Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 123
Thread: Phenom X4 vs. Yorkfield tested in Crysis
    Banned
    Jul 2004
    The battle begins
    Expreview has managed to get their hand on an AMD Phenom X4 and an Intel Yorkfield based QX9650 and have run the two against eachother in Crysis to see which chip is the better one.
    Also thrown in for comparison was an Intel Core 2 Duo E6850 and a Core 2 Extreme QX6850. As you might have already realised, the Intel chips are clocked a fair bit higher than the Phenom X4, so to make things a bit more even, the Phenom X4 was overclocked to 3GHz.
    This is still not quite a fair comparison, as the Phenom X4 had it's memory running at 375MHz due to limitations of AMD's integrated memory controller which prevented it to run at 400MHz as per the Intel based test systems. The Phenom X4 system also had a lower bus speed, due to Intel's move to 1,333MHz bus.
    The Phenom X4 was tested using an RD790 board while the Intel CPU's were tested on a P35 based board. The graphics card used wan an 8800 GTX and the test results are looking quite promising for AMD, at least if the Phenom X4's will retail below Intel's asking price. The only problem is that the Core 2 Duo E6850 seemed to outperform it.
    The Crysis time demo was run 5 times and Expreview took the average of those runs, with the Phenom X4 scoring an average 46.48fps while the QX9650 managed 49.95fps. The Core 2 Duo E6850 scored an average of 49.19fps while the Core 2 Extreme QX6850 managed 49.92.
    http://www.fudzilla.com/index.php?op...=3882&Itemid=1
    Xtreme Mentor
    May 2007
    That's not quad optimized at all. No gain at all between 3x 3GHz CPUs.
    Banned
    Jul 2004
    Quote Originally Posted by KTE View Post
    Hopefully it's just the demo that is not optimized for multicore or else I'm going back to dual
    Xtreme Mentor
    May 2007
    I was thinking of buying a Penryn quad or Phenom quad in 2 or so months and that shows nothing worth considering.
    Did you see the CPU-Z voltages?
    ES QX9650 @ 1.248
    G0 QX6850 @ 1.328
    E0 E6850 @ 1.248
    B2 X4 @ 1.536
    Those are high volts for 3GHz X4 if true but another thing I noticed again is, some of the guys who are getting QX9650 ES to test on stage from Intel like Fugger are not getting those same chips but maybe handpicked onces. They are getting the stock 1.1V QX9650 while this is the 3rd person I've seen with stock 1.248V QX9650.
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Dual Core is much better at gaming contrary to what they say the game will be optimized for
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Fused
    Dec 2003
    Malaysia
    25Mhz less on memory
    2clock loosen on tRP
    1.6GHz NB Speed
    There is still headroom for PhenomB2 to perform on that test..
    Banned
    Aug 2007
    the tests clearly show it's gfx depended.
    Oct 2007
    Quote Originally Posted by MR_SmartAss View Post
    Do you really believe that a K10 running the RAM 5%-10% faster and the NB 10%-20% faster would match Kentsfield's performance?
    You're forgetting that when the final release of Crysis hits the shelves, theres a strong possibility the game utilises all 4 cores of the CPU
    Jun 2006
    Portugal
    You may believe it or not, but it seems you already know the answer, right?
    I´m convinced of one thing, IF Phenom cannot beat Yorkfield (and i agree that, at the moment, it is the most plausible assumption)
    it will be cheaper, so no matter what, good news are coming along
    Sorry for my poor english.
    Mar 2005
    Most of you failed to see one very important thing: Minimum fps of phenom is only 8.28
    Every other cpu get a minimum fps of around 30
    That mean they tested Phenom diferently.
    There is no way a cpu will provide 3x better minimum fps.
    Banned
    Aug 2007
    Quote Originally Posted by tictac View Post
    1.6GHz NB Speed
    And tras is much higher and while they were comparing, why not run the phenom at 9*333 to make it a head to head comparison.
    From what i can see now, the QX9650 is worthless for upgrade.
    Apr 2007
    So the winner will be decided by overclocking and price. One which overclocks better, or is cheaper, will be the winner.
    Banned
    Aug 2007
    Quote Originally Posted by Calmatory View Post
    cheaper has always been the winner.
    What AMD could do as a favour is stock multi +1 extra unlocked, that would make things crazy
    Jul 2007
    I think this proves that Amd are still in with a fight, i think that wasnt a good test personally... would of been better to test using 3dmark06!! showing off what native quad core can do..
    I think people will be pleasently supprised by Amd's Phenoms and RD790 mix
    CPU: Intel Q6600 @ 3600Mhz 24/7
    GFX: eVGA 8800GTS SSC 512MB
    RAM: 4GB Corsair Dominator PC2-8500
    MB: DFI LP LT X48-T2R
    HDD:150GB WD Raptor X
    PSU: Thermaltake Toughpower 1000W
    Screen: Dell 2407WFP
    Banned
    Aug 2007
    3D Mark doesn't shows anything at all. It is a pure synthetic benchmark and IT IS NOT optimized for 4 cores. Even if the so called "native" core is perfect, 3D Mark would make it looks poor. Check out some 3D Mark 2006 scores.
    Yes show me those Phenom X4 on RD790 3dmark06 scores, don't worry i can wait for a few minutes.
    Oct 2007
    even if AMD gets within 10% of Intel, I will be happy. So far, its looking promising
    Aug 2007
    Warren,MI
    Quote Originally Posted by boban10 View Post
    must be there is something wrong with those tests, i am going to call a minor fake here, since now a days only people who can run real truthful test are on here.
    cpu- Intel I7 3930K
    Asus P9x79 Deluxe
    2x HD7970
    32gb ddr3-1600
    corsair ax1200
    Corsair 800D
    Corsair H100 lapped
    2x 128gb M4 raid 0
  18. #18
    D.F.I Pimp Daddy
    Jan 2007
    Bleh....I will be going Back to AMD for some Real Love on the Memory deal and I am quite sure that Phenom will be equal / better that whats here now AMD just runs so much smoother.
    SuperMicro X8SAX
    Xeon 5620
  19. #19
    Banned
    Aug 2007
    Quote Originally Posted by knightwolf654 View Post
    I've just read that the bench is utilising only 1 core
    So far the credibility of this bench and thread.
    core1:[------------------------------------------------------------90% ]
    core2:[---5% ]
    core3:[--3% ]
    core4:[----5% ]
  20. #20
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Does the bus really matter for AMD?
    wouldnt... say... 200*12 perform the same as 266*9 as long as the RAM is performing at a similar level? The HT bus isnt even close to being filled, so it doesnt matter if its running at say... 1.6 or 1.2GHz
    Seeing as the AMD is overclocked and the Intel is at stock, thats a bit of a downer.
    you sigged that?
    why?
    ______
  21. #21
    Fused
    Dec 2003
    Malaysia
    that indicate that phenom b2 can go higher than 3ghz.. ?
  22. #22
    Xtreme Mentor
    Apr 2005
    it's ridiculous to run memory on 750 MHz, when this CPU can use 1066 MHz DDR2 that could work @ 1000 MHz (3000/6)!
    Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
  23. #23
    Banned
    Aug 2007
    I think they haven't properly tested at all, no info on cooling used, and probably they just pushed 1.55v trough it to make sure it runs 3ghz..
    I think this step will run much higher
  24. #24
    Xtreme Cruncher
    Sep 2007
    PA, USA
    Quote Originally Posted by BeardyMan View Post
    i was thinking that too.
    XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
    XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
    Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
    silverstone tj07 build log
  25. #25
    Banned
    Nov 2006
    Ive given up on AMD.
    Phenom should have been out 2 months ago, a month ago, today.
    Performance is not looking to promising, the darkside is looking tempting.
