This is my latest project, it’s a lot bigger and much more different than the normal units we all see, My thinking behind it was to have two condensers with the 93cfm fans blowing from either side to try and keep the compressor and gass nice and cool as you will see I have made a small SLHX and hope to have the unit running a mixture of R402a and R410a which will make things run that bit hotter than normal.
The unit is not finished yet as I am still awaiting Chilly1’s new evap, once this has been fitted and pressure tested I will then do some more paintwork to the compressor and some pipe work.
As you will see i have made two trunking compartments for all the cabling, one section for 240v and another for data and ELV cables, the system is fully protected to 16th edition wireing regs has thermal and overcurrent protection,it also has a safty presuer cutoff switch incase the presuer gets above the set limit.
A Big thanks to SoddemFX for all his input and help
Anyway that’s enough waffle hears some pics.
Sacha
