Results 1 to 24 of 24
Thread: Dfi LanParty rev B , Vdd and vcore modds(what to do?)
    Jan 2003
    Sweden
    Post Dfi LanParty rev B , Vdd and vcore modds(what to do?)
    If anyone cane help me with this....(holst or some)
    Member
    Dec 2002
    Leics UK
    I sure can
    Can you post some high res pics of the board and ill stat looking into it.
    Jan 2003
    Sweden
    Originally posted by Holst
    I sure can
    I dont know if this is good enogh for you..
    http://upl.mine.nu/uplfolders/upload...atproblems.jpg
    Member
    Dec 2002
    Leics UK
    Can you please tell me what it says on the chips ive circled in green.
    Im not sure if I have the right ones for Vmem and VDD, a better pic may help as its a bit hard to make things out on that one.
    Jan 2003
    Sweden
    First we take the vdd chip"maybe its the @ red
    "Evil spook write this in one threat"
    yes it will. i beleave the vdd mod is a 5k ohm pot from pin 3 of the tiny IC with 8legs under the agp slot.
    same chip as the AN7 uses.
    CM358
    34M
    CL81
    Blue:
    HIP66
    0XXXX
    P323607
    It´s very hard to see :/
    Vcore modd:
    Did the volt mods (vcore and vsense)"bldegle2"
    Pomona grabber to 47kpot, then to ground. Grabber ends modded slightly so they clip and hold without touching the legs on either side.
    you NEED to do the Vsense, or the board will crap on the overvolt at 2.1 and beyond.
    50K for vsense and vcore?
    http://www.xtremesystems.org/forums/...threadid=25690
    Member
    Dec 2002
    Leics UK
    My memory suxorz..
    I did the VDIMM mod a few weeks aggo.
    http://www.xtremesystems.org/forums/...748#post307748
    Member
    Dec 2002
    Leics UK
    Ill be back to tell you the others tomorrow as I have to go to sleep.. work tomorrow
    Jan 2003
    Sweden
    K "Bump"
    Member
    Dec 2002
    Leics UK
    For the Vcore, I beleve this guide will help.
    http://forums.extremeoverclocking.co...c/21990-1.html
    Please check that you DO have a 6301 before doing any modding, I cant read that pic clearly...
    Member
    Dec 2002
    Leics UK
    VDD mod is apparantly the same as on the NF7/S
    www.motherboardfaqs.com have a guide... please check that the Vreg is in fact the same before you do the mod...
    Nov 2003
    Netherlands
    the chip is the 6301.
    pin 7= vcore
    pin 10= OVP
    I tried it and it works fine:
    I was raised by a Portuguese ninja who taught me to fly
    www.ministry-oc.net
    Member
    Dec 2002
    Leics UK
    Brilliant, thanks allot for the pic and the confirmation Doctor.
    And Welcome to Xtremesystems, looking forward too seeing your work again
    I dont suppose you have a pic of VDD as well do you?
    Member
    Dec 2002
    Leics UK
    P.S.. what Vr's did you use?
    Nov 2003
    Netherlands
    Post
    I dont have a pic of de vdd i will make 1 soon (from witch area you need a pic ?)
    I used 50K 10 turn vrs from a store in my town.
    www.ministry-oc.net
    Jan 2003
    Sweden
    I think maybe is in area red(my pic)
    But were to dectect the vdd..only founded were to detect the agp v
    Nov 2003
    Netherlands
    to bad u cant read the text on te chip but i think lasviking checked that already
    www.ministry-oc.net
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    Following the instructions for the Vdimm mod, a 100kohm VR is called out.
    Anyone who's done this mod, can you tell me the approximate ohm value your VR is set to? My local Radio Shack has no 100k VR's available at this time. I *do* have some 10k ohm cermets so if the approximate range is 10k or less I'm good to go this weekend. Else I'll have to wait for some 100k VR's to come in.
    The plural of "anecdote" is not "data."
  18. #18
    Jan 2003
    Sweden
    I have 100K@56K and get 3.0v = 3.45v
  19. #19
    X. I. P.
    Jul 2002
    Hmm, maybe I'll try a 50k fixed and use the 10k to trim it. Thanks Lastviking!
  20. #20
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    heres my pic of teh vdimm mod i did.
    that goes to a 200k ohm VR, i have it set to 63k. last viking has his at 58k, and setting bios to 3.2 yields 3.68volts.
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
  21. #21
    X. I. P.
    Jul 2002
    Thanks, Evil_Spork
    If there's that much variance needed (at least 58-63k) then I think I'll just wait 'til I get some VR's with a wider range than 10k. It would be just too much risk to build one up using fixed resistors and a 10k to chance it.
  22. #22
    AMD Fanboy
    Jan 2003
    i just set mine to 63k because i have a one turn 200k ohm pot.. so its REALLLYYY hard to set it. i just picked 63k cuz it was close. and 58k was the only referance point i had.
  23. #23
    Jan 2004
    Frankfurt, Germany
    Help!
    Today my Lanparty B arrived and I just set it up.
    I tried 3 different beta bios and none of them helped me to get 230mhz fsb stable. My Ram is Corsair3500.
    Could someone with high fsb please post some important bios settings and which bios ver. you're using ?
    Thanx !
    EDIT
    I'm pumping 3,2v now up in this beeeeatch!
    Now it's at least Windows stable with 240mhz DC (and 5mins Memtest stable) :P
  24. #24
    Feb 2004
    Naples [Italy]
    hello guys!
    can i go over 2,1v on the cpu?
    with the vcore/OVP mod i can increase the v max to 2,1v...it's right?
