Hello everybody,
I've noticed that there are lots of you with corruption and/or video freezing issues with the Asus Striker II Extreme, so I decided to help you as much as I can to get your issues sorted.
But to "allow" me to help you, you need to help me first.
In the next post you'll find a "template" which you'll have to use to report your system specs & settings ( in detail ) to me, so I can check them out and start troubleshooting your issues individually.
It looks like I'm asking you to fill a big list of settings, but believe me, it's worth it.
Please do not bother posting if you're going to ignore my "requirements" ( check the next post ) and say that you do "fulfill" them.
The best way to troubleshoot and hopefully solve a problem, is to analyze the specs & configurations in detail.The greater the detail and the more chances you have to solve a problem.And this doesn't only apply to computer related only problems, but in every little ( or big ) thing in real-life as well.
This thread is only about the Striker II Extreme, so please do not post here if you have another nFORCE 790i motherboard, it will only make things more complicated, and will derail the thread.
If you're going to post and try to work with me here to get those corruption and/or freezing issues ironed out, please use the template found in the next post
p.s. If you're using the "Auto" setting, report the value set by the motherboard ( some of them have a "current setting" next to them, displaying what the motherboard is using )
p.s.1. I'm no longer providing support for this product.
p.s.2. If you're from nVIDIA or Asus, your product ( 790i chipset & Striker II series ) sucks!
p.s.3. It's "stable" slim, not "estable"
p.s.4. Have fun!![]()
), Juan J. Guerrero
