XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme 3D Team
Reply
Old 11-20-2007, 01:25 AM   #1
The Stilt
Xtreme Legend
The Stilt's Avatar
Unleash the Gladiator (RV670): 862MHz GPU Clock Limit Fixed
As some of you may have noticed there is a strange limit in GPU frequency on RV670 based card.
The maximum stable frequency seems to be around... exactly at 862MHz...
I have seen some wild speculation about a driver problem or a GPU limitation.
All wrong.
Lets put it this way:
There is a mean bouncer standing outside of your favorite bar (863MHz).
Bouncerīs name: is PLL VCO Divider
The frequency of GPU internal PLLs are changing with GPU frequency.
At certain points the PLL must change itīs divider to maintain the frequency at correct range.
If the divider is not changing for some reason the frequency of the PLL will raise too high and it will flip.
This is what happening at 862MHz.
It is pretty much the same thing on cars.
To reach higher speeds you need to put in a bigger gear.
The problem can be easily fixed by updating the new bios.
Unfortunately I donīt have a bios for HD 3850 cards, but it should also be available soon.
HD 3870 PLL VCO Fixed Bios v010.071
The Stilt is offline   Reply With Quote
Old 11-20-2007, 01:30 AM   #2
Fr3ak
OC Jedi
Fr3ak's Avatar
Send a message via ICQ to Fr3ak Send a message via MSN to Fr3ak
Great find! You are a genius
I can send you a 3850 BIOS if that helps you.
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
Fr3ak is offline   Reply With Quote
Old 11-20-2007, 01:33 AM   #3
The Stilt
Xtreme Legend
The Stilt's Avatar
The problem was fixed by AMD graphics department, not by me
Old 11-20-2007, 01:41 AM   #4
SF3D
HWbot Crew / X.I.P.
SF3D's Avatar
Great find and thanks for sharing this information.
P.S Missäs mahtaa olla minun XFX680i?
__________________
AOCC2008 WW #5, MOA2008 EU #5, GOOC2008 WW #1, GOOC2009 WW #3, MOA2009 EU #4, MOA2009 WW #4, GB TweaKing #"5" (4,10), Ditech International OC #2 / #2, ASUS ROG OC Showdown # semifinals
SF3D is offline   Reply With Quote
Old 11-20-2007, 01:47 AM   #5
Fr3ak
OC Jedi
Fr3ak's Avatar
Thank you for posting anyway
I just didnt think AMD would fix something that helps us to overclock their cards better
__________________
オタク
Old 11-20-2007, 01:49 AM   #6
Sampsa
Xtreme Legend
Sampsa's Avatar
Great! Now I just need my Radeon HD 3870s
__________________
Favourite game: 3DMark
Work: Muropaketti.com - Finnish hardware site
Hobby: overclocking.fi - Extreme overclocking: Team Finland
Sampsa is offline   Reply With Quote
Old 11-20-2007, 02:33 AM   #7
Cooper
Xtreme Workhorse
Cooper's Avatar
Now we need to have proper BIOS flashing tool
Cooper is offline   Reply With Quote
Old 11-20-2007, 02:36 AM   #8
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
OMG now I'm looking forward to O/C results.
__________________
IntelŪ Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is offline   Reply With Quote
Old 11-20-2007, 03:02 AM   #9
G H Z
Champion
G H Z's Avatar
Great work Stilt
Now if they could just fix the 1143MHz memory limit (2900's) as well.
G H Z is offline   Reply With Quote
Old 11-20-2007, 03:04 AM   #10
Jupiler
Administrator
Jupiler's Avatar
As Cooper asked, which flashing tool can be used for this card?
Might be usefull for current (and future) 3870 owners, so that they don't use the wrong tool and possibly destroy their cards.
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman View Post
I've got Supermicro boards that lasted longer than one of my marriages!
Jupiler is offline   Reply With Quote
Old 11-20-2007, 03:04 AM   #11
LowRun
LowRun's Avatar
This is very good news, thank you The Stilt
Can't wait to see some updated OC results.
LowRun is offline   Reply With Quote
Old 11-20-2007, 04:19 AM   #12
Miwo
Miwo's Avatar
Send a message via AIM to Miwo
This is great news to wake up to.
When I get home from work today, I will flash my 3870 with this BIOS (which tool to use right now?). I got my card yesterday, and the first thing I did was replace the Stock Cooler with an Accelero S1, and strapped a 140mm Yate Loon to it. I've been running RTHDRIBL overnight at 857/1200 MHz, and my Load Temperatures are 40C with this cooler. Will post more pics and results after I get back from work today
__________________
AMD Rig
720BE @ 3.65GHz 1.43v / MSI GD70 / 4GB OCZ Animal DDR3 / vModded 4850 @ 800/1050
Coolermaster CM690 + Z600 Cooler / Corsair 620HX / Dell Perc 5i + 4x32GB JMicron MLC SSD / 1TB WD Black
Intel Rig
E8300 / DX38BT / 4GB DDR3 / HD3850 / 3x 7200.10 Matrix Raid / Sonata III / Earthwatts 500W
Audio / Video
Samsung 37" 1080p LN37A550
Source: HT Omega Claro, Coax out to Denon (multichannel), SPDIF to Zero DAC (stereo)
Receivers: Denon AVR-788, Sony STR-GX900ES
Speakers: KEF IQ3s + KEF Q8S(surround duty)
LFE: Energy S10.3, 2x Aura Pro Bass Shakers mounted on my office chair
Miwo is offline   Reply With Quote
Old 11-20-2007, 04:52 AM   #13
HousERaT
HousERaT's Avatar
Now, let's see how high these things can clock.
__________________
The little air system that could.
HousERaT is offline   Reply With Quote
Old 11-20-2007, 05:26 AM   #14
Spuggi
Spuggi's Avatar
Send a message via ICQ to Spuggi Send a message via MSN to Spuggi Send a message via Skype™ to Spuggi
tried to flash with winflash from bartpe disk an atiflash in dos from bootdisk, winflash says "no ati gfx detected" and atiflash says "ERROR 0FL01 ADAPTER NOT FOUND"
So any ideo how to flash the damn bios?
__________________
SF Solutions
Spuggi is offline   Reply With Quote
Old 11-20-2007, 05:27 AM   #15
SKYMTL
SKYMTL's Avatar
Send a message via MSN to SKYMTL
Like has already been mentioned; posting the BIOS is one thing but actually flashing the card is another.
So many responses and a BIOS flash tool has not been posted.
SKYMTL is offline   Reply With Quote
Old 11-20-2007, 05:29 AM   #16
Spuggi
Spuggi's Avatar
It was worth a try, so we know it won't work with atiflash and winatiflash :P
__________________
SF Solutions
Old 11-20-2007, 05:36 AM   #17
STaRGaZeR
Xtreme Mentor
STaRGaZeR's Avatar
Yeah, where is that utility
__________________
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
STaRGaZeR is offline   Reply With Quote
Old 11-20-2007, 05:47 AM   #18
Miwo
Miwo's Avatar
Just curious, but what version of ATI Winflash / ATIFlash did you try to use? http://www.techpowerup.com/downloads..._Flashing/ATI/ has versions dated 9/10/2007, Winflash 1.26.1 and ATIFlash 3.43.
The versions linked to in the bios flashing thread in the mods section here seem to be a lot older
__________________
AMD Rig
Intel Rig
Audio / Video
Old 11-20-2007, 05:49 AM   #19
SKYMTL
SKYMTL's Avatar
I don't think the Techpowerup version is set up to detect the RV670-based cards.
The best thing to do is to go through DOS IMO....
Old 11-20-2007, 05:53 AM   #20
Spuggi
Spuggi's Avatar
hiho,
i tried atiflash 3.43 from dos boot cd, getting the error, now i'll try the newer winflash version, but i don't think it'll work
__________________
SF Solutions
Old 11-20-2007, 05:56 AM   #21
SKYMTL
SKYMTL's Avatar
Funny....BIOS posted....no way to get it to work. So close, yet so far away. :P
Old 11-20-2007, 05:57 AM   #22
Spuggi
Spuggi's Avatar
Ok, newest Winflash also not working ^^
__________________
SF Solutions
Old 11-20-2007, 05:59 AM   #23
The Stilt
Xtreme Legend
The Stilt's Avatar
I will upload the flasher as soon as I have the green light...
Old 11-20-2007, 05:59 AM   #24
SKYMTL
SKYMTL's Avatar
Looks like we will need updated software then. Are you under XP or Vista?
Maybe you should have waited to post the BIOS then too? You got all our hopes up.
Old 11-20-2007, 06:00 AM   #25
Spuggi
Spuggi's Avatar
look above your post
i use xp
__________________
SF Solutions
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
