Results 1 to 20 of 20
Thread: Dell 2407fpw released today! There's a review too!
Threaded View
    Mar 2005
    Houston, TX
    Arrow Dell 2407fpw released today! There's a review too!
    As most of you may of known already,
    the Dell 2407fpw is a updated Dell 2405fpw with HDCP compatibility and some tech improvements.
    I'm guessing the reason for the delay was because they wanted to release the panel with the Dell XPS 700 and the Dell M2010 like they did with the Renegade + the 3007fpw.
    For the small REVIEW, scroll down to the "Links:" section below
    Breef specs on the 2407fpw:
    *What is in red represents what changed
    Panel: Samsung S-PVA
    Size: 24" Widescreen
    Response Time: 6ms (gray to gray)
    Color Support: 16.7 Mill. (8-bit)
    Contrast Ratio: 1000:1 (typical)
    Luminosity/Brightness: 500 cd/m2(typical)
    Max Resolution: 1920x1200 (WUXGA)
    Aspect Ratio: 16:10
    Pixel pitch: 0.270 mm
    Weight: 22.1 lbs (10.02 Kg)
    Other stuff:
    - HDCP compatibility
    - new xxx7 series Bezel
    (case)
    - DVI-D, VGA, S-Video, Composite and Component inputs.
    - Integrated 9-in-1 flash card reader
    - 4x USB 2.0 ports
    Price:
    ~$950 for 3-Year Warranty (atm)
    ~$980 for 4-Year Warranty (atm)
    ~$1,000 for 5-Year Warranty (atm)
    Links:
    - Daily Tech:
    http://www.dailytech.com/article.aspx?newsid=2635
    - PC Authority REVIEW:
    http://www.pcauthority.com.au/review.aspx?CIaRID=2947
    - Dell's site: (3yr warranty version)
    http://accessories.us.dell.com/sna/p...19&sku=2407W3Y
    Comment:
    The LCD being compared in the review is the Eizo FlexScan S2410W, which is practically THE best 24" LCD to date, but it costs a lot of money and its not HDCP compatible. Its mostly for professional use, or frikin rich people
    Considering the price and how well it performs vs the Eizo LCD, this could be THE best 24" LCD to date.
    BTW, sorry guys about the LCD Guide :P Its a bit out-of-date atm.
    I've been a bit distracted with other things so I have'nt been able to dedicate some time to the guide.
    Im taking my first SAT Reasoning test on June 3rd, so hopefully afther that I'll have my head clear to dedicate myself on the LCD Guide.
    Im planning on finishing all that stuff I didnt finish and Ill add the new LCDs and Ill remove what's old. Ill probably change the organization a bit so it looks more slick
    Cheers to everyone
    -Turok
