XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 02-20-2008, 10:46 AM   #1
jeeka
jeeka's Avatar
320GB AAK firmware - Here's a BETA AAM Firmware!
UPDATE: Seagate came through and gave me a BETA AMM Firmware for the 320GB Drive, after about two weeks of leaning in on them....Check further down to get the link to it.
(Changing the POST TITLE to help others find the BETA AAM Firmware)
_________________________
I had a Seagate SATAII 320GB drive with an AAD firmware, which is really fast for it's type. I planned on using another, similar drive in a RAID0 or possibly a RAID5 (would have to purchase more drives). I bought an identical drive off Newegg and it came with the dreaded AAK firmware.
At first, I thought, no big deal, but benching it, it was ~20MB SLOWER than my AAD Firmware! That will KILL any dreams of my RAID running at full potential.
I called Seagate and they WILL NOT help me out by swapping to an OLDER AAD drive! The genius on the phone initially thought I wanted to swap to a higher 500GB Drive with the AAM firmware, which fixes these issues, but it's only available for the 500GB model, not the 320GB model (yet)...
All I was asking for was to give me the performance that I paid for, and not a crippled drive. Am I wrong in all this? All I was asking for was a swap to an AAD or similar drive...
So I am stuck with a crippled AAK 320GB Drive that I will have to return to Newegg because it's not as well of a performer as the older drive... It's not broken, it's just not working 100%, which can EASILY be fixed with a firmware update, they already have one for the 500GB model!!! So I'll end up with a restocking fee on top of all this. Not a biggie, just more upset with the cheapie Customer Support Philosophy of Seagate these days.
Anyone have any ideas?
I'm not being a moron am I?
Thoughts? Thanks!
jeeka.
__________________
MB: Asus P5Q Deluxe BIOS 1406
CPU: Q9550 (L835B078) e0 2.83Ghz @ 4105Mhz so far (8.5x483) - 1.3625v vCore Bios, ~1.344v in CPU-Z
RAM: 4GB (2x2GB) (5-5-5-15) 5:6@579Mhz (so far) 2.2v G.Skill F2-8500CLD5-4GBPK
Vid Card: eVGA GTX 260 FTW
Cooling: ThermalRight Ultra 120 Extreme w/ AS5 & 120mm fan blowing + AS5 on all factory pipes/HS
Optical Drives: NEC ND-3540A and Lite-On LH-20A1H
Drives: 750GB Seagate Barracuda SATAII 7200.10 - RAID0 2x320GB SATAII Seagate Barracuda 7200.10 - RAID0 2x320GB SATAII WD 7200.10 - 200GB SATA Seagate Barracuda - 2x160GB IDE WD1600JB (External)- 120GB IDE WD1200JB (External) - 80GB WD800JB (External) - 100GB IDE WD1000JB (External)
Case: Antec p160 PSU: Antec TruePower Trio 650w Fans: 4x120mm
jeeka is offline   Reply With Quote
Old 02-20-2008, 10:51 AM   #2
NickS
I am Xtreme
NickS's Avatar
Keep swapping till you get AAD? Or, go to a local PC shop, best buy, etc and look around till you find an AAD.
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Old 02-20-2008, 04:26 PM   #3
ziddey
Send a message via AIM to ziddey
Sorry to hear that. Hopefully AAM will make its way down to the 320GB's someday. I just got a used 500gb .10 that turned out to be AAK.
Just curious though. I remember a year or so ago, people were complaining about some seagates that were really loud. Were these AAK? 308? My seagate is way way way louder than the two wd 500gb's I have (ks and ys).
At this point in time, why get a .10 over a .11? If raiding a .10 and .11, shouldn't it still perform no worse than having two .10's (assuming the .11 doesn't have any specs lower than the .10?)
__________________
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
ziddey is offline   Reply With Quote
Old 02-20-2008, 04:48 PM   #4
jeeka
jeeka's Avatar
Ya, that makes sense in theory. I would always like to try and have equal drives. Mainly, for me, it's knowing that one drive is holding the other one back.
__________________
Old 02-20-2008, 05:28 PM   #5
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
This is why I stay away from Seagate these days, why would you even have to get such various results between a product only based when and where it's manufactured. This is something I dislike a lot. Should be the same thing if it carries same product model, 2~3 MB/s or so would be ok I guess but 20MB/s slower isn't acceptable.
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is online now   Reply With Quote
Old 02-20-2008, 07:24 PM   #6
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
How do you determine the firmware you get? I bought a 250GB seagate, their really thin single platter one that is pretty quick. Do any of those have poor firmware?
BTW, can't you flash the firmware on the drive?
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 02-20-2008, 08:19 PM   #7
Rilla927
Give it some static and then call them and tell them the drive died so they replace it. This is BS!
__________________
Rilla927 is offline   Reply With Quote
Old 02-20-2008, 08:39 PM   #8
Nick04263
Nick04263's Avatar
I have personally never tried it with a Hard drive (never had too) but isn't it possible to reflash the firmware by some means? Or is it locked, on a ROM chip, etc?
Nick04263 is offline   Reply With Quote
Old 02-20-2008, 09:59 PM   #9
jeeka
jeeka's Avatar
You can go into the Intel Matrix Storage Console and see the firmware when you click on the drive. These drives also have the shipping firmware on the HD's label.
__________________
Old 02-20-2008, 10:01 PM   #10
jeeka
jeeka's Avatar
Ha, true huh, but they already have my calls, online chats and online requests logged, as noted by the genius on the phone who helped me. Knowing them (and in that case they would have the right to do so), they would be suspicious of my drive's "sudden death" and would tell me to go take a hike......
__________________
Old 02-21-2008, 10:16 AM   #11
ziddey
It'll also say it during post. Or in programs like hdtach/hdtune.
Hopefully aam firmware will hit the lower drives soon or someone will figure out how to forceflash them.
__________________
Old 02-21-2008, 12:19 PM   #12
SparkyJJO
SparkyJJO's Avatar
OK thanks, I'll check my label. Intel matrix storage console won't do me a bit of good since I don't have an intel board
__________________
Old 02-21-2008, 03:37 PM   #13
it_burns_when_i_pee
it_burns_when_i_pee's Avatar
i was in the same boat as you, except i bought a pair of 320gb's for raid and they were slow! i did post something about it a while back
anyway i sold them on for ebay actually breaking even for a change, got 2 x WD 320gb's now and world of difference on performance.
i'd recommend you do what i did
__________________
"Never under estimate the predictability of stupidity"
Q6600 @ 3.6 / TRUE (both lapped)
P5Q Deluxe
4Gb Corsair DominatRIX 1066Mhz
1Gb HD 4870 + HR03-GT
2 x 320gb WD3200AAKS RAID-0
Thermaltake Toughpower 850
X-Fi Fatality / SR-71 Amp > Sennheiser HD650's & Logitech Z-5500
HP W2207 TFT
and me??? Powered by absolut, kebabs, tramadol & a new liver
it_burns_when_i_pee is offline   Reply With Quote
Old 02-22-2008, 07:17 PM   #14
SparkyJJO
SparkyJJO's Avatar
My drive is an AAC firmware drive. Good? Bad?
__________________
Old 02-22-2008, 08:08 PM   #15
ziddey
no prob do an hdtach and you'd know if you had problems
__________________
Old 02-22-2008, 08:35 PM   #16
jeeka
jeeka's Avatar
AAC supposedly was really good and didn't have these issues of being "capped". I have AAD on my other drive and it wipes the floor with the AAK Drive.
I wonder if the aquisition of Maxtor allowed them to "downsize"/reuse parts to lower costs and start quietly swapping in less effective parts left over from the Maxtor stuff while riding the "quality" reputation of Seagate. If so, I did not buy the drive that was advertised to me.
It's Ok, I just bought another WD3200AAKS drive to pair it with my other WD drive and put THAT setup into a RAID.
Seagate will pay for spitting on my hands after I handed them my money.
jeeka.
__________________
Old 02-23-2008, 07:16 AM   #17
it_burns_when_i_pee
its wrong they are getting away with it
i paid full whack for the seagate 320gb's, infact i think they a bit more expensive than the western digitals.
seagate advised me that i couldnt update the firmware on the hdd's because the eeprom chip used is different. i'll avoid seagate for this, but who's to say that other manufacturer's wont do something similar?
__________________
P5Q Deluxe
HP W2207 TFT
Old 02-23-2008, 07:13 PM   #18
jeeka
jeeka's Avatar
UPDATE:
They sent me an e-mail with a link to AAE FIRMWARE!.....I knew they would get it wrong......I HAVE AAK! IT WON'T WORK!
So, I backed up whatever I had on the AAK Drive, knowing it would not work, and tried it, just in case I could be proven wrong (which is often) ...
AND..... rebooting back into Windows, HD Tune and the Intel Matrix Storage Console still had me at AAK.....
So it turns out that Seagate knows less about their drives than we do...
Here is my attachment that I sent to them...sorry so big on screen.
Why can't they just tailor an AAM Firmware from a 500GB model and release it! They are probably workng on it as we speak...ya right...
__________________
Old 02-23-2008, 08:49 PM   #19
REVHEAD
REVHEAD's Avatar
Ok after reading this thread I dont understand why you guys have not flashed to aam firmware, a simple google search would have solved you heartache.
I had two 500gb 7200.10s with aak firmware, and a while back contacted seagate support who basically told be to buy new disks becasue my drives couldnt be flashed, well I found a link with a firmware update, and guess what she flashed to the new firmware..
I have saved you the trouble http://forums.vr-zone.com/showthread...=213448&page=5 a guy in this forum has uploaded the firmware for us ,burn it to a cd ,boot from cd skip thru the readme and then when in A:\ promt mash in firmware.bat I think it was.
Just make shure you read the readme file before jumping in, and please dont blame any one if you hose your disks, but I did my two and it worked a treat..
Good luck .
__________________
GA-EX58-UD3R rev 1.6[/color]
6gb Patriot DDR3 @ 1333mhz
166 QPI Core i7 920 @ 3.33ghz
4 X 80gb Veloci Raptors in Raid 0
Creative Xfi Fatal1ty
2 Sapphire 4870s in Crossfire
Dell 3007 WFP
Cooler Master Real Power Pro 1000watt PSU
Lian Li PC-A10B
Air Cooled by Noctua
REVHEAD is offline   Reply With Quote
Old 02-23-2008, 09:02 PM   #20
jeeka
jeeka's Avatar
Good luck .
Before you claim to be victorious in a solution, please note that this is for drives ending in 308 ONLY....whether it be 320GB, 500GB, etc.
You have not totally saved us the trouble since this only applies to some people...and even then some of the people in the other forum could not get the AAM Firmware to take on their 320GB Drives ending in 308....
I have done HOURS of searching on the net, so please don't tell me that I need to try harder.... I appreciate the efforts to contribute, and yes, you are partly right, but we are not there quite yet.
I have seen this post as well, hopefully this helps us find a solution!
Thanks again for helping me arrive at a solution, and don't take the above personally.
Fight on!
jeeka.
__________________
Old 02-23-2008, 09:23 PM   #21
jeeka
jeeka's Avatar
UPDATE:
Hey ya'll tried the link from REVHEAD's post, seeing as how I have an AAK with a P/N ending in -308...and it did not work.
Hopefully someone might be able to build off of REVHEAD's link.
REVHEAD, thanks for the link!
-jeeka.
__________________
Old 02-23-2008, 09:27 PM   #22
REVHEAD
REVHEAD's Avatar
I am sorry to hear this, my drives end in -308 and the flash worked. sorry it it didnt flash.
__________________
Dell 3007 WFP
Lian Li PC-A10B
Old 02-23-2008, 09:30 PM   #23
jeeka
jeeka's Avatar
Ah, wait a second, I used flash.bat and not firmware.bat.......was I supposed to use firmware.bat????????
__________________
Old 02-23-2008, 09:36 PM   #24
REVHEAD
REVHEAD's Avatar
ill recheck for you let me load it back up again
__________________
Dell 3007 WFP
Lian Li PC-A10B
Old 02-23-2008, 09:45 PM   #25
jeeka
jeeka's Avatar
I believe it's just flash.bat...
I saw one your last post (#60) in the other forum and you posted "firware.bat" as opposed to firmware.bat, but in the link, the poster said to use "flash.bat"...
You have the 500GB Drive, no?
I have the 320GB...
arg!
jeeka.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
