About month ago I have found time and have completed my SLi phase-change up to the end.
I required very compact SS SLi system and did not want to use the powerful compressor.
The system was not necessary for records, but for good benching .
I used Aspera 2134GK and LuVe STVF-75, and my SLi evaps ( http://www.xtremesystems.org/forums/...&postcount=159 )
I used very short caps, about 2 x 2m 0.8mm to avoid problems with capacity.
I don't know what will be with G80, but with pair 7900 is more than enough for it.
At present the system is filled R502, but probably I still shall experiment with gases.
First I have filled system R22 much for checking leaks...
Then refilled R502...
Idle tems:
Loaded... about 2 x 150W:
Thx
