It is now being voiced about that Vmem beyond 2.2 volts when using phenom processor can possibly damage the internal memory controller and what that may lead to is yet unknown.
Back and forth from board to board it seems.
how does the Vmem have anything to do with the memory controller? more info please?
Memory controller is in cpu and all you have to do is harken back to the days when high memory voltage on athlon 64 cpu could damage the internal memory controller and it seems similar is afoot now and that voltage appears to be 2.2 on the memory with phenom processor with internal memory controller.
Memory controller is on the CPU. Vmem is regulated by the motherboard. Memory controller voltage is a function of Vcore, not Vmem. I'm not saying you're wrong, I just want to see evidence...
RGone i thought this was problem when running bh5 @3.3v or more, you had to run your cpu @1.4v to be safe
Amd Nvidia/Ati -3dmark06 scorebord revisted
asus L1N64-ws or /b depending on bios chip
4x1gig 8500 gkill bpk
2x opteron 8224 @ 3.8ghz
http://www.xtremesystems.org/forums/...&postcount=236
vga= 8800gt
winxp pro
custom chiller -31 water
2x dtek fuzions
bix3-with x3panaflo hi output
antec 850 quattro
heat under msimax abitmax and dfimax
It's been said that RGone is correct.
I'd love for that to be incorrect though.
RGone, when are we gonna see alot of DFI/790 boards available?
Availability is abysmal
Zen2 Has brought AMD back!
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
split power plane on RD790 board...![]()
what happened back in K8 days? im still here!
runing 1.45 on vcore, 2.9v on mem, 4 sticks of 512
Intel Q6600 (Stock for now)
Scythe Infinity
XFX 680i LT
OCZ 2 x 2GB Platinum DDR2 800
EVGA 8800GTS 640MB
Ultra Aluminus
Mushkin 650watt SLI
Seagate 500gb
Seagate 250gb
DVD Rom/Burner
maybe Tony's theory is rubbish if you haven't killed the chip yet lol![]()
I've ran 2.2V very consistent so far (what my RAM is rated for) and 2.3V on the odd occassion. No problems since 12th Nov.
It's not Tony's fault.He just passed some informations he thought were eleveant to future Phenom owners.BTW,every K8 &10 CPU has-built in over-voltage protection which in turn can fail..We need more examples of failures in these circuits(and as effect burned/dead Phenoms).
guys
If you want to kill the memory controller on your Phenom run 2.3V...its as simple as that.
Remember im not quoting the one or two it may or may not happen too...im quoting from advice i have heard from many people now who are telling me its VERY dangerous.
Im not bothered personally if you kill your CPU or your ram if something happens in the CPU that causes the memory to die...in the end its your CPU to kill and i respect that.
I already know this theory has been tested and the CPU did die...2.4V was the vmem.
So...its upto you
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Some people need to learn those things the hard way![]()
Tony maybe there is more to it than just high vdimm and low vcore
if not why are these systems still alive after all this time then??
mabye amds 65nm fab process is the one to blame?
when they still have problems with the process, i think it would be possible to see cpus/imc that are very voltage resistant and others that die just when you increase the voltage a bit above the recommended settings.
What is the title of this thread...does it say high vmem kills Brisbane?
K10 is a whole new architecture...remember that part.
There is 1 huge plus point here. K10 controlls memory a lot better than K8, as bios matures you will see.
Also clocks needing 2.4v on K8 don't need 2.4V on k10, in some cases huge drops in vmem will still work.
Tony AKA BigToe
Sheesh.............this just keeps getting better and better![]()
SuperMicro X8SAX
Xeon 5620
12GB - Crucial ECC DDR3 1333
Intel 520 180GB Cherryville
Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
I'm happy with that...
What Tony says is absolutely true! Mem controller in K10 is way better compared to K8. My Ballistix is working flawlessly with 2.25V @1000MHz 4-4-4 timings. On K8 it needed 2.42V and it wasn't completely stable ...
If increasing NB voltage will mitigate risk of breaking CPU with over 2.2VDIMM then it's OK and most affected are AM2+ board owners (due to 1.1V NB power plane).
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55''Samsung LED 3D TV
