Existing Equipment Analysis:
CM Stacker 830
ASUS Striker Extreme
Intel Core 2 Duo E6600
2x1GB Corsair C4Pro
XFX 8800GTS
Gainward 8800GTS
4 x Seagate 320GB HDD
1 x Maxtor 300GB HDD
Silverstone 850W Power Supply
Samsung SyncMaster 21" 215TW
Benq 17" FP791 with TV Tuner
Zalman 9700 CPU Air Cooler
Noctua 120mm Case Fans
Crossflow Fan
TrackIR4 Pro
Saitek X52 Pro HOTAS
Saitek Pro Flight Rudder Pedals
Z-Board Fang
Logitech MX-1000 Mouse
Cherry Cymotion Master Wireless SolarPowered Keyboard
Observations:
Existing system is too noisy and the GPU's tend to get a bit hot.
Requirements of Project "CUBEIT":
Cooler running of CPU & GPU's.
Totally silent PC (or next to silent).
Install existing components into a case that will provide more than sufficient internal space.
New case to provide many years of use with support for expandability and equipment adjustments as technology advances.
Case can look real funky too.
Equipment to be replaced:
CM Stacker 830
Crossflow Fan
Equipment that may be replaced if it doesn't measure up:
New Equipment:
Mountain Mods U2-UFO Opti-1203 Black Powder Coated - Diamond Top
Tygon 3603 Tubing 1/2"ID 3/4"OD
1 x Thermochill PA120.3 Radiator
1 x Thermochill PS120.3 (Shroud)
1 x Thermochill NG120.3 (Neoprene Gasket)
1 x Swiftech MCP655 Pump
1 x Filling Syringe
1 x Hose Cutter - Metal
2 x Swiftech MCW60 Graphics Card Liquid Coolers - Black
2 x Retention Hardware MCW60 G80 adapter kits
Swiftech MC14 VGA Forged Copper BGA Ramsinks (8 per pack)
Swiftech MC21 Aluminum Mosfet Heatsinks for MCW60 Water Block (4 per pack)
1 x D-TEK FuZion CPU Block
1 x Thermalright LGA775 RM LGA775 Retention Bracket
1 x EK Multioption RES 250
1-1/4" Black-Oxide Steel Thermochill/BIP/BIX Fan Screws (Pack of 4)
Spare Black Fan Screws (Pack of 4)
ArctiClean Thermal Material & Surface Purifier - 60ml
Not using now Arctic Silver 5 Thermal Compound
Using this instead Arctic Silver Ceramique
UV Reactive Pentosin G11 Coolant Additive (Blue) - 4oz.
Undecided Equipment:
Four Channel Sunbeam Rheobus, 5.25 Black OR
Zalman ZM-MFC1 6-Channel Fan Controller
Status:
All parts have been ordered except Fan Controller
now ordered ---> Zalman ZM-MFC1 6-Channel Fan Controller (using masaville's suggestion to remove the faceplate, mount it behind the slot cover and drill holes thru the slot cover)
Pictures:
Finally have some pictures - see below
