Guys this is most important
If you run a high vdimm and a low vcore with E die etc you are running the risk of killing the cpu's. So if you have VX etc and you are not raising the vcore on your cpu you stand a chance of pumping a lot of current into the memory controller and causing permenant damage.
Im seeing people running $1k cpu's at default vcore and BH5 at 3.4V, this is a sure way to kill the cpu and is NOTHING to do with an issue on the board. If you are going to run high vdimm run a higher vcore also, and keep your CPU's ok.
