http://www.bfgtech.com/bfgr88640gtseeoce.aspx
Don't know if this has been said yet.
Specs Bellow
BFG NVIDIA GeForce 8800 GTS EE OC 640MB PCIe
Performance
GPU NVIDIA GeForce 8800 GTS
Core Clock 565MHz (vs. 500MHz standard)
Shader Clock 1300MHz (vs. 1200MHz standard)
Stream Processors 112
Memory
Video Memory 640MB
Memory Type GDDR3
Memory Data Rate 1700MHz (vs. 1600MHz standard)
Memory Bandwidth 68GB/sec.
Connections
Bus Type PCI Express x16
Connector(s) 2 Dual-Link DVI-I, VGA, HDTV + TV Out
Multiple Monitor Support Yes
HDCP Yes (Requires other compatible components which are HDCP capable. Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays)
RAMDACs Dual 400MHz
Included In Box
> BFG NVIDIA GeForce 8800 GTS EE OC 640MB graphics card
> Quick install guide
> Two DVI to VGA adapters
> Dual 4-pin Molex to single 6-pin PCI Express power adapter
> HDTV dongle
> Driver CD, which includes: NVIDIA ForceWare unified graphics drivers and Full installation manual .pdf
Minimum System Requirements
> 1GB of system memory
> Microsoft Windows Vista -or- Windows XP
> CD or DVD-ROM drive
> 50MB of available hard disk drive space for basic driver installation
> 425W ATX 2.2 or greater system power supply with a combined 12V current rating of 28A or more (Minimum system power requirement based on a standard PC configured with an Intel® Core™2 Extreme X6800 processor)
> PCI Express-compliant motherboard with one vacant PCI Express x16 slot. Two vacant slots below the PCI Express x16 slot. This graphics card physically occupies two slots and requires one open slot in addition to ensure proper airflow and cooling
> One 6-pin PCI Express supplementary power connector -or- Two 4-pin Molex power connectors
