Galaxy 7600GS 128MB DDR3 Voltmod - vGPU & vMEM (non-reference)
So, here it is:
1. Control points for the vGPU & vMEM:
VGPU:
Measure between GND (point 0 for example) and point 1, 2, or 3. If it's hard to measure here - do it on the other side on the corresponding capacitor or the parallel mosfet of p.1 .
VMEM:
Point 4 - on the leg of the mosfet.
2. The MOD:
You need two trimmers of 100kOhm.
Red is for VGPU, green for the VMEM. Black is GND - your choise. I prefer the resistor, as shown.
VGPU is done on FIRST leg of the regulator (FB1), VMEM on the resistor 336, as shown. FYI its connected to leg 4 of the regulator (FB2) and can be soldered there.
If the trimmers are sticked to the capacitors as shonw and you can read their description, then rotating them counter-clockwise should increase voltage. Watch it with care. It shifts slowly at the beginning, and very smooth afterwards.
The resistances between these legs and GND before the MOD are (with vGPU jumper at overvolt position):
FB1: 652Ohm
FB2: 228Ohm
The effect is impressive! The core made a huge increase from stock volts OC of 670MHz to rock stable 720MHz. And the memory - from 1610MHz to 1800MHz for benching, 1780MHz for 24/7. Consider that the GPU overwolts under load with about 0.020-0.035V.
Gonna post pics with the water cooling soon
The regulator is ISL6534, if someone is interested.
Thanks go to my commrad Yovchev for all the help.
I've been using the card 24/7 for 3 weeks now and haven't had any issues.
720/1780MHz @ 1.605V/1.89V. WC'ed GPU (never went more than 52 degrees), and HUGE ramsinks on the MEM (never more than 40*) and all the mosfets (same temp here) with a 120mm@1000rpm blowing directly at the card. 3D05 - 7150+ Marks.
EDIT: FutureMark now supports 7600GS cards. Here's an url - 7153
Good luck and report!
Disclamer: Everithing you do is on your own! You may and you will lose your warranty after the MOD. I cannot be held responsable of anything!
Cheers,
Abyss
DFI LP UT nF4 Ultrа-D rev.AD0 704-2BTA
Opty 165 LCBWQ 0722RPAW... 3150@1.506V measured ... Done
2x1GB Apacer CL3 UCCC @ 282MHz, 3-4-4-8, 1T, 2.65V ... Done
XFX 7900GS 480M... 650/1750MHz, no vmods for now ... Done
Water:
pics soon ...
ApogeeGT ... Installed
MCW60 ... Installed
MCR320 ... Installed
3x Delux-dirt-cheap 120mm fans ... Installed
DDC3.2 w/ Alphacool top ... Installed
Aignep nickel plated G1/4 to 12mm barbs ... Installed
Custom glass res ... Installed
2m of 12/16mm Reimatic tubing ... Installed
Personal list of kills: NW2.53, NW2.6, NW2.8, IS7, IC7-MAX3, P4P800 Deluxe (2), P4C800 Deluxe (478 mobo MOSFETs SUCK), V9999GE, 7600GS 128DDR3, Vitesta 566 2x256MB, Sicce NOVA pump x2
Personal list of achievements: OSA144DAA5BN CAB2E 0546FPCW @ 2952MHz, 1.693V on XtremeAir Sonic Tower=>1M, 8M
SINGLE GALAXY 7600GS @ 748(720)/1800MHz, 1.615V vGPU, 1.89V vMEM ==> 3D01SE 29294, 3D03 15905, 3D05 7291, 3D06 3701
- You may not post replies
- You may not edit your posts
Forum Rules
