Results 1 to 16 of 16
Thread: DDC 12v Pump Mod *Pic's*
    -100C Club
    Oct 2005
    Essex UK
    DDC 12v Pump Mod
    I decided to follow the guide from coolercases.co.uk and attempt to mod the DDC 12v pump. This was mainly as i use 1/2 barbs and i wanted a better look and the bigger barbs will help flow rate..
    This pump is very quite and small so is perfect for a CPU and Gfx card setup. There are big and better but i plan to houses this in a Lan Boy case so need a small pump.
    Technical data
    * Motor design: Electronically commutated, brushless DC, spherical motor Voltage Range: 6 to 13.2 VDC
    * Motor rated at: 18W
    * Maximum system pressure: 22 PSI
    * Maximum flow @ 13.2 volts = 400 LPH
    * Temperature range: Up to 140?F (60?C)
    Tools & Kit
    Drill
    Arodite
    Filler
    1/2 Barbs
    File
    Sandpaper - 1200Grit - 600Grit
    Spray - Primer - Colour's
    Time Taken
    2-3Hrs depending on Skill and Quality outcome.
    The Pump Stock & Striped Down
    Phase 1. Fitting Outlet 1/2 Barb
    I had to drill out the centre and file down the edges and cut of the Plastic Outlet Barb as i was going to fit the Barb at the top.
    Fitting Inlet barb to 1/2
    I also added a 1/2 Barb to the Inlet and filed down the inside for increased flow altho its not showen in these pics. It was the same mentod as the Outlet Barb.
    Place & Seal 1/2 Barb
    I used AroDite around the Barb and checked It was sealed properly
    Filler & Tape the Barbs and Spraying the Pump
    Tape Up And spray the pump with primer and tape over the barbs, then check to see its flat and sand down with 1200grit Paper to smoothen off.
    The Final Outcome.
    I decided to go with Blue for the Top after i had to sand it back down to smoothen out yet again. Took some time but well worth it.
    Testing
    I run the pump for around 4hrs checking for leaks. It was perfect and i can say its a mod well done.
    The Conclusion
    This Mod has taken around 3hrs all in all and was a pain. I can say i would be alot quicker if i was to atempt it again as i was fussy about the final look when it was silver. It also was the first time ive used filler since having my old escort.
    Oct 2005
    Hey, is this 18w revision? ( I see orange impeller, but who knows ... )
    And did you notice any noise difference after modding?
    What about vibrations?
    Anyway, looks amazing and should perform very well
    And thanks for Pics!
    -100C Club
    Oct 2005
    Essex UK
    Quote Originally Posted by maratus
    Mate to be honest its for a project build, Im fitting water into a Lan Boy Case so havent had chance to test it.
    Altho when running it on the Bench when testing it really needed rasing as of the vibration was still alot.. Altho
    this was the first time id run it for more than 5minutes so not sure what it was like before.
    DDC 12 volt Pump
    Technical data
    Measures: (w x d x h) 62x62x38mm (without connections)
    Kind of engine: electronical commuted ball engine
    Nominal voltage: 12 V DC direct voltage
    Allowed voltage range: 6 to 13.2 volt
    Lifting height at 12V: 3.7m
    Max. lifting height: 420L/h
    Feb 2005
    Tennessee
    the orange impeller is the 18w version. Nice looking mod. I tried to order a 10w only to receive an 18w. If I keep this one, I am going to do the flow mod also, although I don't think I will go through the trouble like you did to fill in the top. I wish you had some pics of the inlet as I haven't seen anyone mod that.
    -100C Club
    Oct 2005
    Essex UK
    Yeah dam sorry mate, Basically what i did was cut the inlet in half and then arodite the barb which is cut, to the inlet plastic which is left on the pump. Then once it set i fillered over it.
    Sorry about that mate i really thought i had taken pictures of the whole project, a less learnt
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    whats the difference between versions?
    seems 18w would have more head?
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Oct 2005
    Quote Originally Posted by WeStSiDePLaYa
    10W has ~3.9m head and 420LPM
    18W has ~4.7m head and 600LPM + is a bit noisier (not too much, but noticable)
    Jun 2005
    sLOVEnia
    Is there a noticable difference in the performance between the 10W and
    the 18W version? I would like to keep my system as silent as I can, so if
    the difference is barely noticable, the 10W pump would be a better choice.
    AsRock Z68 Extreme3 Gen3 / i5 2500k / 8 GB Corsair Vengeance / Sapphire HD6850 / Crucial M4 64 + Samsung F3 500GB + F1 640GB / Corsair HX750 / CPU / GPU H2O / Sharkoon Seraphim rev.ATX
    Jun 2005
    seem nice
    -100C Club
    Oct 2005
    Essex UK
    Is this pump able to be controlled via voltage to regulate the noise output, As many buy this pump for low noise maybe this could be an option.
    Feb 2005
    Tennessee
    Quote Originally Posted by 4Qman
    I thought about this. The problem for most people is that a pump pulls a lot more amperage than fan controllers can handle. I have a large rheostat that can 10 amps/25watts that I have considered using, but that is way more than a fan controller.
    -100C Club
    Oct 2005
    Essex UK
    Yes i see, shame as the main thing this over the D5 is size altho the D5 can be turned down
    Also i check the pump im using is a 18w altho its stated to only push 420lph, this must be incorrect then. Im happy with the final outcome on this pump, just got to get the rest of the Case modded and ready
    Apr 2008
    sneakerN3T
    i remember seening the same project a second ago. but with a black top. anyway, great work.
    CPU: C2D e6300 @ 3360MHz 1.33125v bios 24/7
    RAM: 2x1GB OCz reaper pc2-9200 1203MHz 5-5-5-18 (Intel 1200MHz) 2.000v
    MoBo: DFI LanParty UT P35-T2r 12/24 BIOS
    Storage: 1xSeagate 80GB sataII, 2xSeagate 500GB sataII = RAID1
    VGa: eVGa GeForce 8600gts ssc edition 756/2140
    PSU: Corsair 850tx ((+12V@70A))
    Cooling: Tuniq Tower
    Case: Antec SoHo Server (Black)
    May 2009
    FFS stop nerco'ing old threads idiot
    Oct 2004
    Quote Originally Posted by timsarg View Post
    I think that's a little harsh... But the9093 seriously needs to realize that his post-count buffing is so obvious it hurts...
    You have to at least be somewhat subtle about it man.
    Jun 2004
    Simple pump mod mate, congrats.
    Extreme ways I know will part the colors of my sea, perfect color me | Arthur's WC Worklog with Lian Li PC-9
