People seem to swear by Core Temp saying that this new fangled piece of software will give you 100% accurate results to what your CPU die is, and has killed the need for onboard motherboard sensors from the last 20 years. To this I say in theory this is a good idea but in practicality Core Temp is still a beta program with some room to change.
The reason that people seem to have temperature 10-15 degrees high is that the TCaseMax is set to 85 when I believe it should be 100. On my Core Duo it is 100. What Core temp is doing is taking a delta and subtracting that number from the TCaseMax to give you a temperature from each core. After numerous processor remounts and trying other things to get temperatures down, I have come to this conclusion. When running 2 different mobos with my E6700 I found that it was exactly 15 degrees higher than the internal temperature (infinity 975 and p5w dh) when using excel to map the data. This happened time and time again at given times from hardware monitors and Core Temp.
So today I purchased an e6300, volted it to 1.65 placed a digital thermometer between the IHS and the standard heatsink. Opened it up and let in run. I got into windows for about 3 minutes (processor is fried now good experiment). The digital thermometer read the temperature between 1-2 degrees different then that of the motherboard cpu reading again and again Core Temp was 15 too high. The other thing is on throttle watch, Core Temp read 100 degrees C before it started to throttle. Anyone else can try this experiment as well. The Proc will not throttle till 100 in Core temp. Thanks.
can't be right
, mind test this to get the "truth" out ?
