Kindly help me iron things out...
im on the bleeding test last night, i slept at 2am, listening to the music with winamp in my pc, then i kinda notice that my room is so dark, which is supposed to be some blue and red lights in my room coming out from the case and my saitek 2, so i then woke up at 6:50 am and checked why i have no music and no lights (from the pc) i open the sidepanel then all the liquid in the res and all the tubes are gone, figured out that the hose from the inlet of my chipset block has been detached, coz, i didnt put the lock of my koolance 1/2 compression fittings coz it wont fit both of it, so the other one has and vice versa, i didnt expect that the hose will come out like this, because it is well fitted, and cannot be remove easily so i didnt bother to put other clamps that may do the job. (laziness)
now, the hard part is, that all the liquid flowed directly to my current 8800gt, the xfi is wet, same as the 2 120mm fans down in my rad, and lower part of the motherboard including the sata cables are also wet...
would you help me figure out, if there's any possible damage or parts that ill never have the chance to use again?
mobo?
processor?
xfi?
GFX Card?
