Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: 965XE Cold bugged
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    965XE Cold bugged
    I tried to to push the 965XE chip under the cascade but I had start problems and the chip would not start at the warmest temp, it only booted once and that was short lived bench session.
    I estimated the start up evap temp at -50c, I had to unplug third stage and let it warm up to start up. I did this a few times.
    I will swap out chips and try another soon, I wanted to really push the Presler on P5WDG2-WS 8 phase power board.
    With the odd problems with cat 6.4 I am having crossfire problems when I restart and not being able to restart 100% of the time, its more like 25% with the driver failing on this Asus WS board.
    Everything is fine under vapo and so far, I can break 6Ghz and bench at 5.6Ghz or so.
    http://valid.x86-secret.com/show_oc?id=86905
    This chip/board combo is stronger than the P5WD2-E and 955XE chip. I will start a new thread on Vapo once I get more benches done.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2004
    It's not that your WS M/B got problems with cold? Doubt the cpu is the reason.
    Intel FTW!
    Beanna
    Jan 2004
    Israel
    so cold bug came to intel's world as well ?!
    Jun 2002
    Las Vegas
    Random chips have shown lower showing lower start temps for about a year now. This is the lowest Intel chip temp I have worked with so far. Once started I can go to max temp and I can reboot no problem. If I cycle power then I would need to drop back to -50c.
    A good P4 will fire upwards to -120c
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Mar 2004
    So if I got you right you can't go over say -50 on boot but while you're in windows you can go for full speed on the cascade without problems and then start benching and such?
    *EDIT* I've to go with esdee on this one FUGGER *EDIT*
    Intel FTW!
    Beanna
    Oct 2004
    Athens,Hellas
    is your problem only powering up the board? this sounds more like cold boot and not cold bug.
    if this is your first night in xtremesystems,
    you have to overclock.
    Jun 2002
    Las Vegas
    Well, "bug" on AMD may not be exactly the same.
    Chip is bugged when booting past certain temp. Those who go here will know what I mean.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Mar 2004
    So it's not like the AMD coldbug that it won't work on a certain temp? Just booting? It's fine otherwise?
    Intel FTW!
    Beanna
    Jun 2002
    Las Vegas
    Correct
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Mar 2004
    Thank you very much, now I can sleep properly So have you got any trick to get into windows then with the cascade on?
    Intel FTW!
    Beanna
    Jun 2002
    Las Vegas
    I can adjust expansion valves on second and tird stage to get as warm as -62c on the evap.
    I can unplug the third stage as well. This is not a good option as I have had a few failed starts and could damage the compressor if I restart too soon.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Oct 2005
    UK
    At least the problem is isolated to booting up only. Do you have any theories on what could be causing this?
    c[_]
    Nov 2002
    Alberta, Canada
    usually a coldboot problem is due to the motherboard.
    neo2 platinums being prime examples.
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Legend
    Jun 2005
    Taipei, Taiwan
    Maybe some ASUS 975X mobos have coldbug.........
    Jun 2002
    Las Vegas
    Intel says the thermal trip for heat is being kicked in and preventing the machine from starting. This is self protection of the core working incorrectly.
    This might be fixable in bios
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    With AMD the "cold bug" is a result of the memory controller and clock gen being on the core, with Intel it would have to be related to thermal protection of the core.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Feb 2004
    sounds like the problem i had with a 920 and a 631 on dry ice (wouldn't boot, but if i lifted off the tube for a second it would and function perfectly until i tried to reboot). 640 and 830 worked well though, perhaps it's a 65nm thing?
    930 @ 4.4 & P5WD2 (vcore + droop, mch vdd, ddr2 vdd)
    4x512 Micron D9
    7800gtx 600/1470 (vgpu + vdd)
    h20
    my heat
  18. #18
    Jul 2005
    Phase-cooled? Oooooh yea!
    try getting some ampers per hard-wire to warm up a little...
  19. #19
    Apr 2005
    Italy
    Hi Fugger , we have same problem with our 955ES and Asus p5wd2-e Premium..
    at -50° mobo dont boot and this is a bug on CPU but only at the start.
    So let's try this :
    Power up your Phase and enter in Bios quickly . Then wait the temp drops under -100° and set your cpu for a boot at 6 Ghz or over.
    Yuo will need -120° for booting at 6 Ghz ...
    When you ready , save your setting and exit from bios .... Yu will boot whitout problem ..
    If your sistem crash :
    power off phase
    wait the temp rise at -50°
    power up mobo, first boot will fail !
    power off , wait 5 sec. then reboot again.
    power up phase and mobo and enter in bios quickly.
    This worked for us , i hope this can help you.
    PcTuner Staff
    Shark Team
    7.2 Ghz club
  20. #20
    Nov 2005
    The Netherlands
    Those XE-Preslers are very nich chips, though.
    Our 955XE was 5.6GHz benchable on DryIce.
    Yours did 6GHz with "not the best cooling You can get". If you solve those problems i think it`ll get somewhere near 7GHz.
    P.S. What Vcore are you running at ?
  21. #21
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    I'm sure you will kick out the hell outa the chip anyway - this is nothing causing a FUGGER to stop
    Good luck, as long as it can run under low temps but not boot who cares...
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
  22. #22
    -100c Club Member
    Apr 2003
    Riverside, California
    I am surprised people forgot... cold bug back in winchester in AMD time was actually cold boot problem. For same CPU, depending on mobo, some would boot at lower temp while some just won't....
    Variance got even more depending on individual stepping... (this is around where I bailed on phase for a while... after 4-5 winchester cpus and 6-7 mobos).
    Symptons clearly showed me that whatever is in bios to work with CPU to prevent thermal damage, etc just wasn't designed to work with the temp it wasn't really meant to be subjected.
    I get gut feeling same is true for these intel mobo and CPU.
    Have you tried totally different mobo yet Charles? Just to see if it boots up at colder temp on other mobo? (meaning non-asus)
    If you have bit off difference in where you can boot up depending on mobo, it obviously is something that can be worked with bios.... (as per willing to... well maybe they would do it for you :P)
    Presler is soooo hot though -_-; How much volt you crack up when you are on vapo?
    PS) and how do you insulate your mobo?
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
  23. #23
    Mar 2005
    Spain
    As said before this cold bug is not due to mobo. That's what i thought at the begining but is due to CPU. I tried disabling temperature monitoring with no go on a 920. Now with this 631 i had no problems booting @-70º on the same mobo... Hopefully is bios fixable...
    BTW, that 965 looks great, with some real cold it should get over 6ghz with no problems...
    Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
  24. #24
    -100c Club Member
    Apr 2003
    Quote Originally Posted by ^don.k's^
    Ok... try this... disable the temp monitoring and let the cpu get overheated... it WILL shut down despite the fact you disabled it :P
    All current crop cpu do have this last safety measure and mobo do come with support for this which can't be accessed by "bios" per say.
    Think of it as hard reset vs soft reset :p
    heatware: jinu117
  25. #25
    Mar 2005
    Spain
    Quote Originally Posted by jinu117
    Maybe a cpu itself feature ? if so, it wouldnt have nothing to do with the mobo...
