Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Thread: ThermalTake Super Typhoon
    c[_]
    Nov 2002
    Alberta, Canada
    Didnt feel like working on my P5K Deluxe today so I worked on another project that i've been meaning to get to for a few months...
    Still not done yet... may be able to finish tomorrow if I can find all the stuff I need. Fan placement isnt finalized. These heatsinks sure soak up the heat. I had a hard time soldering/unsoldering with a big butane torch...
    EDIT
    Also if you're looking at these pics and thinking you'll realize a TT-BT would make a great video card heatsink just by changing all the heatpipes onto one side then bending them
ID:	70361   Click image for larger version.
ID:	70362   Click image for larger version.
ID:	70363   Click image for larger version.
    All along the watchtower the watchmen watch the eternal return.
    Dec 2007
    That's freakin' sweet. And kinda ghetto.
    Aug 2007
    Humble, Texas
    looks kinda cool.
    does it work though?
    will it fit in a case as well?
    and how will you mount it?
    Little Mean Red Machine:
    2008 Saturn Astra XR|Salsa Red|2dr Hatchback|1.8L 140HP 4cyl|5-Speed FWD
    Main Box:
    ABIT IP-35Pro XE|Intel C2Q 3.2GHz|Zalman 9900|4GB Corsair Dom. DDR21066|ATI 5770 |SB X-Fi XM|2x W.D.V.R. 300GB RAID 0|S.B. 320GB|2x TSSCORP SH-S223B|Antec P193|Antec TPQ 850W|2x Samsung SyncMaster P2350 HD 1080P|G15|MX1000&G5|Win7 RTM Pro X64
    Spare Box:
    ABIT IC7-G MaxII|Intel P4 3.2GHz|Zalman 7700CNPS-C|2GB OCZ HP DDR400|ATI 9800XT|W.D.C. 40GB|W.D.C. 250gb|Antec
    Neo480|WinXP Pro SP3
    Admin
    Feb 2005
    Ann Arbor, MI
    Hope you got before temps for a comparison
    Apr 2007
    Innovative and CRAZY!
    ʇɐɥʇ ǝʞıl pɐǝɥ ɹnoʎ ƃuıuɹnʇ ǝq ʇ,uop
    May 2007
    That must be very heavy. Looks like it will work quite well. Not pretty but it's performance that matters.
    i5 2500K @ 4.7ghz 1.32v(+.010 offset LLC set to 4) / ASRock P67 Extreme4 (B3) / 2x4gb Samsung Green MV-3V4G3D @ 1866mhz 1.35v / AMD HD 6850 1gb /2x150gb Velociraptor Raid 0 + 500gb WD Green / Corsair TX 750watt V2
    c[_]
    Nov 2002
    Alberta, Canada
    Lunchbox - Stock mounting should work for 775 still, which is what i'll be using it for. I'll measure to be sure later. If not i'll just get longer bolts than what it came with.
    Vapor - Havent used the one since I got rid of my old Opteron 165 last xmas.. other has been in a box new since then as well lol...
    Grips - If I have what I need tomorrow it will look a lot better and should pick up some more performance as well. A stock TT-BT would benefit from what i've got planned.
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    there's something about all those pipes and fins, all that cooling power, man that is a MAN's cooler
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
    Dec 2007
    Austintown, OH
    Nice!!!!
    Quote Originally Posted by twilyth View Post
    Welcome Mr. Bugger. Agreed - 2 out of 3 are no-baggers.
    Jun 2007
    Nice air coolers
    Jun 2006
    Can't wait to find out what temps you get.
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    Can't wait to see what you come up with in terms of mounting. Truly excellent so far STEvil, well done.
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
    Aug 2007
    Cumming, IA
    Awesome idea man.
    PS:why are you drinking such crappy beer? Especially in Canda?
    XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
    Xtreme Cruncher
    Sep 2007
    PA, USA
    looks cool. hope it doesnt break the board
    XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
    XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
    Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
    silverstone tj07 build log
    Oct 2007
    Bay Area
    That looks extremely heavy. I wonder how it will perform.
    Oct 2005
    Italy
    That makes about one square mile of dissipating surface
    Thermaltake Xaser V8000A * Enermax EG701AX-VH Coolergiant 600W * DFI LanParty nF4 Ultra-D AD0 * AMD Opteron 165 Denmark * 2x1024 MB OCZ PC3200 EL Platinum XTC * Sapphire Radeon X1900 XT 256 MB * Western Digital WD740ADFD, WD2500KS and WD5000AAKS * Creative X-Fi XtremeMusic * NEC ND-4571A * Dell 2709W * APC Smart-UPS 1000 VA
    Xtreme Mentor
    Feb 2004
    The Netherlands
    don't think the sandwiching will help any, but it sure will look awesome
    http://www.xtremesystems.org/forums/...d.php?t=119747
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
  18. #18
    Mar 2005
    Ontario, Canada
    Nice, the termps should be good.I did that once with 2 xp120s giving 10 heatpipes. you did a mudh cleaner job. I still use it with a 940 oced to 5G.
    http://entertainment.webshots.com/ph...67863468sXjclI
    http://entertainment.webshots.com/ph...67863468QDBbXK
    Rampage III Gene I7 950@4.48G--1.485V HR-02 12G G.Skill 1600-1.5V, GTX470-SLI@725core 1750mem, Antec P180 MINI
  19. #19
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    STEvil that thing is freaking awesome and innovative..
    what sort of temps are you getting with that cpu cooler ???
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
  20. #20
    Dec 2006
    Falkenberg, Sweden
    Best mod I have seen in quite some time! Know get that beast mounted, and tested! Lots of pic&#180;s would be nice to. Great work!
    AMD
    955BE, 720BE & Athlon II 250
    Gigabyte 790FXT-UD5P F5 Bios
    Crucial Value 2*1Gb D9 JNM
    XFX 4770
    Seventeam 650w
  21. #21
    Xtreme Cruncher
    Jan 2005
    England
    wow, cant wait to see some temps
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
  22. #22
    c[_]
    Nov 2002
    Alberta, Canada
    Dont have the stuff on hand to finish it off today...
    Fujimtsu - Those would be my brothers' cans.. that shop is party central every weekend.. lol.
  23. #23
    c[_]
    Nov 2002
    Alberta, Canada
    Bad news, cant get what I need fast so its going to be a while unless I choose to lower my standards.....
  24. #24
    Xtreme Family
    Dec 2004
    Republic of Hiroshima
    ouch!!! 1500gr of massive cooling
    Great start, thread subscribed !
    Mojo
    Family
    Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
    Criminal
    Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
    Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
    Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
    Kids
    P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
  25. #25
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    i have a bigtyphoon not used here, i might bend it the way shown in thread #17 and use it on my 8800GT,
    any tips about how to bend the heatpipes without breaking them ?
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
