Results 1 to 10 of 10
Thread: Interesting things about Crucial Ballistix
    Jun 2004
    The Baltics
    Check out experience of Xtreme members:
    http://www.xtremesystems.org/forums/...threadid=39329
    And check out Anandtech's most recent memory review:
    http://www.anandtech.com/memory/showdoc.aspx?i=2145&p=9
    257 fsb 2.5-2-2-5 with 2.85 volts on i875?
    Maybe OCZ guys have some comments on that, could the Micron's new 5B-G chips indeed suddenly be so good? Or just handpicked Crucial stuff?
    away & gone
    Apr 2004
    i definitely say it's handpicked
    A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    thephenom
    Why - did you play around with any regular Micron sticks?
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    -100c Club Member
    Apr 2003
    Riverside, California
    Gulp... plopped down $300 and ordered those 2 sticks... (1gb).
    Now that I have both A64 and p4 rig that are decent to play with, I will see if memory does perform up to what it claims to on Anandtech... (They mentioned it being great on A64 just like on p4).
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
    Mar 2004
    Virginia
    gulp is right. i hope mine aren't duds.
    Xtreme 3DMark Addict
    Sep 2003
    it looks like people cant get good timings so good luck to you
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Apr 2004
    Originally posted by IvanAndreevich
    thephenom
    Actually I have, I have 2X512 single sided Micron PC3200 which uses the 5B Rev C chips. They are nice in terms of FSB, but mine doesn't like running at tight timings. The tightest it would go on high FSB is 3-3-3-5 @ 243Mhz w/ 2.85v (CPU limited) Also runs at 2.5-3-3-5 up to ~230 or so, 2.5-2-2-5 will be no post at most FSB settings. That's all the testings I've been doing.... I'll play with it more when I have more time. And the fact I haven't seen Ballistix out-OC OCZ EB is another interesting backup for the idea that the review sticks are cherry picked.
    Dec 2002
    Jersey City, NJ USA
    honestly I have heard the g-die can be awesome, but the yeild is crap. You may get some really good ones, but most won't do as well as the first post. They are not viable then as an overclockers mem, cause you will have to many varying results.
    So in all they seem to be cherry picked.
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    I'll stick with bh5 =/
    Level 80 UD Death Knight on Murmur (Beta)
    Apr 2004
    Here's a quote what bigtoe said on the matter in another thread
    Guys
    I have been looking at the Balistix and it does seem Wesley was sent some very cherry modules there, even the comments section on the review has people questioning whether the micron was cherry.
    We have C and G, C is still better, when G is better than C we will move to it.
    I have read now 5 forum threads on different forums all showing EB still doing a lot better than the balisitix....if you want proof my DFI thread at the top of this page has me doing ddr600 at 3.1v 3-2-2-0 with 3500
