Just a few numbers from my ES Q9450 that I've been playing with for awhile
http://valid.x86-secret.com/show_oc.php?id=297476
Running at the 1333MHz bus it features 2x6MB L2, 6-8 multiplier range and some lovely 45nm technology squeezed into it.
First some bad news.....
Seems the FSBwall it pretty low on these ES chips - 478MHz
http://valid.x86-secret.com/show_oc.php?id=297477
The x8 multiplier really limits the maximum GHz overclock on these cpus. HEre's hoping that the retail ones scale better!
...Let's see how it scales up to its predecessor the Q6600 ?
System setup
abit IX38 QuadGT
2x1024MB Team Group 450@4-3-3-8
Vvikoo 8600GT
Swiftech Compact H2O cooler
Silverstone 850W
I've decided to run both at 3.6Ghz (8x450Mhz) due to the limitation on the Q9450 FSB. Both cpus run on the same system running the same specs. The only difference was the the Q9450 vcore was 1.3volts whereas the Q6600 was 1.45volts:
Lets see some comparisons:
1M SuperPi
Q9450
Q6600
32M SuperPi
Q9450
Q6600
32M/1024M WPrime
Q9450
Q6600
3DMark06 CPU Score
Q9450
Q6600
Power consumption and Heat
Q9450
Q6600
Check out that current rating with all four cores loaded, the Q9450 is drawing nearly half that of the Q6600. Add to this the fact that the Q9450 requires less voltage and it's safe to say that the Q9450 is a very efficient cpu. As a result the temperatures are alot lower on the Q9450 when running all four cores - so less complicated cooling is required.
