Results 1 to 22 of 22
Thread: X1950xt 256mb
Threaded View
    Xtreme Mentor
    Oct 2005
    Portugal
    X1950xt 256mb
    hi guys , x1950XT 256mb is out , but come with GDDR3 instead of GDDR4 like the X1950XTX but the speed memory is 1800Mhz .
    The price is around 270 €uros
    http://www.sapphiretech.com/us/produ...w.php?gpid=169
    Caracteristicas:RADEON™ X1950 XT core (625MHz)
    256MB GDDR3 onboard memory (1800MHz)
    Windows Vista™ 3D environment Support
    48 pixel shader processors
    Video-In and Video-Out
    PCI Express x16 / CrossFire support
    Pixel Shader Version 3.0
    Video Acceleration of: MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264
    Dual DVI
    Features
    384 million transistors on 90nm
    fabrication process
    Up to 48 pixel shader processors
    8 vertex shader processors
    256-bit 8-channel GDDR4
    memory interface
    Native PCI Express x16 bus interface
    Ring Bus Memory Controller
    Up to 512-bit internal ring bus for memory reads
    Fully associative texture, color, and Z/stencil cache designs
    Hierarchical Z-buffer with Early Z test
    Lossless Z Compression (up to 48:1)
    Fast Z-Buffer Clear
    Optimized for performance at high display resolutions, including widescreen HDTV resolutions
    Ultra-Threaded Shader Engine
    Support for Microsoft DirectX 9.0 Shader Model 3.0 programmable vertex and pixel shaders in hardware
    Full speed 128-bit floating point processing for all shader operations
    Up to 512 simultaneous pixel threads
    Dedicated branch execution units for high performance dynamic branching and flow control
    Dedicated texture address units for improved efficiency
    3Dc+ texture compression o High quality 4:1 compression for normal maps and two-channel data formats
    High quality 2:1 compression for luminance maps and single-channel data formats
    Complete feature set also supported in OpenGL 2.0
    Advanced Image Quality Features
    64-bit floating point HDR rendering supported throughout the pipeline
    Includes support for blending and multi-sample anti-aliasing
    32-bit integer HDR (10:10:10:2) format supported throughout the pipeline
    2x/4x/6x Anti-Aliasing modes
    Multi-sample algorithm with gamma correction, programmable sparse sample patterns, and centroid sampling
    New Adaptive Anti-Aliasing feature with Performance and Quality modes
    Temporal Anti-Aliasing mode
    Lossless Color Compression (up to 6:1) at all resolutions, including widescreen HDTV resolutions
    2x/4x/8x/16x Anisotropic Filtering modes
    Up to 128-tap texture filtering
    Adaptive algorithm with Performance and Quality options
    High resolution texture support (up to 4k x 4k)
    Avivo Video and Display Platform
    High performance programmable video processor
    Accelerated MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264 decoding and transcoding
    DXVA support
    De-blocking and noise reduction filtering
    Motion compensation, IDCT, DCT and color space conversion
    Vector adaptive per-pixel de-interlacing
    3:2 pulldown (frame rate conversion)
    Seamless integration of pixel shaders with video in real time
    HDR tone mapping acceleration
    Maps any input format to 10 bit per channel output
    Flexible display support
    Dual integrated dual-link DVI transmitters
    DVI 1.0 compliant / HDMI interoperable and HDCP ready*
    Dual integrated 10 bit per channel 400 MHz DACs
    16 bit per channel floating point HDR and 10 bit per channel DVI output
    Programmable piecewise linear gamma correction, color correction, and color space conversion (10 bits per color)
    Complete, independent color controls and video overlays for each display
    High quality pre- and post-scaling engines, with underscan support for all outputs
    Content-adaptive de-flicker filtering for interlaced displays
    Xilleon TV encoder for high quality analog output
    YPrPb component output for direct drive of HDTV displays
    Spatial/temporal dithering enables 10-bit color quality on 8-bit and 6-bit displays
    Fast, glitch-free mode switching
    VGA mode support on all outputs
    Drive two displays simultaneously with independent resolutions and refresh rates
    Compatible with ATI TV/Video encoder products, including Theater 550
    CrossFire
    Multi-GPU technology
    Four modes of operation:
    Alternate Frame Rendering (maximum performance)
    Supertiling (optimal load-balancing)
    Scissor (compatibility)
    Super AA 8x/10x/12x/14x (maximum image quality)
    *Specifications are subject to change without notice and may vary depending upon product sku*
    http://www.sapphiretech.com/fn/produ...gpid=169&grp=3
    regards
    [Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
    [Review] ASUS HD4870X2 TOP » Here!! «
    .....[Review] EVGA 750i SLi FTW » Here!! «
    [Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
    [Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
