Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Project: Cosmos S, first casemod "update"
    May 2004
    Taastrup@Denmark
    Project: Black & Chrom Cosmos S
    I think that the Cosmos S looks nice stock, but i can do better
    This is also my first casemod
    Planned so far
    All power cables gets black sleeving
    Every gray plastic part is paintet black
    Handle bars, door rails and most of the mesh are to be "chrom"
    Hardware:
    PSU: Corsair HX620
    Mobo: DFI Lanparty DK P35
    CPU: Intel Q6600
    GPU: XFX 8800GT Alpha Dog Edition
    RAM: TeamGroup Xtreem Dark PC8500 2 * 2 GB
    HDD: WD Raptor 150GB for OS
    Watercooling:
    CPU: EK-Supreme
    GFX: EK-FC88
    Rad: HW-Labs GTS 360 Xflow
    Pump: Laing DDC 1T with EK DDC X top
    Fittings: Bitspower Premium High Flow 1/2"
    Fans: Scythe S-FLEX SFF21E
    Tubing: Tygon R-3603
    Res: EK Multioption Reservoir 150
    First i tryed to spraypaint chrom, but just look at the pictures to see how that turned out
    Picture of the painted internals and HDD module
    Stock
    75% assembled
    Back
    Stock
    Halfway through the sanding
    Done
    "Be sober, be vigilant; because your adversary the devil, as a roaring lion, walketh about seeking whom he may devour." 1 Peter v. 8."
    Cosmos S Mod
    Apr 2008
    Canada, by the mountains
    I like the subtle yet effective changes!
    How much of a mess did it make to polish the rails like that? (Thinkin' of doing the same thing.)
    Me like jazzy Cosmos'
    Time is an illusion. Lunchtime, doubly so. Douglas Adams
    QX9650 @ 3825mhz CoolIT FZone
    2x HD3870X2 @ 845/946mhz air
    Asus Maximus Formula 0907
    2x2048mb OCZ Reaper 8500
    2x Raptor 150G Raid0; 'Cuda 1000G
    1200W Thermaltake
    xFi Extreme Gamer/ Z-5500
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    Dec 2006
    Looks good man. Nice work.
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    Subscribed!
    Apr 2008
    Quote Originally Posted by [XC] NetburstXE View Post
    Subscribed!
    Same here! Looking good so far
    May 2004
    Taastrup@Denmark
    Quote Originally Posted by TedShred View Post
    By sanding and alot elbow grease
    I stared with Grit P180 (normaly applied to wood, but gets rid of the paint)
    Grit P320
    Grit P800
    Grit P1000
    Grit P1200
    Grit P1500
    And at the end, i used "autosol" to polish the surface with, this product is available in most countries
    When you are done the surface should be very smooth before you apply autosol
    Cosmos S Mod
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    nice work buddy
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Apr 2008
    Quote Originally Posted by Fumle View Post
    Grit P320
    Grit P800
    Grit P1000
    Grit P1200
    Grit P1500
    I figured something that nice had to be hard work (dam). Excellent info, thanks Fumle
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    May 2004
    Taastrup@Denmark
    But it is worth the effort
    Cosmos S Mod
    May 2004
    Taastrup@Denmark
    A few parts have arrived yesterday, still waiting for my package from Performance Pcs, it was take by customs in denmark
    EK blocks
    RAM
    Cosmos S Mod
    Xtreme Cruncher
    Mar 2008
    China/Australia
    Wonderful sanding work there Fumle. Definitely keeping an eye on this Cosmos.
    Keep up the excellent work.
    Apple MBP 15": Intel T9400 (2x2.53GHz) | 2x2Gb DDR3 1066 | 9400M + 9600M GT | 250Gb 7200rpm
    Wish List: Return to desktop for some crunch action.
    I am on... QuadCaine.
    Banned
    Jun 2006
    in a Red Rage D....
    wet sanding is hard work... what other chems did you guys use to make the finish last...
    Mar 2008
    Great work, i love the shiny bars
    My new Intel build, logged here.
    WE GO PLAY HOOP
    -Barry
    Banned
    Jun 2006
    in a Red Rage D....
    try manually sanding some pieces of acrylic to right angle edges...
    cosmos s sure is popular now a days... like made for water cooling all internal build...
    I am Xtreme
    Jul 2007
    looks forward to updates
    May 2004
    Taastrup@Denmark
    I was unemployed when i started this mod, but since i got an job again, so not much for modding, polishing or anything
    PSU cable
    PSU cable again
    ATX 8 Pin Cable
    PCI-E cable
    Cosmos S Mod
    Banned
    Jun 2006
    in a Red Rage D....
    hmm seems that the matrix movie's sentinel's tentacles are in now a days...
    nice, an update! keep em coming...
  18. #18
    Banned
    Aug 2007
    C:\Philippines\TPC
    good job sleeving those cables!
  19. #19
    I am Xtreme
    Jul 2007
    nice sleeving
  20. #20
    Banned
    Feb 2008
    San Antonio, Tx.
    wow, sleeving each and every wire. didn't know they made smaller than 1/8"
    Good work,
  21. #21
    May 2004
    Taastrup@Denmark
    Quote Originally Posted by Big_Daddy View Post
    Good work,
    I used 1/8" sleeving for this (3mm in EU size)
    But i takes a short amount time, but really happy with the end results
    Cosmos S Mod
  22. #22
    Jun 2007
    Melbourne, Australia
    Nice work Fumle, especially good job on the sleeving! What tool did you use to remove the pins in the ATX and PCI-E connectors? I'm currently sleeving my HX620 and i can't get them out with the sunbeam tool.
  23. #23
    Banned
    Jun 2006
    in a Red Rage D....
    updates?
  24. #24
    May 2004
    Taastrup@Denmark
    Quote Originally Posted by twwen2 View Post
    The sunbeam tools er are SH**, i use an pin remover from AC Ryan, it fits perfectly but dont use much force, because it will break
    Quote Originally Posted by septim View Post
    updates?
    I belive i will get some work done this week, because i got some time from job from my new job as Server King
    Cosmos S Mod
  25. #25
    Jun 2007
    Right. Off to find an ACRyan kit then. Thanks for replying
