SWC DDC TOP comming up - tests prove better than Alphacool, DDCT-01s, XSPC
OK, friends, long time we haven't seen some new DDC tops. This is about to change soon, very soon.
SWC comes from Sugar4o Water Cooling - Sugar4o is water cooling guru here in Bulgaria. He has been designing and producing water blocks, modding pumps, etc. since the dawn of water cooling. Quite many people had/have his cpu, chipset, gpu blocks. Including me. Some few weeks ago he bought a DDC pump from Laing Hungary Inc. He just couldn't resist to modding it.
Enough of the man, let's talk pump tops!
Testing methods:
High restriction system, consisting of a SWC block (very low restriction), some thermaltake vga block (highly restrictive), and restrictive barb at the end. Test is filling a 2 liter bottle.
Free flow - only pump with some tubing. Test - filling a 5+ liter bottle.
Barbs used are the the gray plastic you see in the pictures - 8mm inner diameter, 11mm outer. Only Petra's top was tested with D-tek's (should get some advance from that).
Pump was DDC 3.2, 18W, blue impeller
RESULTS
Restricted system......................................Free flow
The top has some major differences on the inside chamber. It's only a prototype - even the chamber is not polished. So even better results are expected after finishing the insides!
The reservoir is also a prototype - it's glued with the top with some chloroform. In high flow conditions a huge whirlpool on horizontal axis is formed and is the next thing to fix. This should improve flowrate quite a lot. The finished product should be optional and easy to mount and rotate to suit different needs.
HERE ARE SOME PICS:
(idiot taking pictures, pls don't kill me)
THE SWC DDC TOP
Shot with DMC-FZ7 at 2008-05-19
THE SWC DDC TOP WITH RES
DFI LP UT nF4 Ultrа-D rev.AD0 704-2BTA
Opty 165 LCBWQ 0722RPAW... 3150@1.506V measured ... Done
2x1GB Apacer CL3 UCCC @ 282MHz, 3-4-4-8, 1T, 2.65V ... Done
XFX 7900GS 480M... 650/1750MHz, no vmods for now ... Done
Water:
pics soon ...
ApogeeGT ... Installed
MCW60 ... Installed
MCR320 ... Installed
3x Delux-dirt-cheap 120mm fans ... Installed
DDC3.2 w/ Alphacool top ... Installed
Aignep nickel plated G1/4 to 12mm barbs ... Installed
Custom glass res ... Installed
2m of 12/16mm Reimatic tubing ... Installed
Personal list of kills: NW2.53, NW2.6, NW2.8, IS7, IC7-MAX3, P4P800 Deluxe (2), P4C800 Deluxe (478 mobo MOSFETs SUCK), V9999GE, 7600GS 128DDR3, Vitesta 566 2x256MB, Sicce NOVA pump x2
Personal list of achievements: OSA144DAA5BN CAB2E 0546FPCW @ 2952MHz, 1.693V on XtremeAir Sonic Tower=>1M, 8M
SINGLE GALAXY 7600GS @ 748(720)/1800MHz, 1.615V vGPU, 1.89V vMEM ==> 3D01SE 29294, 3D03 15905, 3D05 7291, 3D06 3701
- You may not post replies
- You may not edit your posts
Forum Rules
