFM
  • Ultra High Speed Fans - Voltage adjusted 38mm to 2930 RPM
And I was just curious to find out which of these categories fits most users out there?
So, I figured the best way to do that is a poll..
Count me in for the Slow Speed 1350RPM 25mm category.
And if you think you're somewhere in between categories you can pick two.
Martinm210 is offline   Reply With Quote
Old 07-04-2008, 10:32 AM   #2
Jimmer411
Jimmer411's Avatar
I use slow yateloons everywhere in my case. Fullspeed on the rad and undervolted everywhere else.
__________________
Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
Current Phenom overclock
Max Phenom overclock
Jimmer411 is offline   Reply With Quote
Old 07-04-2008, 10:35 AM   #3
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Thanks!
I've got the poll up and running now, so whatever you use on the radiator is what I'm mostly after.
I actually have some of the ultra lows for case fans, but use slow speeds on my radiators.
Old 07-04-2008, 10:40 AM   #4
RealRedRaider
Banned
I use Yate Loon D-12SM-12...
RealRedRaider is offline   Reply With Quote
Old 07-04-2008, 10:51 AM   #5
Vapor
Admin
Vapor's Avatar
Nice poll
I use sub-ultra-low for case and ~ultra-slow/slow/med for radiator/HSF depending on application and performance I get from the various settings (recently, 5V San Aces, so just below "low" for airflow)
Vapor is offline   Reply With Quote
Old 07-04-2008, 11:01 AM   #6
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
vapor, then what PSU do you use? you cant control the rmp of the psu fan for ultra quiet unless you mod it
__________________
WhiteFireDragon is offline   Reply With Quote
Old 07-04-2008, 11:05 AM   #7
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Thanks!
Just what I'm looking for and pretty much matching what I was thinking too so far.
Old 07-04-2008, 11:30 AM   #8
lowfat
I am Xtreme
lowfat's Avatar
I can control the fan via software on my Odin GT
Voted Ultra Low Speed, the quieter the better.
__________________
27" iMac: i5 750 * 80GB X25-M G1 * 4GB DDR3 * HD4850
Tecnofront HWD: i7 920 @ 4.2GHz * Rampage III Extreme * (3) GTX460 1GB (2x1GB + 1x768MB) * 6GB DDR3 * 80GB ioXtreme * 30GB X25-E * 1000W Antec
Storage: (2) Sans Digital TR8M-B * 29TB
Audio: Shure SRH840 * Onkyo TXSR606 * Soundstage Center 5 * (4) Kef IQ1s
lowfat is offline   Reply With Quote
Old 07-04-2008, 12:10 PM   #9
MpG
MpG's Avatar
Hmm, no "ridiculously low" category, say around 700-ish rpm? Well, I'll cast my vote for the 1000rpm category then. I'm well-aware how bad the rad performance fall-off is at those kind of rpms, but any higher and I can hear the fans.
@Martin: In his recent reviews, Vapor mentioned that the Ultra Kaze rpm's might not be as advertised? What did you have to do to the voltage to make your fans hit those rpms? More? Less?
__________________
i7 920 | EVGA X58 SLI LE | GTX280 | Corsair DDR3-1600 2x3GB
MpG is offline   Reply With Quote
Old 07-04-2008, 12:11 PM   #10
eXa
eXa's Avatar
D12SL-12 @ 8.5ish volt on my mcr320 atm. But its slightly too noisy for me so im adding a mcr220 and hopefully get the yates down under 7v
__________________
Tho personally Iam wishing I had more girth than length. This skinny thing I got just dont get the job done anymore. The wife agrees.
eXa is offline   Reply With Quote
Old 07-04-2008, 12:15 PM   #11
Sparda
Sparda's Avatar
Clicking carelessly and doest realize it a multiple choice poll.
Medium fans on my cpu loop and slow fans on my gpu/nb loop.
edit : s-flex f and noctua p12
__________________
Sparda is offline   Reply With Quote
Old 07-04-2008, 12:19 PM   #12
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
In my first radiator test I hit around 2930RPM for my Ultra High speed test, and so I always target that number no matter what voltage. I don't measure voltage, I just log RPM with my Crystalfontz.
The 2000RPM I just picked because I assumed it would match their 2000RPM model, so that's what I always target for every 2000RPM test.
RPM is a wierd thing, it will actually climb for some time when the fan is first turned, on, so I have to let the fans warm up and it takes a while to get to the target RPM. Since I'm just trying to test all the radiators the same, I'm more concerned about maintaining exactly the same fan power. Still, I'm usually only good to about 10RPM or so, and lately I'm including the actual RPM averaged that was logged during the test, so if it's off a little the chart indicates the exact average RPM..
Old 07-04-2008, 12:19 PM   #13
Vapor
Admin
Vapor's Avatar
That was only for open air and only a maybe. On a radiator I have no reason to not believe they're not spinning close to their rated 3000RPM.
Old 07-04-2008, 12:23 PM   #14
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Originally Posted by Vapor View Post
That was only for open air and only a maybe. On a radiator I believe they're spinning close to their rated 3000RPM.
Good to know, I probably just goofed the voltage on my first test. No turning back now though, they are all 2930..
That's alright, it doesn't seem to be a very popular pick so far..
Old 07-04-2008, 12:50 PM   #15
whatever
How the Nexus fans will act on some MCR320/MCR220 rads ? Nexus or Yate Loon D12SM...nexus or yate loon...
whatever is offline   Reply With Quote
Old 07-04-2008, 12:54 PM   #16
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
I think the Nexus fan would be equal to my D12SM12 undervolted to 1000RPM, so it would fit perfectly into the "Ultra Slow" category.
Looks like I'm wasting my time with the Ultra High testing and should have just done one more "Mega Slow" 700 RPM slot..
Old 07-04-2008, 12:55 PM   #17
jonny_ftm
I like the S-Flex F series, they are medium strength but undervolt nicely. I run them at 800rpm and temps are great on my thermochill + Q6600 3.8GHz even under 100% Prime95 load
I largely respect your tests Martin, but I have a small consideration that I never said before:
You often use "Ultra Slow Speed Fans" expression to talk about ultra silent fans while you put them at 1000RPM
For most people, a true silent fan setup with 120mm fans is below 1000rpm. On a multiple fans setup, 1000rpm fans will be easily heard.
The sentence: "Ultra Slow Speed Fans", in my opinion, should be reserved for <800 rpm setups
Just my thoughts.
I voted Medium Speed Fans as I use the S-Flex F series, they undervolt to extreme silence even with many of them (1600 rpm at 12v and undervolt up to 3v with 200RPM)
__________________
Q6600 G0 L740B126 Lapped, 2x1Gb Kingston HyperX DDR2-1200
Gigabyte 8800 GTS 512Mb OC 756-1890-1000
TT Toughpower 750 W (W0116) new 8xPCI-E Rev.
Western Digital Caviar SE16 WD6400 AAKS rocks
WC: Swiftech H2O-Apex Ultra 220 GT + PA120.3 5v
OCZ XTC RAM Cooler, HR-05 IFX + 80mm FAN (NB), 2x HR-09U type 2 (mosfets), Modded Zalman ZM NB-47J (SB), Arctic-Cooling MX-2
Vista 32 bits
- ASUS P5K Premium bios 0612: (3.84GHz 8x480) @1.432v
- P5B Deluxe: 3.60GHz (9x400) @1.33v *** Old Setup (P5B deluxe)
OCCT 2.x Final Download
jonny_ftm is offline   Reply With Quote
Old 07-04-2008, 12:57 PM   #18
jonny_ftm
Yep, you said it 1mn before my post
I really think this "Mega Slow" test is the only true silent setup for people looking at silence
I, personally, multiply the rads to get enough power dissipation capacity with low speed fans: Power overclocking with real silence
__________________
Vista 32 bits
Old 07-04-2008, 01:08 PM   #19
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Yeah, it sounds like it's alot more popular than the ultra high.
I based my naming convention around the yate loon D12SL12 for "Slow", D12SM12 for Medium and went out from there. Panaflo and Delta both seemed to use the Ultra as a step, so I followed suit there.
Even though Panaflo considers this 1700RPM an "Ultra Quiet"
http://www.sidewindercomputers.com/pa12ulqu.html
I tried to stay away from the terms of silence or quiet as it's all user preference. I use some of the 1100RPM LED slow speed yates and consider them silent, but then there are also many folks that say the same thing as you and say 800RPM or lower is what's needed for real silence.
With a house full of screaming kids, I guess silence could come in the form of more noise for me...
Old 07-04-2008, 01:23 PM   #20
Eldonko
Eldonko's Avatar
I use mainly panaflo 120mm fans, they are reasonably quiet not that I care about sound.
__________________
Eldonko is offline   Reply With Quote
Old 07-04-2008, 01:30 PM   #21
Fairydust
YL D12SL-12 at 7V.
Fairydust is online now   Reply With Quote
Old 07-04-2008, 01:49 PM   #22
jcool
SR-2 up and running!
jcool's Avatar
I wouldn't call a 1000rpm 120mm fan "Ultra low speed", I call it "standard". Low speed would be the Scythe SlipStream 500 or any great 120mm fan undervolted to 400-600RPM (S-Flex. Noctua P12, YL and the likes).
__________________
World Community Grid - come join a great team and help us fight for a better tomorrow!
Rigs:
16-Cores: Quad Opteron 8347HE @ 2.0
12-Cores: Dual Westmere-EP X5680 @ 4.3 | Dual Westmere-EP X5650 @ 2.93
Octacores: Dual Gainestown X5570 @ 2.93 | Dual Harpertown X5450 @ 3.6
Hexacores: Intel Xeon L5640 @ 3.8
Quadcores: Core 2 Q9550 @ 3.8 | Dual Sossaman (Yonah Xeon) @ 2.0
crunching 24/7 | crunching part-time | offline/down
jcool is offline   Reply With Quote
Old 07-04-2008, 02:12 PM   #23
Makymaco
Excuse me for my english, i'm french.
I prefer 1000 rpm class fans undevolted to 600/700 rpm.
1000 rpm fans make too much noise for my ears.
I like the sound of my silent eagles and scythe sony bearings with 5v (originally 12v/1000rpm fans).
PS : @Martin : your tests are great
Makymaco is offline   Reply With Quote
Old 07-04-2008, 02:25 PM   #24
Eddie3dfx
Xtreme Mentor
Eddie3dfx's Avatar
My goodness, you have ears like a dog.
I can't even hear anything under 2000rpms.. lol
__________________
Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
Eddie3dfx is offline   Reply With Quote
Old 07-04-2008, 02:25 PM   #25
Arni
Arni's Avatar
hmmm Ultra Xtreme Slow Speed Fans - 500RPM 25mm -
__________________
~~~~~~~~water ed ~~~~~~~~~~
Sry 4 my english
http://galeriawc.pl
Arni is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
