In the begining...
Intel C2D E6300
Asus P5W DH Deluxe
XFX 8800GTX
Coolermaster iGreen 600W
2x 200GB SATA HDD
1x 160GB SATA HDD
PQI Turbo PC4200 2GB DDR2 533mhz 3-3-3-8
Antec P180
then...
Gigabyte pump from 3D Galaxy kit
Alphacool NexXxoS XP
Black Ice Xtreme 120mm
Clearflex 1/2" ID Tubing
Swiftech MCRES res
added EK FC8800GTX to the loop and another radiator from the Gigabyte 3D Galaxy kit. back in the noob days, mixing aluminum with copper![]()
then moved to a BIX2, water colour turned from blue to purple from not cleaning out the gunk left over by previous owner, again, noob days![]()
also upgraded to a Laing DDC with Petra's top and a Cathar Storm G4
my sexy Alphacool block
then lapped my CPU
then flushed out the gunk inside the radiator and changed to Swiftech 7/16" tubing
Redline water wetter looks yucky, and tubing got dented from overuse of coolsleeves in unnecessary places, also changed to a Swiftech Storm
painted the Storms mounting plate and changed to a Intel Bad Axe 2, ditched the Swiftech stuff and bought some el-cheapo tubing from Bunnings
dogey custom bracket to support the G80
heaps of changes have happened and now:
-upgraded to an E6600
-downgraded to a 8800GTS 320MB
-swapped the 3x HDDs to a single 500GB one
-upgraded to a Corsair HX620W PSU
-upgraded to 2x 1GB Crucial Ballistix PC2-8500
-got my hands of 1/2" ID Tygon Tubing
-upgraded to a Swiftech MCR220
-Laing DDC died so I bought a Swiftech MCP350
-changed to a Swiftech Apogee
-changed out the Swiftech MCRES to a brand new one, old one had dirty gunk in it
-added an EK Nickel plated chipset waterblock and sold the EK FC8800GTX
-put a HR05 of the SB
-added an OCZ XTC RAM cooler
then redid cabling and loop order, didn't like having my pump running sideways
I have no idea why the paintwork is cracked like that, I will fix it sometime, also the white stuff is masking tape, my attempt to block out noise and dust, didn't have any duct tape lying around at the time
I will be changing the motherboard out to an Asus P5N32-e SLI or Asus P5K Deluxe in the next few weeks so yeah.. stay tuned
This all happened since mid January 2007![]()
