Page 59 of 173 FirstFirst ... 9495657585960616269109159 ... LastLast
Results 1,451 to 1,475 of 4323
Thread: The OFFICIAL MSI K8N Neo2-939 tips and tricks guide thread
  1. #1451
    Nov 2004
    For the voltage, in cpu-z i have 1,552v , SpeedFan & Everest 1,55v however in bios i set it to 1,7v ... with CoreCenter I have 1,7v ... I set to 1,85v and I get 1,680v (cpu-z)
    harpyboy, have you got pc3200xl corsair ? if yes why don't use divider 166 ?
    I will StressPrime this night (yes in france, it's 00h47 am ... and I work tomorrow .. erf) at this spec:
    cpu: 303*9 @ 1,55v
    ram: 248 - cas2.5/ras6/rcd4/rp&rrd3/rc7/fc14/rwt3 - weak mode - mtrr continous (small description ... :-P ) and it's 2*512Mb Corsair tccds pc3200xl dual channel ...
    goodbye.
  2. #1452
    May 2005
    Los Angeles
    Quote Originally Posted by Sonic9
    cpu: 303*9 @ 1,55v
    goodbye.
    nope not the XL... this is literally the first 2-2-2-5 PC3200 corsair came out more than 2 years ago.... it max out at 230mhz...
    Intel Core 2 Duo E6400 | Asus P5B Plus Vista Edition | OCZ PC2-8500 SLI EPP 4x1GB
    XFX 8800GTS 640MB | SilverStone Strider 560W | Creative X-Fi XtremeMusic
  3. #1453
    Jan 2005
    Anyone got the files I need them and I can't seem to get them from the site registered already, I hate sites that make you register to veiw images and such.
  4. #1454
    Jan 2005
    nvm I got them if you want them just email me ill send them, if you don't feel like registering that is.
  5. #1455
    Sep 2004
    does this new bios officially support the Venice processors? i don't like my cpu being identified as a 0.13nm processor
  6. #1456
    May 2005
    Los Angeles
    Quote Originally Posted by 4rory
    i hosted it on my server alredi..
    refer to post #1458
  7. #1457
    Sep 2004
    any of you guys gonna get the new DFI nf3 mobo?
  8. #1458
    Sep 2004
    FL
    I have a question about getting an OCZ booster, will I have to worry about my memory's temperature or does that not really matter much? B/c I know at 2.85 V via bios it does feel quite hot
    Main Rig:
    2 x Dell 2001FP 20.1" TFT Monitor
    AMD X2 4400+ @ 2.6Ghz
    DFI LANPARTY UT NF4 SLI-D
    2 X 1GB Mushkin Redline XP4000 [3-3-2-8 @ 2.7v]
    BFG 7800 GT OC
    WD Raptor 74Gb - SATA
    Maxtor 120Gb - SATA
    Maxtor 250Gb - IDE
    Creative Sound Blaster Audigy2 ZS
    Logitech G5 Wired Mouse
    Logitech Z-5500 5.1 Speakers
    PC POWER & COOLING TURBO-COOL 510 DELUXE
    Water Kit: DD A64 TDX 1/2", Thermochill 120.3, Hydor L35
    ZTCDESIGN.COM - Web Design/Hosting/Game Servers
  9. #1459
    Sep 2004
    put a fan over them
  10. #1460
    Jan 2005
    I have a strange issue with the new bios. I tried both the mod and normal version and it wont let me enter the bios setup menu. Pc boots and sets the ram to 2-3-3-8-11 1T and sets the san diego 3700+ at 11x200 which is ok. When i press delete it says unable to load bios setup and just sits there.
    If i let pc load it does so fine and im in windows now with the new bios.
    I used winflash to flash the bios from windows ive since reflashed it within winflash but still same issue i flashed from 1.8 official bios and cleared cmos. I flashed with the multi set to 11 and the htt 200.
    Any ideas why its not working?
    (Could it be a cold bug)
    Specs
    3700+ san diego
    2x 512mb pc4000 ballistix
    Vapochill PE
    ati AIW 9800 pro
    2x seagate barracuda connected on ide
    dvd burner connected on ide
    Edit
    In 1.8 bios it worked fine for me but when i went into hardware monitor it used to freeze when detecting the cpu temp. Does the new bios show the cpu temp on the main screen? maybe thats why.
  11. #1461
    May 2005
    Los Angeles
    both BIOS 1.8 and this beta 1.9 works fine for me.
    i don't have any issues with temp monitor either....
    u r using vapochil ? wat is the temp... this might be the issue for reporting too low cpu temp
  12. #1462
    Jan 2005
    Temperature is about -25 degrees idle and -10 load yes i think it could be that to but there is not a lot i can do about that. Hopefully the official release will cure this problem or maybe a moded version will work on this. Pehaps other people are having this issue.
    Gonna try to boot when vapochill hits like 5 degrees and see if that helps but first i need to find out if its safe to start up like that.
  13. #1463
    Sep 2004
    was the memory issue only if you use a divider?
    anything special i need to do to use TCC5 based ram on this board. I think it is TCC5, it could be TCCD but i doubt it.
  14. #1464
    Nov 2003
    Suomi/Finland
    Opteron 175 @ 2.8GHz+, DFI nF4 SLI-Expert, Gainward GF8800GTS 640, 2GB ram (1GB/512MB for testing).
    Member of OCTeamFinland
    Member of Team Skootterit
  15. #1465
    Jan 2005
    looks a bit like mine
  16. #1466
    Jun 2005
    Can you help with my problems. Read the thread below.
    http://www.xtremesystems.org/forums/...863#post914863
    I am going to try a modded 1.8 bios that has relaxed that relaxes internal memory timings when using dividers.
  17. #1467
    Jan 2005
    Have been reading around the other forums and other people also have the bios setup time out issue where you cant enter bios setup. Seems that its not a cold boot issue at all and something wrong with the bios under certain hardware conditions. Ill have to wait for the official release.
  18. #1468
    Mar 2005
    Chicago, IL
    Maybe some of you didn't notice that, here's remodded v1.36Mod BIOS http://www.geocities.com/nastechxtre...o2-13modR1.zip that we requested. Big thanks to tictac
    trc=13 clocks, trfc=15 clocks. Those timings will always stay on 13 and 15 no matter what divider you will use So if you had divider problems try it now! If your on venice or san diego grab this v1.8 one http://www.geocities.com/nastechxtre...eo2-V18-R1.zip
    EDIT: Ok, here's rev.2 of v1.8 BIOS with same tweaks as above + much more cool stuff. Refer to this post http://www.xtremesystems.org/forums/...254#post915254
    BEST BIOS I EVER USED!
    Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
    AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
    Long Live DFI.
  19. #1469
    Jan 2005
    Quote Originally Posted by need.for.mhz
    Thanks for the info mate.
    Im trying 1.8 r2 now seems good so far tictac makes really good bios files so i hope he makes more for neo2
    This bios does seem to be more stable for me even though i used to use A64 tweaker to set the timings anyway its better with the bios it seems.
  20. #1470
    Jan 2005
    Quote Originally Posted by Electroid
    What chip is that green heatsink covering. Mine doesnt have a heatsink on it worth putting one on?
  21. #1471
    c[_]
    Nov 2002
    Alberta, Canada
    been working on 1.8r2.. great bios tictac!
    All along the watchtower the watchmen watch the eternal return.
  22. #1472
    Jan 2005
    Has anyone replaced the noisy fan fot a passive HS on the chipset? Which model? I hava a NV Silencer 5, so my options are limited... but I sure would like to get rid of that 5000rpm annoyance.
  23. #1473
    Mar 2005
    Australia
    well theres not alot of clearance at all with the Silencers... But the chipset doesn't run too hot, so i bet one of the Zalman 'sinks will work fine. Just clip the pins that get in the way down to size .
    I'll probably replace mine with a Zalman NB47J, trimmed to fit ofcoarse. Though i have alot of clearance with my current graphics card, only about a quarter of the zalman will have to be trimmed, if at all.
    I think the bearings in the stock chipset fan got shot - its increasing RPM by the week. Its almost at 6000rpm now! :S
    Opteron 170 @ 3.0Ghz on air, Opteron 144 @ 3.1Ghz on air
  24. #1474
    May 2005
    Los Angeles
    i think for overclocking, better to use one with fan tho... i hav the silencer nv5 too.. doesn't seem to fit any passive heatsink capable of decent cooling... i really love to get a tall nice passive heatsink for it.. but we are the one who wanted a 6800
    weird that you said the chipset fan is noisy... i can't really hear it.
  25. #1475
    Nov 2004
    For me, I use SpeedFan and I set the Chipset's fan to 70% and it isn't noisy ...
    Moreover I wait the bios 1.95b with Multiplier fixed !!!!!
