Hello
While ago Symon asked me about unit, to cool his quadcore with reasonable temperatures. I suggested an autocascade, tuned to hold quad load :-) And here it is !
Specification:
Compressor -> Sanyo 7000btu/h
Condenser -> 1,9kW
Evaporator -> made by Duniek, brazed by myself, grey sleeve, 75cm suction line, 19mm thick insulation.
Phase separator -> 35mm pipe with caps.
Expansion devices -> captubes on both stages.
Heat Exchangers -> Main HX + slhx before phase separator.
Gases -> R290/CO2 (maybe a bit of R1150).
and some pictures:
I f*cked charge, so don`t look @ temperature. I had -87*C on evaporator (not at vacuum !). Must vacuum it once again and charge ;-)
I will make triple evac tomorrow and charge it once again.
Hope you like it.
Cheers
But from what I see, it`s ideal for everything.
Only few days and it will be finished !
