Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Gigabyte P35-DQ6 Picture!! ... another All Solid DQ6 w/ Great Pipes!! (56K Friendly)
    Feb 2006
    Sorry Guys
    Pictures Removed Because I Received Official Alert from Gigabyte
    Sorry for Sharing!
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Thats not a good sign...all that chipset cooling?
    Are those DDR3 slots?
    Thanks for the pic!
    you sigged that?
    why?
    ______
    Jan 2005
    The Netherlands
    Quote Originally Posted by K404
    Thanks for the pic!
    Could be a bad sign, I think it is just to impress costumer.
    I think those are not DDR3 slots, that is when I look at this picture:
    AMD Opteron 148 CABYE 0543 FPBW || DFI LanParty nF4 SLI-DR AD0
    2x 512MB OCZ PC3500 Limited Edition Winbond BH-5 || 2x 512MB Corsair PC3200LL V1.1 Winbond BH-5 || 1x 256MB Mushkin PC3500 LV2 Winbond BH-5
    SAPPHIRE X800GTO2 @ 16P 600/570, Voltmodded, GPU=1,7V/VDD/VDDQ=2,3V
    Zippy PSL-6720P(G1) GAMING ,POWER - I love it!
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    This is a DDR2 board, and it's already been tested hands-on by people you've most likely seen around here. P35 is still in the alpha stages though and the boards are very immature.
    Formerly XIP, now just P.
    Jul 2006
    Vancouver, BC
    Thanks for the pic!
    You can see from the silk-screen by the DIMM slots that it's DDRII.
    As for the heat pipes, OMFG... this looks worse than a Striker!
    Aug 2006
    eu/hungary/budapest.tmp
    Is it just me or is the NB HS in the way of the first x1 slot?
    Too many big HSs around the socket.
    Usual suspects: i5-750 & H212+ | Biostar T5XE CFX-SLI | 4GB RAndoM | 4850 + AC S1 + 120@5V + modded stock for VRAM/VRM | Seasonic S12-600 | 7200.12 | P180 | U2311H & S2253BW | MX518
    mITX media & to-be-server machine: A330ION | Seasonic SFX | WD600BEVS boot & WD15EARS data
    Laptops: Lifebook T4215 tablet, Vaio TX3XP
    Bike: ZX6R
    Oct 2005
    Norway
    maybe the cooling is interchangeable with the R600 cooling:P
    Looks like the chipset is gona run hotter than a stock Core 2
    Core i7 920@4.3GHz TRUE, 2xHD4890, 6GB OCZ@1640MHz
    Oct 2006
    Argentina
    i see 12 phase regulation? OMFG!!!
    I am Xtreme
    Dec 2002
    jeeze what an ugly cooler, and board all together, i wonder if it rally needs all that cooling.. thats got to be better then most aftermarket coolers...
    Feb 2007
    And I thought Striker had big heatpipes, but that's just huge.
    =- Main RIG -= Quake 4 flies - Problem Solved
    -= Intel QX6700 2660 MHz OC 3.2 GHz =-
    -= Asus Striker Extreme nVidia nForce 680i SLI =-
    -= PDP Patriot Dual XBLK 2x 1GB DDR2 1 GHz CL4 =-
    -= EVGA GeForce 8800 GTX 768MB KO ACS3 =-
    -= Creative Sound Blaster X-Fi Fatal1ty =-
    -= WD Raptor X 150 GB 16MB SATA =-
    -= 2xSeagate 320 GB Barracuda 16MB SATAII =-
    -= CoolerMaster Stacker 830 Black =-
    -= Topower TOP-1000P10 U12 EZ =-
    -= Logitech G15 =-
    -= Razer Copperhead Laser 2000 DPI Blue =-
    -= Logitech Z-5500 THX =-
    -= Dell 2407 WFP UltraSharp =-
    -= Windows XP Pro SP2 =-
    Sorry for my bad English. I'll try to improve.
    Xtreme Guru
    Dec 2006
    Philly/NJ
    ok that kinda cooling is just un called for lol, i wonder how hot those get
    Jun 2004
    Olot (Girona)
    I'm also testing it right now...
    || Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
    || XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
    Nov 2004
    Geez, what all is under that big sink in the middle? That's just ridiculously huge. How is anyone supposed to maneuver a cpu heatsink onto the socket with THAT?
    Feb 2005
    Indiana
    Man...talk about overkill on the chipset cooling. Why didn't they just go ahead and include some Dice Pots?
    Sep 2006
    Stamford, UK
    any other information about this board?
    FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
    eXceed TJ07 worklog/build
    Oct 2005
    Austria
    sick sh*t
    what's next; three stage heatpipe cooling? chipset and vrm cooling devices bigger than the cpu cooler?
    i'm waiting for the day when the bling bling stuff costs more than the "real" components on it.
    Power Rig: Core i7-5930K, ASRock X99 Extreme6/3.1, 16GB G.Skill DDR4-2400, Asus Strix GTX980 OC
    Time Sink: Core i7-5775C, ASRock Z97E-ITX/ac, 16GB AMD DDR3-2133, Silverstone PT-09 w/ 120W Power Brick
    HTPC: Athlon 5350, ASRock AM1H-ITX, 4GB DDR3, Supermicro SC-101i
    Nov 2004
    United Kingdom
    i like having the cooling on, its not overkill if it'll help you push the board a lil further with the stock cooler. would be good if there was some sort of active attachment, like....ummm i forget the board now he he, i think it was abit that allowed you to add on a fan or something???? :S
    Core i7 7700K| ASUS Z270F | 16Gb DDR4 | GTX1080Ti | Watercooled CPU+GPU | 512GB 950Pro
    So why is it customary to post specs in sigs anyway?
  18. #18
    Dec 2006
    Strangely enough:If this board clocks like crazy and is rockstable,suddenly everyone stops moaning about the heatpipe...and start drooling over it..For me,i don't give a damn how a board looks like,as long as it's a good one....
  19. #19
    Xtreme Legend
    Mar 2005
    Australia
    when will they stop messing with us and JUST STOP PAINTING those sinks in copper colour FFS
    either put copper ones there or stop misleading people
    Team.AU
    Got tube?
    GIGABYTE Australia
  20. #20
    I am Xtreme
    Dec 2002
    fake copper is usually pretty easy to spot imo, this stuff looks real...
  21. #21
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by Revv23
    LOL are you sure
    have a look at the colour again i don't even have to guess this stuff is fake believe you me............firstly because of the cost involved and colour is too bleak for copper
    Team.AU
    Got tube?
    GIGABYTE Australia
  22. #22
    Xtreme Mentor
    Jan 2005
    I don't understand?...why the elaborate cooling setup?, don't get me wrong...i like it.
    But i assumed Bearlake was made using 65nm technology, the chipset uses less voltage/power/produces less heat etc.
    Or am i totally wrong?
    Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
  23. #23
    Xtreme Mentor
    Jan 2005
    Quote Originally Posted by dinos22
    LOL are you sure
    The DQ6 has a copper base while the upper/finned area is painted aluminium.
  24. #24
    all outta gum
    Dec 2006
    Poland
    At least the cooling solution is mounted with screws, not like those crappy plastic clips on ASUS' 680i's (Striker, P5N32-E)
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
  25. #25
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Quote Originally Posted by xoqolatl
    atleast ...
    did you actually see the huge heatsink on the back of the board? it has a simple path for watercooling j/k
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
