Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: QX9650 L739A644 + Blitz Extreme
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Cool QX9650 L739A644 + Blitz Extreme / X38-DQ6
    Look what arrived on a weekend (weird USPS EMS delivered to me on a Saturday! )
    Closest batches I can find are
    Memory Addict
    Aug 2002
    Brisbane, Australia
    System:
    • Intel Core 2 Extreme QX9650 L739A644 retail
    • CPU cooling = Swiftech G4 Storm/Thermochill 120.3/MCP655
    • NB chipset cooling = Radiical Chipset Block/Corsair Cool single 120mm fan Rad/MCP350
    • Asus Blitz Extreme 0804 bios
    • 128MB Gainward FX5200 PCI
    • 2x1GB OCZ PC3-14400 Platinum - DDR3-1800 rated at 8-8-8-27 at 1.9v
    • 500GB Seagate 7200.10 SATA on SATA1 Port
    • LiteOn 165H DVD Burner
    • Sony FDD
    • 1KW OCZ ProXStream
    • WinXP Pro SP2
    Coretemp 0.954 doesn't read the QX9650 VID properly but on AUTO vcore, bios reports 1.208v idle vcore and when I set vcore manually to 1.2375v vcore, bios reports 1.208v vcore as well. So VID probably = 1.2375v
    Just in time that CPUZ v1.42 came out
    I tried v1.42 with QX9650 L739A644 retail + Asus Blitz Extreme + 0904 bios but v1.42 picks up 1T CMD as 2T but v1.41 picks up CMD correctly as 1T heh
    cpuz v1.42 dump file here
    cpuz v1.41 dump file here
    Memory Addict
    Aug 2002
    Brisbane, Australia
    QX9650 @4005Mhz
    Needed 1.376v to boot into windows @4005Mhz but to complete Systool Quad 16M Pi test, needed 1.392v vcore (1.425v bios set). Also seems I've having some stability issues not sure if it's cpu, board or the new 0904 bios but at 4005Mhz at 1.392-1.400v vcore I managed to complete 32M run but after a few moments it rebooted the system. Haven't had this kind of instability in a long time - i.e. pass Super Pi 32M but reboot afterwards ? More investigating into bios settings is needed I guess
    For now here's the Super Pi 32M run - which is a good 40-50 seconds faster than equivalent Conroe/Kentsfield time at 4005Mhz 9x445FSB 1:2 DDR3-1781Mhz 7-6-5-18 1T !
    Anyone else running QX9650 on Blitz Extreme ???
    Memory Addict
    Aug 2002
    Brisbane, Australia
    reserved #1
    Memory Addict
    Aug 2002
    Brisbane, Australia
    reserved #2
    Moderator
    Nov 2006
    waiting for your test eve2000
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Xtreme Family
    Dec 2004
    Republic of Hiroshima
    reserved #3
    Well im not using an Extreme but with the Blitz Formula i have no issues for 4ghz @ 1.38v,its stable enough for Crysis and heavy benching.
    Mojo
    Family
    Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
    Criminal
    Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
    Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
    Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
    Kids
    P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
    May 2007
    Very nice results.
    It must just be my crap Gigabyte P35-DQ6, but I have to push 1.5875v to just get 3800MHz. Q6700 can't do 4000MHz.
    But on topic, nice stuff!
    Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
    Jul 2007
    Quote Originally Posted by MuffinFlavored View Post
    Very nice results.
    This is a Yorkfieldthey need less voltage then the Kentsfield
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by hiwa View Post
    slowly they will come
    Quote Originally Posted by PcCI2iminal View Post
    reserved #3
    hehe was that on air or water ?
    right now this QX9650 L739A644 needs 1.376v to boot 4005mhz but only semi stable with reboots at 4005mhz at 1.392-1.408v vcore on water cooling.. any lower vcore = BSOD heh
    But it could be Blitz Extreme issue as my Q6600 L725A903 needed 1.432v for 3600Mhz prime95 on water while same cpu on Blitz Formula did 1.408v for 3600Mhz prime95 on air heh.
    Very nice results.
    alot of factors i guess... could be vcore droop in your case and/or heat
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    George wont sleep for days now with the new processor
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    George,
    Congrats on the QX. You may find this kind of crazy, but I think you are having stability issues because of your FSB. My findings have always led me to stability issues whenever FSB was near 445, 450.... I cannot even boot Windows after 450 FSB, 455+ it will freeze at post. So, FSB has been a huge limiting factor for air/water on these QX's. Just a little FYI from my personal experience.
    Try 10 X 400 with 1.3625 (bios selected) vcore and if you have ample air cooling capacity I am pretty sure you should be quad prime stable set to (12meg cache setting in multiprime).
    I know, because you are raising the multi, bus speed and ram will be slower. But I see you are running CAS7 6-6 on those sticks. To combat this I have found the best setting on a 4.0 Ghz overclock for me was:
    10 X 400 , 1.3625 Vcore bios selected (1.31 after vdroop)
    Ram at 1600 mhz, Timings: 6-5-5-18 (2.05v , 1T)
    As you can see, even though you are lowering FSB, you still have the ability to run CAS6 and tighter timings + I am pretty sure you will be able to achieve 4.0 GHz low volts stability.
    Let me know of any results.
    SVTSnake.com Head Honcho
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by FUGGER View Post
    hehe looks that way
    Quote Originally Posted by dominick32 View Post
    George,
    Yeah been testing 10x multi and you're probably spot on 10x400FSB more stable than 9x445FSB at same 1.400-1.408v vcore. But still no boot until 1.376v for 4ghz regardless of FSB used.
    But seems >4Ghz is looking closer to other QX9650 now.. i.e. 4152Mhz at 1.448v load for quad 16M systool Pi test looping several loops.. 4184Mhz at 1.448v passed one loop of quad 16M systool Pi test before rebooting heh.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    I like to use Systool Quad 16M Pi test to find my feet with a new cpu (benchmarking -> cpu -> select 16M Pi test and check 4 threads box). Quad 16M Pi test uses ~1.2-1.3GB of memory, so you can't run Quad 32M Pi Systool test as it uses 2.6+ GB memory and for 32bit OS it will give you out of memory even if you have 4GB memory installed.
    Systool Quad 16M Pi test scaling looks like this so far:
    • 4005Mhz at 1.4375v bios set -> 1.408v idle/load
    • 4137Mhz at 1.4750v bios set -> 1.448v idle/1.440v load
    • 4152Mhz at 1.4875v bios set -> 1.456v-1.464v idle / 1.448v load
    • 4180Mhz at 1.5000v bios set -> 1.472v idle / 1.464v load
    • 4200Mhz at 1.5375v bios set -> 1.512v idle / 1.508v load
    10min @4005Mhz at 1.392v load
    Systool Quad 16M Pi pass at 1.508v load
    (don't mind the times as i ran at 1:1 divider heh)
    Load
    Complete
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    wow im pretty surprised how cool your cpu runs under load seems like a killer chip
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Coretemp 0.95.4 isn't correct Coretemp 0.95.6 beta i just started to test shows closer load/idle temps to everest OSD report in screenshots heh
    Coretemp 0.95.4 is about 5C under reported from Coretemp 0.95.6 beta.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Can now confirm, 9x445FSB instability wasn't related to FSB but related to lack of vcore as I bumped vcore right up and have no instability issues at 9x467FSB with Quad 16M Pi Systool test.
    9x470FSB with CPU PLL = 1.50v
  18. #18
    Banned
    Sep 2006
    Where download Coretemp 0.95.6 beta?
    By
  19. #19
    Memory Addict
    Aug 2002
    Brisbane, Australia
    coretemp author is going giving it out via email requests so will ask if it's okay to share
    Well either I have Asus Blitz Extreme 0904 bios issues or I probably have a below average QX9650 as I can't even complete 1M @11x400FSB = 4400Mhz at 1.65v bios (1.608v load) - half way through 1M Super Pi run it reboots heh.
    Might have to move QX9650 cpu to my Asus Blitz Formula to see what's up.
  20. #20
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    nice review Geroge. lol
    but poor chip
    Uni Hardware:
    http://www.unihw.com
    Team China
  21. #21
    Nov 2005
    Germany
    i had same problem with a QX9650 ES on Blitz Formula & Maximus Formula
    I think it is the CPU
  22. #22
    Banned
    Sep 2006
    Quote Originally Posted by eva2000 View Post
    Ok For coretemp
  23. #23
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Chri$ch View Post
    Yeah it's looking like it's cpu
    Asus Blitz Formula 1205 bios blashed, same QX9650 needs 1.408v to get into windows air cooled. 1.35v bios reboots before getting into windows.
  24. #24
    Xtreme Mentor
    Jun 2002
    You have the exact same batch # as I do.
    EDIT: sorry mines the 664 one, not 644.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
  25. #25
    Memory Addict
    Aug 2002
    Brisbane, Australia
    xgman, how's you cpu doing?
