Hey all
The giant cooler I made a while back is not keeping up with the ST so I had to make an even huger one. I played around with different ideas and settled on using 3 PA120.3, 3 Alphacool 1510 pumps on Meanwell 150S-24 and three EK cylinder Reservoirs. I also decided to use an Emtell 12V PSU for the fans...
I thought about a lot of differnt configs (tower, hexagon, cylinder, cube) and settled on the idea of a trapezoid with the long side up top...this way I could suck up some AC from the floor vent
Well after I got the three rads strapped together they were sooooooo heavy a trapezoidal shape would just tip over
So I went with a sorta cube shape. The amount of material, time, and planning it would take to pull off a sweet looking hex is just too much right now. Although I will revisit that sometime in the future
Here's what I got together so far. Technically the thing is ready to Rock and Roll
I used a piece of 1 x 1/8 strap to join the rads. I also used silicon grommets to isolate them from the structure.
Truly the most amazing looking thing I have seen in my shop...it's like a car rad now
At least ten pounds empty...
I did some measuring...
Made an incredibly detailed construction diagram...
Somtimes ya just gotta bust a move...I was tired of gyrating around 12 different ideas so I started with a simple frame.
I braced up the rad rack with some angle mitred to 45 degrees
Trying to keep this small was futile
This isn't about small...
I am liking how it's going together at this point...
I tossed some tubing in there just to get a reality check
At this point I could put some wires on the PSU and git r done...but I want to add some acrylic to baffle the sound.
I added a strip up top to keep any air from recirculating.
The pebble grain lexan is unbelievably expensive...we are talking HUNDREDS...sigh.
This is my favorite part so far...no problem filling this humongo cooler...
The res/pump units get supported by the EK clips on a strap and by the cutout up top and by a piece of angle that I will 777 some Neoprene onto to deaden the noise.
Blue tape is aproximately where I plan to cut the exhaust port.
The rear panel will get holes for the 6 lines. I will likely mount the AC plug there too. Up top I will put any controls and gauges. Probably would look awesome with 6 gauges for pressure (in and out) and 6 gauges for the temps (in out) and maybe even a rheostat for the fans...but I doubt I will need to undervolt them. But that can all happen later on...I need some COOLING and I need it NOW![]()
Gonna call it a night before I screw anything up:twitch:
MOAR soon.
i7 920@2.8
X3220@3.0
X3220@2.4
E8400@4.05
E6600@2.4
