WARNING:
DON'T BUY ALUMINIUM WATERBLOCKS![]()
OR MIXED /// COPPER base with ALUMINIUM COVER ///![]()
WARNING:
// E6600@3900~1.5v // Asus P5K DLX //A-DATA 2GB EE // Samsung F1 1TB // ASUS X1900XTX~735/1680 // Corsair HX520 // Thermaltake Armor VA8000SWA // W. COOLING ~ D-Tek FuZion & Viscool V3 GPU & Swiftech MCP655 & 2x Swiftech MCR-320QP //
Ew!!!!
CPU: INTEL Q9550 E0 @ 3600 1.28V + CORSAIR H50
GPU: EVGA GTX 480 @ 725/1450/3800
PPU: EVGA 9800GTX @ 738/1836/2250
MB: ASUS P5E X38
RAM: MUSHKIN 2X2GB
SOUND: X-FI TITANIUM FATAL1TY | LOGITECH Z-5500 | LOGITECH G35
HDD: WD 76GB X 2 RAPTORS RAID 0 10KRPM | WD 1TB CAVIAR BLACK 32MB STORAGE
PSU: CORSAIR HX1000W PSU
OS: WINDOWS 7 PRO X64 OS
MON: HANNSPREE 28" 1920X1200 RESOLUTION
OMG Is that true ?
My project log
http://forums.overclockzone.com/foru...ad.php?t=62457
omg!!
Duh?![]()
Yea, that happens.![]()
Can somebody explain the chemistry or whatnot involved here?
HTPC - AMD Phenom II 555 Unlocked(4cores) - 4GB Gskill - AMD HD 5850 - Avermedia Duet - Harman Kardon avr247 - Surround Sound (Infinity Beta 50's, 10's, 360, and ed a2-300) - Samsung 46"
Desktop Powerhouse PC - Gathering dust due to high usage of HTPC as general pc now
looks like some has been eating to many veges and has being pooing green![]()
My Rig
CPU: Intel Core 2 Duo E6600 L626A175 3GHZ 1.30V real
RAM: Crucial Ballistix PC2-8500 stock speed and timings
Motherboard: Asus P5E X38 333MHZ FSB x9 multi
Video: Gigabyte 8800GTS 320mb stock speeds
Soundcard Creative Soundblaster Audigy 2 ZS
Hard Drives Seagate 250GB 7200.10 SATAII (boot) > Samsung HD501J 500GB SATAII (Storage)
Case: Lian Li PC-S80
Powersupply: Corsair HX620W 620watt
Optical: Samsung SH-S182D DVDRW 18x
Monitor: Asus MW221U 22" LCD
Mouse: Logitech CF G7
Keyboard: Logitech G15
Speakers: Logitech Z5500
The water cooling
CPU waterblock: Swiftech Apogee (original with custom top and mounting plate)
GPU waterblock: EK FC8800GTS Acrylic
Pump: Laing D5 Vario "3" speed setting
Radiator: Swiftech MCR220 w/ 120mm Yate Loons D12SM-12 running at 7V
Resevoir - Swiftech MCRES Micro - Pentison G11
[img]http://smiliesftw.com/big/noesaway512.gif[ / img]
*EDITed by IFMU*
Point to this post other than?.....
FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
eXceed TJ07 worklog/build
What liquid did you use ?
Asus P5K DLX ** e6700@360** **2xWD Raptor 160gb** 2xseagate 500gb sata2** ATI X1950XTX GDDR4** **Coolermaster stacker T01**Enermax liberty 700W **Laing D4**SWIFTECH STORM G4 REV2**SWIFTECH MCW30**MIPS on SB- transistors **2Gb OCZ-9200 FlexSeries**Terastation 1.6TB
Gah, that's disgusting! but then again, you should have known better not to add anti-corro stuff
but this looks more than simply corrosion *pukes*
Delicious! Put that on your salad next time you have some
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
Sorry guys, but Im gonna have to be controversial and disagree with the non use of AL blocks
Infact AL has a "natural" resistance to water:
"aluminum is immersed in pure water, it will form a white hydroxide film, which remains more or less constant in thickness"
From the above pics, there are lots of reasons that this can occur,mixed materials, had a pump that had way too much pressure, water that had a low Ph (acidic) but it was probably because it didnt have any glycol in.
As long as your not careless and look after your loop this wont happen.
For those interested in the a bit of chemistry and al corrosion and my source please see:
http://lytron.com/support/anti_corrosive.htm
However this thread is a good warning for those with AL block to stick a nice amount of anti-freeze (Normally a nice source of ethylene glycol)
In fact Marci..if your around (being a great source of all water cooling knowledge in the uk) how do you find al? and would you agree/disagree with anything I have said?
*Im pretty sure that ONLY water in an AL loop will do more damage than goodyou need good anti freeze with glycol and anti corrosion ingredients and you will have trouble free operation with an AL loop
Last edited by rogard; 05-28-2007 at 02:16 AM. Reason: *added the bit about only water
If you hade some glycol (or other alcohol based liquid) with destilled water you wouldnt have that green icky stuff.
"The flames of freedom. How lovely. How just. Ahh, my precious anarchy.."
How about adhering to industry practices in general and not using it altogether so that there's less work/planning to be involved on the consumer side. Not to mention, Copper dissipates heat better. The use of ALU is shoddy craftsmanship and design.
By forcing us to use additives, we lower the theoretical amount of heat that can be dissipated instead of having gone a 100% solution of distilled water.
By making excuses for companies, we just shoot ourselves in the foot.
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
its does not look very nice ...
BUT
Warning: please do not use massive red text with a mix of capital letters and non-capital letters. (it's damn annoying expecially when your lappy screen is 1024*768)
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
