Results 1 to 21 of 21
Thread: eXceed TJ07 loop reconstruction/work log (realtime) (no 56kers die)
    Sep 2006
    Stamford, UK
    Basically I've decided to meet current needs of graphics and cpu hardware my current build has to be updated to what it really should have been in the first place.
    ATM my TJ07 has a the following watercooling components installed:
    - BIX240
    - Alphacool NexXxoS XP Bold Sockel 775
    - Laing D5
    - DangerDen 5 1/2" single bay reservoir
    I have the D5 and BIX in the bottom along with my Enermax Liberty 620W. Here are some pics for those that are interested:
    (bear in mind these pics are around 1-2 months old, sorry poor quality!)
    latest pic
    latest pic
    At some point this year I will be upgrading my computer with 2 x AMD Quad Core Agena FX's (that is if they don't suck...) and a R650/70 (again if they don't suck) so I plan on upgrading to these components:
    - Thermochill PA120.3
    - Thermochill PA120.2
    - 2 x 12V Laing DDC-1T Ultra w/Petras Tech DDCT-01s Top
    - 2 x Dtek FuZion cpu block
    - DangerDen Single bay reservoir (thats on top of the current one I have)
    - Swiftech MCW30 chipset block (unsure of how many I will need but will be ordering one at first to go on my current motherboard chipset)
    - 40ft of Tygon 1/2" OD (I don't deal in small quantities, scared I'll run out during build - would get pissed off if I had to order more during build! -)
    I of course am looking to build 2 separate loops because of the excessive heat output...
    ATM I have reached really really really basic blue prints of what I plan on doing, and I only really made it to ensure I could theoretically fit everything down there. At first I was going to get 2 D5's but they won't fit and having read about the Petra Tech Ultra Top I don't know why I chose the D5 in the first place!
    Here's the rough schematic/blue print/paint drawing (not actually made with paint but it looks poor in JPEG format...) I made:
    I will update this thread as I get everything ordered up and finalised. All I need is any feed back on my build and also what to put into what loop. I am currently thinking:
    - CPUs on the PA120.3
    - GPU and chipset(s) on the PA120.2
    And I have not got a waterblock planned for the GPU yet but will be looking for one as soon as they are released...
    Thanks for any advice!
    FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
    eXceed TJ07 worklog/build
    Apr 2005
    Windsor, Canada
    Nice, I love the look of the TJ07. Where are you planning on putting the 120.3? I'm sure two PAs on the bottom won't fit comfortably.
    Usama aka Ferrari Freak
    Quote Originally Posted by jimmyz View Post
    A DFI board is like a divorce, expensive, but well worth it.
    Quote Originally Posted by virtualrain View Post
    I dunno... I think a DFI board is more like marriage... demanding, time consuming, and a PITA but rewarding in it's own twisted way.
    Sep 2006
    Stamford, UK
    haha check my little drawing (all the parts are labelled with numbers so you can identify them)
    Banned
    Jun 2006
    in a Red Rage D....
    exceededgoku could you include an airflow diagram of what you're planning to do?
    its like both sides gonna intake air thru rad thru fan and meet in the middle, maybe channel meeting air downwards towards the bottom of case?
    and also maybe more unrestricted intake grills/filters?
    but the basic idea is good... keep up the good work/paint/drawing/modding...
    Sep 2006
    Stamford, UK
    I hadn't thought about changing the grills... but I had thought about the airflow:
    I imagine if I had arranged so that the fans would pull air then there would be turbulence in the middle which would affect temps negatively. I was toying with the idea of a fan pointing directly down the middle between the pumps and the radiators but I can see that also have a negative effect on temps...
    Banned
    Jun 2006
    in a Red Rage D....
    so most likely plan some sort of filtered intake vents on the bottom to be pushed thru the rad by the fans...
    or maybe invert rad fan placement so that pull cool air from bottom vents thru rad thru fan to case and out...
    you could probably also use space beside PSU as another exhaust, if it would fit another 92mm fan there...
    Mar 2007
    Durham, UK
    Just started looking at options for rad and pump placement. My PA120.3 staying down there, but as you can see the Galaxy psu takes up lots of room on the other side, about 11 inches to were the cables bend up. Just as well its modular!
    Thought I'd see what it would be like if I tried to get both rads down there.
    The other rad is a B I pro 240. Looks like its going to live with the top case fans.
    Think I'll put both D5 pumps down with the PA, so the air can move better
ID:	59498   Click image for larger version.
ID:	59499   Click image for larger version.
    Sep 2006
    Stamford, UK
    nice build, that radiator looks mahooosive!!!! Hope for my sake that mines not that big... otherwise there will be some issues... although it works in practise!
    EDIT: just saw the angle you have the camera at, yeah looks like there is plenty of space
    Mar 2007
    Durham, UK
    Check out little and large ha ha. Now I know why Thermochll is king of the hill.
    At least the B I pro looks like the air will flow through the rows just as well as the PA.
ID:	59501   Click image for larger version.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Please resize the pics to 1024x768 for those of us who have slower connections, we don't really need poster size pics The one is 2048x1536 for example, way too big.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Mar 2007
    Durham, UK
    This is my Tj07 striped
    Sep 2006
    Stamford, UK
    mines going to get the same treatment within the next month
    Feb 2007
    Arizona, USA
    Wait, in order to place a 120.3 and a 120.2 in the bottom, do you need to use 90deg bends? If so, would it kill your flow by much?
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
    Sep 2006
    Stamford, UK
    There is space to make a gradual incline, and with tygon there wont be any problems with kinks or such (hopefully )
    PS. All parts have been ordered
    Feb 2007
    Arizona, USA
    Quote Originally Posted by ColonelCain View Post
    Was that answering this?
    May 2006
    Slovakia Europe
    Quote Originally Posted by ladderman View Post
    lol
    Nice photos
    // E6600@3900~1.5v // Asus P5K DLX //A-DATA 2GB EE // Samsung F1 1TB // ASUS X1900XTX~735/1680 // Corsair HX520 // Thermaltake Armor VA8000SWA // W. COOLING ~ D-Tek FuZion & Viscool V3 GPU & Swiftech MCP655 & 2x Swiftech MCR-320QP //
    Sep 2006
    Stamford, UK
    yeah
  18. #18
    Sep 2006
    Stamford, UK
    I need some advice on the loops for my future setup:
    Loop1
    Res1->Pump1->PA120.3->Dtek Fuzion CPU block1->Dtek Fuzion CPU block2
    Loop2
    Res2->Pump2->PA120.2->R650/70 block->MCW301->MCW302 (not sure if the RD790 will have 2 chipsets since it will be dual socket)
    PS Pics have been resized for ease of viewing.
  19. #19
    Banned
    Jun 2006
    in a Red Rage D....
    looks good. carry on then...
  20. #20
    Feb 2007
    Quote Originally Posted by eXceededgoku View Post
    Did you ever find out if this airflow combo, which has both sides as exhausts, was more or less effective say a more traditional airflow combo with one side being the inflow and the other being the outflow?
    Lian-Li PC-Q11W mITX - Core i5 4590 - MSI Z97I Gaming AC - 8GB DDR3 RAM - Seasonic 460W fanless - Intel SSD 520 240GB - 2x WD 4TB HDD
    Cooling: XSPC AX480 Quad rad - 4x NB-eLoop B12-1 @ 650 rpm - EK-D5 Vario X-RES 140 - EK-Supremacy CPU block - EK GPU full cover block
    Video: nVidia 670 GTX - Achieva Shimian QH270-IPSB @ 2560x1440 - Ergotron LX LCD arm | Audio: Yamaha RX-V467 receiver (via HDMI) - Tannoy Mercury F1 5.1 speakers
  21. #21
    Aug 2006
    Perth, Australia
    Im selling my Galaxy PSU just so I can fit both a PA120.3 and a PA120.2 in the bottom compartment, similar to what AndyM has done.
    With regards to rad airflow I will be sucking air in from both sides and space permitting, exhausting that air straight up through the middle and out the top of the case. My PWM, SB & NB are going to be watercooled so ambient air temps arent an issue, save for my RAM which I won't be pushing huge FSB anyway.
    I just wish I bought a TJ07 before hacking to bits a TJ09 and now realising it was a waste of money
