In this thread I will be providing you with feedback from my tests on this board.
I just unpacked it some hours ago, and finally set up the system...with my SuperPi bench PCI Card since all my Twintech GeForce cards that I have here with me are incompatible with this board( grrrrrr ).
Very similar to my first experiences with the first Striker Extreme ( 680i )... tried various BIOSes... and all of them seem to have their problems.
I'm using 0511 at the moment... the board ignores me most of the time.
Changes the CPU Multiplier at will... boots & runs fine with the given FSB & RAM Frequency & Timings... Whenever I reboot my windows it will hang during POST before detecting the SATA drives... with the LCD Poster at "TEST MEM" [ not DRAM_DET ]
Another reboot and the board sets its own stuff in BIOS ( without notifying me or giving me a overclocking failed message ) and POSTs & boots fine...
I'm going to get inside the BIOS again now, set the system at stock settings ( 333MHz FSB, DDR3-1333 RAM and relaxed timings ) and see if the board is corrupting my OS or not.
If my files are ok, I will move to 400MHz FSB & DDR3-1600 RAM and check for the SATA data corruption issue again.
p.s. I also had some weird POST failures with the LCD Poster stopping at "INIT8042"... even at stock settings or with the "Load Default Settings" option.
I think it happens after saving and exiting the BIOS sometimes.
...glory times...
( grrrrrr ).
i think 790i is a wonderful chipset, but this problems make it unuseable, so i take the mobo in the corner till this problems will assolve i dont wanna lose my data's or hdd's
Saaya yupp, I agree
