XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 07-09-2007, 03:28 AM   #1
ztop
need gigabyte ga-p35-ds3p drop mod
hello..i'm searching for a gigabyte ga-p35-ds3p drop mod... someone can help me?
thanks
ztop is offline   Reply With Quote
Old 07-09-2007, 11:32 AM   #2
ztop
Old 07-09-2007, 11:57 AM   #3
bassie
Send a message via ICQ to bassie
pictures?
bassie is offline   Reply With Quote
Old 07-09-2007, 12:00 PM   #4
ztop
i have no pictures ...sorry....
Old 07-09-2007, 12:34 PM   #5
Adam217
I would also like to know this and voltage measuring points as well. I can take some high res shots of board if that would help, may take a day or two since I would have to disassemble rig. I have no problem poking around with a DMM, just can't identify the proper components.
__________________
Gigabyte GA-P35-DS3P
Intel Q6600@3.5
G.Skill 4GBPQx2 8GB
ATI HD4870
WD Raptor-X 150
WD 36GB Rapor x2
WD 320AAKS
NEC 3500a DVDRW
Corsair HX620
X-Fi Prelude
Adam217 is offline   Reply With Quote
Old 07-09-2007, 12:44 PM   #6
ztop
[IMG][/IMG]
i have found this img from vr forums...but this mod is for the p35 ds3...not for the p35 ds3p....
Old 07-09-2007, 12:49 PM   #7
ztop
here we go... the mod for the p35 ds3 and the p35 ds3p are the same...
read here
http://sg.vr-zone.com/index.php?i=4966&s=10
Old 07-09-2007, 01:54 PM   #8
Adam217
The boards are not the same, that is the DS3R in the link, the DS3P has a different layout. The DS3P, DS4, and DQ6 share the same layout. Take a look at the pictures in this thread, http://www.xtremesystems.org/forums/...d.php?t=142340 , look closely at the top of the ram slots, note the position and orientation of the fan header.
This, http://img262.imageshack.us/my.php?i...sc08545zw5.jpg , was posted over at the VR-Zone forums. Compare that with the ones posted in the DS3R review and you can see see the components are in different places.
__________________
Intel Q6600@3.5
G.Skill 4GBPQx2 8GB
ATI HD4870
WD Raptor-X 150
WD 36GB Rapor x2
WD 320AAKS
NEC 3500a DVDRW
Corsair HX620
X-Fi Prelude
Old 07-09-2007, 02:33 PM   #9
ztop
you're right.... there is some differences...and at the moment i don't know how to do this drop-mod on the p35 ds3p...
this is taken from a p35 ds3p?
Old 07-10-2007, 09:25 AM   #10
ztop
someone have made the mod ?
Old 07-10-2007, 11:34 AM   #11
ibby
Annoyed
ibby's Avatar
this is the picture for your board ?
__________________
RIP GrandDad , I'll miss you -15/07/1985
RIP GrandMother, I'll miss you -08/08/2007
Sossaman Modfications Planned.
ibby is offline   Reply With Quote
Old 07-10-2007, 11:38 AM   #12
ztop
yes
Old 07-10-2007, 01:23 PM   #13
ibby
Annoyed
ibby's Avatar
I belive that is your vdroop mod.
Please mesure voltage before hand
__________________
Old 07-11-2007, 03:49 AM   #14
ztop
i can do it with a pencil?
thanks
Old 07-11-2007, 03:56 AM   #15
ibby
Annoyed
ibby's Avatar
I dont see why not,
But i dont have the board here to check the voltages / resistance
so could be worth checking the other board and verifying i m right
__________________
Old 07-11-2007, 11:55 AM   #16
ztop
someone have tried the mod posted by ibby?
Old 07-12-2007, 09:37 AM   #17
dnottis
Xtreme Mentor
dnottis's Avatar
The pencil P35 DS3R vdroop mod DOES NOT work. I did it last night and my volts tanked!!!! Normal 1.35 became 1.22 and load was 1.04v. I lost stability at stock settings... remove the mod and its running 3.6 @ 1.525, 1.44 actual now.
Sucks cause I wouldn't have ordered this board if I had known the vdroop mod didnt work.
EDIT - in fact just to test it again today. I made 1 swipe with #2 pencil. Booted up, voltage dropped from 1.49v to 1.44v idle at the 1.525v setting. Under load 1.44 dropped to 1.37 and the machine froze. SO, the pencil mod VR-Zone is touting actually LOWERS your voltage!!!!!!!!
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 08-06-2007, 12:23 PM   #18
Adam217
Any chance anybody ever came up with the vdroop mod for ds3p? I would also like to know voltage monitoring points.
__________________
Intel Q6600@3.5
G.Skill 4GBPQx2 8GB
ATI HD4870
WD Raptor-X 150
WD 36GB Rapor x2
WD 320AAKS
NEC 3500a DVDRW
Corsair HX620
X-Fi Prelude
Old 08-06-2007, 02:05 PM   #19
fishton
I could hep you with the vdroop mod if you can get some measures
I ve modded the same chip on my GA-G33M-DS2R
fishton is offline   Reply With Quote
Old 12-10-2007, 11:18 AM   #20
darken
help
could anyone confirm if this Vdroop mod worksfor DS3P?
thanks
darken is offline   Reply With Quote
Old 01-03-2008, 01:59 AM   #21
aoch88
aoch88's Avatar
Does the vdroop mod also applies to DS3L?
I guess the layout of the boards are all the same so I believe it should work?
aoch88 is offline   Reply With Quote
Old 02-14-2008, 04:28 PM   #22
c00LhaNd
c00LhaNd's Avatar
Send a message via ICQ to c00LhaNd
works great on my P35-DS4 Rev1
should also work on P35-DS3P, because same PCB Layout
thx a lot dude!
__________________
Code:
e6420 @ 3,6GHz | 2 x 2GB Mushkin XP2-8000 | Gigabyte GA-P35-DS4 Rev 1.0 XFX 9600GT @ 800/1950/1050MHz | Enermax Liberty 500W | Lian Li V1000 plus b cooled by AF Soleil01, EK-FC9600 SLI nickel, Mora 2 Pro, Laing Pro
c00LhaNd is offline   Reply With Quote
Old 02-14-2008, 09:14 PM   #23
maxwolfie
Confirmed working on P35-S3 also
maxwolfie is offline   Reply With Quote
Old 02-17-2008, 01:54 AM   #24
quintus
quintus's Avatar
also on my ds3!
quintus is offline   Reply With Quote
Old 02-17-2008, 04:15 AM   #25
r4st4m4n
r4st4m4n's Avatar
Did you use conductive ink or pencil ?
__________________
Q6600@3.6 GHz / GA-X48-DQ6
2x2GB Kingston HyperX DDR2-800
Asus HD 5870
Corsair TX-850
WD Velociraptor 150GB / WD Green power 500GB
Water Cooling: EK res 250 > Swiftec MCP655 > Swiftec MCR320 > EK-FC5870 > HeatKiller 3.0 LT
r4st4m4n is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
