Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: 8600GTS Real Benches from an Aussie
    Xtreme News
    Dec 2005
    California
    Originally Posted by Aussie
    With drivers supplied on cd:
    E6600
    250gb 16mb cache Sata 3gb/sec
    2gb 6400 Gskill ram
    3dMark06...
    Main Test Results
    3DMark Score 5542 3DMarks
    SM 2.0 Score 2284 Marks
    SM 3.0 Score 2036 Marks
    CPU Score 2605 Marks
    Detailed Test Results
    Graphics Tests
    1 - Return to Proxycon 17.534 FPS
    2 - Firefly Forest 20.532 FPS
    CPU Tests
    CPU1 - Red Valley 0.834 FPS
    CPU2 - Red Valley 1.302 FPS
    HDR Tests
    1 - Canyon Flight (SM 3.0) 18.063 FPS
    2 - Deep Freeze (SM 3.0) 22.653 FPS
    http://forums.whirlpool.net.au/forum...m?t=715719&p=1
    Xtreme Mentor
    Oct 2005
    Portugal
    8600GTS
    Just picked it up, whim me for shop!!!
    Got to stuff it in my pc and run some benchies!
    E6600
    2gb 6400 Gskill ram
    3dMark06...
    Main Test Results
    Graphics Tests
    CPU Tests
    HDR Tests
    Max temp with fans PELTING (stock) was ~70c with ATI tool stress test... This thing could do with some aftermarket methinks!
    After adding Zalman VF900cu (fit perfectly with 7600gt holes and settings) at high speed, max temp at stock settings came to 50c.
    So I overclocked...
    With core at 715, and memory at 1110, 3dmark06 score was 5847 Marks , with temps JUST touching 55c.
    I've now dropped it to 710 and 1100, with idle temp 40c and max about 52-53.
    http://forums.whirlpool.net.au/forum...s.cfm?t=715719
    Stock
    Overclocked (705 core // 1145mhz Ram)
    3DMark Score 5654 3DMarks
    SM 2.0 Score 2342 Marks
    SM 3.0 Score 2079 Marks
    CPU Score 2603 Marks
    Delta Stock -> OC
    3DMark Score +112 3DMarks
    SM 2.0 Score +58 Marks
    SM 3.0 Score +43Marks
    CPU Score -2 Marks
    Perhaps the memory is holding your card back... I'm surprised that overclocking yielded so little performance.
    MAX OC w/ Zalman VF900 >> 715Mhz core // 1145Mhz memory :
    720 gave me a little green dot on the fuzzy cube when "scanning for artifacts".
    I just tried the memory. Got up to 1155 (with find max mem), then cube turned into a big yellow square, with something about direct x not matching?
    (Stock settings with stock cooler got to 70c)
    regards
    [Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
    [Review] ASUS HD4870X2 TOP » Here!! «
    .....[Review] EVGA 750i SLi FTW » Here!! «
    [Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
    [Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
    I am Xtreme
    Apr 2005
    Upstate, NY
    Slow..
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Xtreme Gamer
    Jun 2006
    Des Moines, IA
    Quote Originally Posted by NickS View Post
    Slow..
    It is supposed to replace the 7600GT, what did you expect?
    Sep 2006
    Does this mean that shops will start selling the card early or that particular shop that just sold the card will get in trouble?
    /nV ninjas will raid the shop?
    I am Xtreme
    Aug 2003
    These could be some fun buggers to OC
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    I am Xtreme
    Apr 2005
    Upstate, NY
    Quote Originally Posted by [cTx]yaddam205 View Post
    Something equivalent to my X1900GT Rev. 1
    Mar 2005
    128-bit memory is holding that card back Big time, and nvidia knows it, the 8600gts has a ~12% core clock advantage, but a 40% memclock increase over the 8600GT (assuming gt:700, gts:1000). doesn't clock as high as I'd expect.
    Microsoft's homepage can be found at: thesource-dot-ofallevil-dot-com - interesting, no?
    Think of something witty and imagine it here.
    Apr 2004
    Well, I think you got that, at the very least.
    DFI LANParty DK 790FX-B
    Phenom II X4 955 BE (1003GPMW) @ 3.8GHz (19x200) w/1.36v
    -cooling: Scythe Mugen 2 + AC MX-2
    XFX ATI Radeon HD 5870 1024MB
    8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
    Seagate 1TB 7200.11 Barracuda
    Corsair HX620W
    Support PC gaming. Don't pirate games.
    I am Xtreme
    Apr 2005
    Upstate, NY
    Quote Originally Posted by Cybercat View Post
    Think again. That's with my 24/7 CPU clock and fairly low GPU clocks (can do 735/855 bench stable).
    Live Long And Overclock
    Sep 2004
    Games will decide this...we all know that.
    Perkam
    I am Xtreme
    Apr 2005
    Upstate, NY
    Well my SM3 clobbers the 8600's, but I get beat slightly in SM2.
    Jan 2005
    Grand Forks, ND (Yah sure, you betcha)
    looks to me that the 8600gts will be very good in SM2. SM3 doesn't look so great.
    Just looking at regular overclocks...
    8600gts OC (coolaler)
    SM2: 2700
    SM3: 2400
    x1900gt OC (NickS)
    SM2: 2260
    SM3: 2530
    Edit: NickS beat me to it...I was trying to see if the same pattern occurs in the 8800 products, it does not.
    Very strange...Wonder if it's a driver bug?
    That is all.
    Peace and love.
    Apr 2004
    And here I was expecting something like 7k+. Have you seen the VR-Zone article?
    Corsair HX620W
    I am Xtreme
    Apr 2005
    Upstate, NY
    Maybe tonight I'll do some cold 06 runs for the fun of it, see if I can get near 6.8k or so.
    Oct 2004
    well, its better than a 7900gt, most ppl didnt expect that much by looking at the specs.
    DFI P965-S/core 2 quad q6600@3.2ghz/4gb gskill ddr2 @ 800mhz cas 4/xfx gtx 260/ silverstone op650/thermaltake xaser 3 case/razer lachesis
    Aug 2006
    The Netherlands, Friesland
    nVidia 7600GT was also slow when it came out, compared to the (previous generation) high-end in that time. 8600GT has the performance you should expect for an mid-range card, nothing less or more.
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
  18. #18
    Jan 2005
    The thing is buddy, most people don't really count the V-mods or Shamino's slick and nasty cooling as an even comparison.
    Granted, I do agree they should play a role considering how easy the mods are, and most people 'round here will use nice air or wawa on their cards...Still. If you do count that article (mods/cooling), the 8600gts is a pretty nice card and is comparable or exceeding last gen's performance parts...Of course you'd also have take into account the 7900gs can be conductive ink modded as well and give a slightly better score.
    It's pretty mucky. I think it comes down to if you want DX10 support, and the question of how it will perform using it. If it does reasonable, I think it will have it's place for replacing the current ~$200 cards.
    That is all.
    Peace and love.
  19. #19
    Apr 2004
    Well, this is XS, so I'm at least expecting stock cooling to be out of the question. Still even if you take volt mods out of account, ~6100 is within the capabilities of the 8600GTS. It really is a small difference, and like Perkam says, it's the games that matter anyway.
    Corsair HX620W
  20. #20
    Jan 2005
    Well, now we know.
    http://vr-zone.com/?i=4883
    That is all.
    Peace and love.
  21. #21
    I am Xtreme
    Apr 2005
    Upstate, NY
    So basically a vmodded 7900GT stomps a mudhole in the 8600GTS' aszz.
  22. #22
    Xtreme Mentor
    Oct 2005
    Portugal
    the scores on the topic was with zalman vf900 ,with stok cooling and default clocks the card reach 70c
    with zalman vf900 max clocks = 715/1145
    And the problem i see its not the OC , its the score , form default clocks to OC 715/1145 only ~200 points
    Stock
    Delta Stock -> OC
    CPU Score -2 Marks
    MAX OC w/ Zalman VF900 >> 715Mhz core // 1145Mhz memory (5847 Marks)
    Btw: In Games seems Better than in Benchmakrs (3Dmark)
    In terms of overclocking, both are overclocking masters when overclocked the "professional" way... But close to 60% headroom can be garnered on the 7900GTbut "only" about 35%on the 8600GTS. For how well this card overclocks, http://www.vr-zone.com/?i=4883
    7900GT performence ( a litle better) with DX10 , Not BAD for 200$
    reagrds
  23. #23
    Oct 2006
    nah...id still get a x1950pro instead which is dirt cheap and still faster
  24. #24
    May 2004
    for 200$ I rather have an X1950XT, it will smoke the 8600GTS.
  25. #25
    Apr 2006
    Cairo
    Quote Originally Posted by mascaras View Post
    reagrds
    Note that this is a 8600GTS overclocked @ max with after market cooler VS 7900GT @ 450/660 ,,,,,,,,,,,,,,,,,,,,,,,,, who runs a GT at those speeds @ XS
    Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
    Asus X58 P6T
    6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
    XFX HD5870
    WD 1TB Black HD
    Corsair 850TX
    Cooler Master HAF 922
