Chilly1 Evap, Condensation Issues.
I'm running a chilly1 evap, with his mounting kit and insulation.
I have had nothing but issues with condensation. If I turn the machine off for a little while (30mins), water will start to drip out from around the socket.
The foam that goes on the evap seems to be both too tall, and too thick, but it was what was provided with the evap and mounting kit.
It recently killed my p5wd2, and I can't continute to leave the machine on 24/7 so that the snow doesn't melt into water.
When removing the cold evap, there is snow all around the inside of the mounting bracket. The socket was greased up, and the mount was as tight as it could go.
Anyone have ideas?
{PMS}fishy: how much voltage can we give it?
Gautam: as much as you want
930 @ 5250 -- P5WD2-P --vDimm --vNB --vDroop --vCPU
Custom {PMS}fishy Mach1 /wChilly1 Evap & Special Mods
Trouble Shooting 101:
1. RTFM
2. Repeat Step 1
830 @ 5555
631 @ 6060
920 @ 5256
930 @ 5631
- You may not post replies
- You may not edit your posts
Forum Rules
