Results 1 to 25 of 183
Thread: Cascade 5 (2 Stage GPU)
Threaded View
    -100c Club Member
    Jul 2005
    England
    cascade 5 GPU
    First stage
    compressor: LG NJ362 R-407C i will also testing a PG130XIT-4CRE 8000btu for future use on this stage
    Hx: 12 plate
    Danfoss tev: Tes2 00 orifice
    Receiver: RLV 02 PED 77*220 V=0,88l
    Condenser: 1,10kW
    in line filter 1/4 flare
    High pressure gauge
    water cooled DSH
    The copper pipe sizes used in this stage are
    1/4 inch used on the expansion valve suction sensor to the suction return
    5/16 compressor to the condenser and receiver
    3/8 used on the run from the receiver to the expansion valve and HX suction return
    1/2 used on the expansion valve to HX
    Fittings
    1x 5/16 straight
    1x 5/16 tee
    2x 3/8 tee
    1x 3/8 elbow
    1x 1/2 elbow
    2x 3/8 flare nut
    1x 1/4 flare nut
    1x sevice port
    second stage
    compressor: PG130XIT-4CRE 8000btu
    Oil separator: temprite 900
    danfoss high pressure cut off KP 5
    cold ice mini condenser
    cold ice pressure relief valve 24 bar
    High pressure gauge
    spun drier/filter
    Chilly type evap with one extra turn
    1m braided suction return
    refrigerant: R507/R23 for tests with PG130XIT-4CRE 8000btu on 1st stage
    then R507/R1150 when the LG NJ282P R goes in
    the unit will also have shut off hand valves located on the suction return and cap tube for easy change of evaporators and setups
    there will be no case for this unit
    the other units
    cascade 1 http://www.xtremesystems.org/forums/...d.php?t=143340
    cascade 2 http://www.xtremesystems.org/forums/...d.php?t=105549
    cascade 3 http://www.xtremesystems.org/forums/...d.php?t=117279
    cascade 4 http://www.xtremesystems.org/forums/...d.php?t=126920
