nice but i'll wait and see the nf4 xpert mobo, also i wont need to learn almost from 0 with the xpert mobo
thanks for all the info
p.d. i'm sure i read somewhere before that ati would made a 4 layer pcb mobo
Expert is going to be like the RDX200, if you think you won't need to relearn then im sorry to say you are wrong.Originally Posted by metro.cl
If all boards worked the same it would be pretty boring now wouldn't it?![]()
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Originally Posted by Tony
i like to learn but not from 0 every time![]()
As I feared they made it with the 8 pin CPU 12V connector, preventing many from using it unless they buy an adaptor... if it exists...
Thermaltake Xaser V8000A * Enermax EG701AX-VH Coolergiant 600W * DFI LanParty nF4 Ultra-D AD0 * AMD Opteron 165 Denmark * 2x1024 MB OCZ PC3200 EL Platinum XTC * Sapphire Radeon X1900 XT 256 MB * Western Digital WD740ADFD, WD2500KS and WD5000AAKS * Creative X-Fi XtremeMusic * NEC ND-4571A * Dell 2709W * APC Smart-UPS 1000 VA
Im saying they are both fine boards, both have plus points and both have negative points. Im not going to judge them till I have both here.
Jason, the CF-BT is a direct copy of the reference board with some minor tweaks to traces going to the dimms, the board already does 300+ fsb easy.
There will be a single 16X version from many companies, Sapphire have the PURE range which features grouper, DFI tell me there will be a second BT board based on grouper also.
Abit have a board with many features copied off Halibut aslo so this may be a good clocker as well.
We will find out over the next few weeks im sure. i have been offered PURE and i can probably get the Abit also, the DFI's will come a little later.All in there will be an explosion of boards over the next 6 weeks, many have the next generation voltage regulation etc so should be a move forward.
Tony AKA BigToe
All sounds good to me, just gotta wait for the reviews and take the plunge at Xmas.Originally Posted by Tony
G
Tony, noticed you say you tested with VX.
Any issues such as those i constantly encounter using my Ultra-D with 2.6V being fed on boot up even though 3.4V in BIOS, therefore no boot?
Tony, I noticed the board has the 8pin PSU connector rather then the P4 4 pin. Any idea if users with power supplies from last year with the 4 pins need a new power supply? My PCP&C has 4 pins and it would suck to have to replace that.
Thanks,
D
4pin will work afaik.. but 8pin will definitely be better (they don't put it there for no reason)
as for PC&C u can send it back and they mod it for u @ a price of 20 if i'm not mistaken
What the big deal?
Venice/Sandy A64's are SUPPOSED to be able to do 1T 4x512M @ 200Mhz. The Winchester was limited to 166Mhz.
Call me when you get 250Mhz 1T out of 4x512M BH/CH or 300Mhz 1T out of 4x512M TCCD.
Meantime, is the Vtt issue cleared on these boards, or not? DFI needs to implement the heatpipe cooler for the chipset that Asus/Abit have. That stupid hsf on the ATI chip is just not gonna cut it longterm.
The 1,000 point drop in AM3 1T vs 2T is what, just over 1% difference? Hardly worth running 200Mhz 1T rather than 300Mhz 2T you'd get out of the same TCCDs.
Eye on the prize people.... Vtt fixed, Crossfire working, chipset cooled correctly, USB performance at least equal to NF4, and SATA raid performance.
GA-MA790GP-D4SH, 965BE, 3.8Ghz
Ultra120E, 4x2G Gskill 1066
2x 150G VRaptor raid, WD640AALS
8800GT 735/940/1685, LG-BluRay
venice and sandy were never 4x512MB DDR400 at 1T only 2T - the improvement was only to allow DDR400 with all banks populated at 2T instead of DDR333
im surprised no one has asked this yet:
so whats 4x512 utt/bh do under volts?![]()
Or better yet, 4x512MB old BH5?Originally Posted by Revv23
Formerly XIP, now just P.
I tried 4BH5 1T and didn't have much luck, it will run but not memtest stable. The stables runs were with 4XTCCD at 2-2-2-5.
4 pin connectors will work, but as mentioned 8 pin is better.
I ran VX last night and had no boot isses at 260fsb, it booted fine for 10 reboots and then 5 more after a 15 min cool down.
I have run memory dividers without issue, there should be no isses as remember the memory controller is on the CPU and that is a factor that has not changed.
I have had issues with my 4000gold, not sure whats cusing them yet so won't comment further till i know exactlyt what the issue is, as fo my 3200Plat and 4000EB kits they boot fine with the same 2gig density so itssomething weird i think probably just with my kits as they work fine on Halibut and the vanilla NF4 from DFI.
Tony AKA BigToe
Ok, then it's not worth for me anymore. I think this "4x512MB 1t Feature" is absolutly on his limit, no plus for the board! Near to instability, even @ 200Mhz and with TCCD.Originally Posted by Tony
(imho)
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
It may be just my dimms not evenly matched, keep an eye on the members posting their experiences as they may have more luck than i did.Originally Posted by GravediggA
Tony AKA BigToe
Yep, let's wait and see what's coming up if the board is in stock and alot of ppl can test this.
lol
WOW!Originally Posted by Grayskull
Part of the Q I have was asked before, but without the answer...
Tony, do you have any idea what NB Core and NB Analog Voltages are for? Also, what does NB-SB Port Configuration option do? Thanks in advance
Great preview... I hope you'll find the way to work those issues you've had so far![]()
Analogue voltage i have no idea but will askOriginally Posted by bachus_anonym
NB core is chipset voltage
NB-SB enhanced state is reduced latency between the chipsets.
Tony AKA BigToe
Love to hear more about the VX 'issues'. I know you said you wouldnt post until you know what they are, btu can you explain the symptoms?
Is it just a no boot issue, or instability, or????
Tony, would you say there's any chance of getting 2xTCCD + 2x5B -D to run at DDR400 1T at 2.5-2-2?
