Did the tedious testing today after buying a ball valve to control flow and setting up a plumb water column stand, I was off and running doing my first P/Q chart. Collected 16 data points just as a check to see if any one was way out of wack.
Here is my ported P/Q graph against several others that Alex graciously provided me, gotta love Petra's for being so involved in the community![]()
Anyhow, here is the graph. My first thought was...oh man, what did I screw up, that curve has a big wow in it...it doesn't compare well to the swiftech chart at all either.
I was darn near ready to scrap the whole test and start over, but I was being really carefull with a nice plub stand, multiple measurements, etc. So before I did that I figured I would go to laings site and look at their graphs again. Particularly their D5 brochure:
http://www.lainginc.com/pdf/LTI%20D5...-%206pages.pdf
I then sniped out the 1/2" barb chart and pasted it in. Ok that looks more realistic, I opened up the inlet and outlet, so actually lost strength when less than 1.2gpm, but gained really well after that. More importantly the Laing graphs also have a similar dip around 1gpm, my data is looking more plausible now.![]()
Now on to the big barb comparison. I mean after all porting should probably be similar to a large barbed outlet right...YES it is...now I'm feeling much better about my results![]()
So a question might be would this mod benefit real world loops.
So far I've tested out my GPU loop with MCW60,MCR320, 5/8" T-line, and 80" of 7/16" tubing and got 2.76 GPM, so it definately helps low restriction loops.
Now I'm curious about inlet/outlet nozzles. Is there a way to bulg the curve upward in the 1 to 3 GPM range, or is that an impeller thing?
FYI,
Here are those modifcation pics again:
Before:
After:
My question is...why is swiftechs chart so far off from Laing, mine looks much more like the Laing charts and I had to go to a 4th order polynomial equation just to match the roller coaster that it is...hmm![]()
I'd love to try a D5 impeller with a couple more blades, I bet that would be just the ticket to match water cooling needs.
