Results 1 to 25 of 52
Thread: Rapty's Vapo LS mod by Johann
Threaded View
    Aug 2005
    Pretoria, South Africa
    These days I dont really post mods here anymore but Rapty asked me to post progress of mod so here it is.
    Rapty asked for a more silent and powerfull machine for his conroe.
    As you all know the obvious first thing to do is change compressor to NL11F. The stock LS compressor is noisy and not too powerfull. I still dont know why Asetek uses this compressor. NL11F on the other hand is nice and smooth and alot more powerfull.
    Next is a bigger condensor to handle the little bigger heatload from compressor and CPU and enable rapty to run fans at reasonable setting instead of full.
    Lastly a new evap lineset (Dimas v 4.1) I like the Dimas evap kit. Performance is good and mounting options good also. I added a accumulator as usual these days because Im not a fan of floodback and I like to make the captube around 2-3 inches shorter for the little warmer Conroe chips.
    Captube is 2.7m 0.031 on this one.
    Last time I had a stock LS on my loadtester at 150w I saw around -20c to -25c or so. After the mods I expect to see a load temp of around -42c to -45c so I would guess around 15-20c increase with less noise
    Some pics:
    Original unit as I received it:
    Replacement parts:
    ADDED:
    Step 1:
    Vapo removed. At least the controller, 2 fans and LCD screen remain . I believe the warranty is now void
