Results 1 to 22 of 22
Thread: G1/4 Mod For D5 1/2" & 3/8" Barbs
Hybrid View
    Sep 2006
    North East UK
    This mod was instigated by BP-Vincent at Bitspower so all credit to him
    Very similar to a previous guide Tapping and Threading a G1/4 Hole but thought i would do a run through with the D5 to give a better idea of how it looks in practice.
    Hopefully this simple guide will explain the tools required and how best to tackle the job.
    Tools Required:
    Electric Drill
    Hack Saw
    11.8mm HSS Drill Bit
    1/4" BSP 19 TPI Second or Plug Tap
    Wrench
    400 Grit Wet & Dry
    First of all you need to disassemble the D5 by unscrewing the front barb assembly from the pump itself and you also want to remove the pump bracket to make the job much easier.
    Once you have the front off you need to cut the existing barbs off down to the Red line indicated in the picture below. You want to get this as precise as possible as this is where the rubber "O" ring of the barb will be seated so it needs to be as flush as possible. Don't worry if you're slightly off as you can always straighten things out with some 400 Grit Wet n Dry on a flat surface the way you would lap a water block base.
    Once you're happy you have the existing barbs removed and flush you need to take a 11.8mm Drill and ream out both the inlet and outlet of the pump and its best to have the part clamped in some way as you need to keep the drill hole as accurate as possible or even better using a pillar drill. You will find the pump material drills really easy and i found i didn't need any lubricating at all but feel free to use it if preferred.
    Now you have the 11.8mm hole, take your G1/4 Tap and basically start screwing it into the hole you have just drilled. Its paramount at this stage that you offer the Tap up to the hole perfectly vertical at 90 degrees to the surface otherwise you could end up with the thread running off and the barb not fitting flush resulting in leakage.
    Keeping the Tap lined up correctly you can start Tapping the hole by turning the Tap half a turn clockwise followed by quarter turn anti-clockwise which allows the swarf to be released from the threads keeping the cutting edges of the Tap free to make cutting much easier – the process of half a turn clockwise followed by quarter turn anti-clockwise should be carried through till the Tapping process is finished. Again i found no lube was necessary but feel free to use it if preferred.
    Its just a case of cleaning up, especially if you used any type of cutting lubrication and reassemble the pump and you're good to go.
    The pictures below are first using 1/2" Danger Den Stubby barbs then the complete pump i used D-Tek Hi-Flow as the "O" ring stands less chance of popping out due to the recess "O" ring grove.
    Feb 2007
    Nice job Coolmiester!
    Aug 2006
    Nice mod - looks fairly easy to do
    I would say sticky!
    - Tw1st3d
    Hardware
    | Asus m4a89gtd pro | Phenom X4 955 | 2 x 2 GB Kingston Value PC10600 | Asus ATI HD4870 DK | Seagate 500 GB 7200.12 x 4 | Corsair TX550 |
    Case
    | Lian Li PC-A70F |
    Watercooling
    | Alphacool Xtreme III | Laing DDC + EK X-res 140 | DangerDen TDX | XSPC 4870 FC | 8/10 mm PushOn |
    Xtreme Mentor
    Jun 2007
    Chicago
    What size tap would you need for the 3/8" barb?
    btw I will be doing this! I can't believe nobody posted this before, thanks!
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Banned
    Mar 2007
    French Quarter of Grinchville
    Quote Originally Posted by Eddie3dfx View Post
    You mean G3/8" or 3/8" ID tubing barb ? If it is the latter, it use the same G1/4" threading so basically the same tap and drill as outlined here.
    Great guide, I knew it's that easy but it's essential to take your time to make things perfect so the o-ring sit flat.
    Dec 2007
    Taiwan
    Perfect job, coolmiester ...You help me a lot....
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Awesome work!
    On my long list of to dos is exactly that, then I would have the ability to tinker with smaller inlet nozzles. I could then machine a series of custom G1/4 barbs with various nicely tapered and extended inlet nozzles to run some tests on.
    I'm pretty sure now, you can make the D5 a really good pressure pump with a smaller inlet, just need to do some experimenting. I figured a combination of a nozzled inlet and cleaning up the outlet is key in performance.
    That looks really sharp!! Never like the looks of the plastic barbs.
    Unoriginal Macho Energy
    Dec 2002
    Quote Originally Posted by Martinm210 View Post
    Wow I do like this mod! Martin, I think you have it backwards though... The key is to narrow the OUTLET, not the inlet, although experiment both ways. Most high pressure pumps have a larger inlet and a narrow outlet, RD-30 is a very good example.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by nikhsub1 View Post
    Interesting, I havn't done much experimenting, but way back I did try some nozzles on the inlet and outlet of a D5 and found that at least for maximum pressure head, a smaller inlet helped maximum pressure, but a smaller outlet had no effect at all.
    Alot of the inlet size probably depends on the impeller inlet. Only way to know is try it. I figure if you do this mod and you're just experiementing with different custom barbs, there's no risk in ruining anything. Doesn't work...throw away that nozzle. From all the DDC3.2 top testing and examining, the smaller inlet tops generally did better in pressure than the others with larger inlets. Similar thing with the Alphacool top, switch over to the side nozzle and add some restriction at the inlet, and th curve shifts to the left. The DDC does have a pretty small impeller inlet though...
    I think the D5 has too large of a volute with the stock top, so you'll probably never get really good pressure out of it without a whole new top, but never hurts to try and see..
    Feb 2008
    Coolermeister, I never expected this level of a response when I mentioned that I was really interested in your results from trying BP's mod. Thanks a bunch for the effort.
    ASUS P7P55D
    Intel CORE i7-860
    EVGA 8800gt 512mb
    Corsair 800D
    Banned
    Apr 2006
    Portishead, Bristol, England
    Nice one Paul, i think i will try and do the porting mod on mine this week then maybe get you to mod the top for the G1/4'' and give ya few beers if ya intrested at all
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Heh, looks like I was ahead of the curve yet again.
    http://www.xtremesystems.org/forums/...6&postcount=44
    Full thread: http://www.xtremesystems.org/forums/...d.php?t=150733
    I had thought about this for about a year prior to asking the question, just couldn't bring myself to spend the money to find out, as I have no use for a 1/2" barbed pump.
    Circles SucQ!
    Sep 2006
    North East UK
    NP Meatpuppet - this is what the forum is all about
    I have a few Laing D5 tops from various other projects including a few of the Norvl 1/2" OD which i thought i would try the mod out on first but on closer inspection i found the inlet and outlet to be 13.3mm which would be perfect for a G3/8 barb where as the normal D5 is 10mm.
    I've no clue whether this would be beneficial or detrimental to the performance gained in a watercooling situation but Laing obviously do it for some reason and its got to be worth further investigation imo (shouts of Martin for help )
    Sep 2005
    Toronto, Canada
    excellent mod guys!
    thanx for sharing, id really like to see some #'s on these to see if they increase performance of the pump as well
    q9550 @ 444 x 8.5 1.3v - Venomous X
    p5q DLX
    Ocz RPR 1066 4 x 2g @ 1066
    eah5870 V2 @ 920/1250 - HR-03gt
    Antec Fusion Remote MAX
    Xonar HDAV1.3
    Ocz zx850w
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by coolmiester View Post
    Cool, you're the first one I've seen with the noval top apart
    According to Laing's charts the larger threaded top is supposed to be a little stronger in the 1.5GPM range, so overall it should do better.
    I didn't expect to the inlet being that large though. Wow!
    I had actually recommended to swiftech many many months ago that they offer these threaded top instead of the 1/2" hosebarb top, but they never responded.
    Sure, I'd be interested after I get caught up. Have to wrap up the parts I have on hand now, then I wouldn't mind tinkering with the D5 again.
    If nobody starts producing a top, I might even be force to buy a Koolance D5 top, just to see if it does anything.
    Sep 2006
    North East UK
    If nobody starts producing a top, I might even be force to buy a Koolance D5 top, just to see if it does anything.:D
    Hahahaa, i just had to email Koolance yesterday to get a couple of their D5 tops shipped over as i can't get my hands on any in the UK but still waiting to hear back.
    Having said that i'm going to have a word at the machine shop tomorrow to see if they can mod all the D5's i have here.
    Certainly be interesting to see the difference the bigger Norvl top would add to the mix.
    Sep 2005
    Toronto, Canada
    does this mean there could be some benefit to porting the inlet on the regular tops as well?
    p5q DLX
    Xonar HDAV1.3
    Ocz zx850w
  18. #18
    Xtreme Mentor
    Jun 2007
    Chicago
    G3/8" but of course!
    better yet, 9/16 that dd uses
  19. #19
    Sep 2006
    North East UK
    No no mate, Danger Den only used 9/16" a couple of years back in their transition period between 1/4" NPT to what they use now, G1/4
    9/16" was a strange size to go for imo and had us all confused for a while and was a nightmare when people were trying to replace barbs for their previous blocks
  20. #20
    Mar 2007
    Great guide, coolmeister!
    P.S. you might want to check your sig
  21. #21
    Sep 2006
    North East UK
    Cheers karbon, sig fixed
  22. #22
    Xtreme Cruncher
    Aug 2006
    Sydney, Australia
    Great work Coolmiester! I'll definitely have to look at this mod myself.
    Cheers
    GAM
