DFI NF4 Ultra-D
FX57 CABCE 0516 WPMW
Antec 550W TruePower2.0
2 x Raptors
Corsair 3200LLv1.1 | OCZ GX | TEAM BH-5
Chilly1 DI Container
Liquid Electrical Tape
Acetone
Funnel
Neoprene Tape
Insulation : (listed by steps)
Liquid Electrical Tape around socket
- Liquid Electrical Tape will take approximately 20-30minutes to dry depending on how thick you apply on the motherboard. It will peel off easily from your motherboard so don't worry.
Neoprene Tape on Liquid Electrical Tape and gaps taped up with electrical tape and holes covered by Liquid Electrical Tape
- Next use some neoprene tape on the liquid electrical tape for extra insulation and for the extra height for better contact with the cylinder neoprene piece.
- Tape some neoprene on the back as well just in case.
- Cover the gaps with electrical tape
Test Mount
Dry Ice Run
- Best run for me is about 50ml of Acetone then some crushed ice followed by normal dry ice pieces.
1M
8M
32M
After Run
- What I do is i remove all cylinder neoprene and then pour out all dry ice from the container.
- After that I add water into the container to warm the container so that the bond between the container and processor will loosen and then give it a good twist and it will come off easily.
I have about half an eski of DI left.. will be doing more benching again tomorrow
2nd day :
first bad mount and ran out of ceramique.. tried AS5 and it didn't work well so had to cancel subsequent runs
had some dry ice left so i had some fun with them
Removing Insulation
