Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: 4x1g full dimm WR DDR 617 & Micron 5BF Myth
    Banned
    Jan 2004
    Land of Buckeye
    Hi all, after several days test and effort, now, when you see that thread topic,
    you might be thinking about OPB is showing his cherry picked again now. However,
    let me seriously tell you right now, this is 100% not cherry picked but just randomly selected
    from the 30 pairs out of 100 pairs I have done for the SPD programming. I was quite surprised that
    characteristics of Micron 5bf is totally different from the other memory modules. Initially, I was very very frustrated
    when I saw Ozzimark can get over 290fsb 1:1 1t. For me, no matter how hard I tried,
    I have never got pass 285fsb except use upper divider when I ran fx60 under single stage(cold bug).
    Due to last time, some users also struggle and complain that their ram got weird spd just showing PC3200, so
    that's why I got to do the QC and do the SPD. After get used into it, I figured out this IC is, well I can't say it's King of 2GB set, but
    I strongly believe that all this results are based on the non-cherry picked and non-bias bench. If you really wanna say something,
    that might be on my PSU or Venus. Well, but I tell you what, most of these pairs passed DDR600, 1:1, 3-3-3-3-7-12...
    only required 2.78v~2.80v under ultra-D. Also, I found that the DS/DDS of Ultra-D is way more effective than Expert or Venus !!
    but for instance if you wanna run 4x1g 2t , you gotta use Expert or Venus for sure. Let's go ahead and discuss all these myth of Micron 5BF.
    Let's start from 2 dimm DDR600, Venus/Expert platform first:
    Conditions:
    Before we start, you will need to make sure, there is a beta bios 406 for all DFI nf4 series boards, go flash that bios first!!
    Here I must appreciate Tony really did a great great job, this bios play a big big role of 5bf can "easily" get on toDDR600 with that unbelievible
    tight parameters.
    Basically, we can look at the picture below, honestly, I was thinking about ozzimark has mentioned on the 5bf thread about we can try 2t first,
    so after I finished the SPD programming on the first pair, I set 300x11 under bios and certainly CPC option I set was disable. After I boot into windows
    I also think if I want to run 2t, why don't I just have all the setting are the tightest waywithout probles; therefore, initially, I did not set TRFC as 12 just like you
    see in the screen below. but I did set tras and icl as 8(cuz I don't want to jump up too much from 16cks) with TWTR as 1; and wow...it did not fail..
    But we all know , you will need to run that several times for 1m to make sure it's right. During this moment, when it was runing, I intentionally switch the 2t
    command from enable to disable (1t), and it also passed without any problem.I was really excited at that moment when I stared the 1t at the CPUZ 133 memory
    timing confirmation. so then I keep those timing as refernce and try to get the paten on 5bf. Certainly, the best way to confirm is running every length of super
    pi. so let's see here.
    From this screeny, we can see from CPUZ, my primary parameters setting is 3-3-3-0-7-8; I at least ran 5 times by using this setting.
    Please read through all the notes.
    super pi 1m:
    2m, are you guys aware of what 2 timings I changed? Yes, I changed Tras to 2 and ICL back to 16clks; honestly,
    256 really do nothing and even failed to complete calculation.
    Now, what about 8m? yup, I change TREF back to 3120(200mhz, 15.6us), Tras to 2 and then ICL as 0 clock; during this 8m running, I got couple
    errors, such as " not exactly run" or "not convergent in SQR"...that all happened around the 6~7th iteration. Therefore I thought that 2.78 won't be enough for
    running at DDR600 with those tight timing! (think about the TRFC as 12), so I restart and add from 2.84 to 2.87v(it's off about 0.04v compare with mbm5
    detected value), , no wonder, it just running smoothly all the way end.
    Now, here is the insteresting part about 16m, when I finished 8m running, I accidentally thought, holy xxxx, maybe I might not have to give that vdimm for
    more 0.03~0.05v, so I went back to check my setting and think if I get ICL relax a bit and set Tref as 100mhz/1.95us, I might have chance to do
    16m finish. Alright , here we go, this result verified my assumption as well.
    Now, it's the time to challenge the most difficult one though. Honestly, I got about 4 times fails before I understand the trick.
    First of all, from the results and ideas above, we can apparently sort out that most timings on the a64tweakers table are basically fixed;
    consequently, those variables related to our discussion are:
    TREF, TRAS and ICL
    Certainly, not just these 3 timings, before this step, you gotta completely understand some key factors, such as how to set DS/DDS, and remember, trrd can be
    set as 3
    as well as TWTR can be changed to 2 "in order to stablize a bit" (actually really not much! haha ); my concept is " Performance can NOT be hoding back due to
    lack of stability."
    THerefore, I changed ICL back to normal value 16, so of course I can't just backward, then I also put 2 as TRAS to balance that along with Tref switch to
    133mhz, 1.95us to complete this 32m calculation.
    ** well, I still think I need to be fair to show the camera pictures, 4 of them. If anyone live closed to Columbus, You are more than welcome to pay me a visit
    and ramdomly choose any two sticks , I can do my best to show you how to!
    Now the CPUZ verifiedmy 32m pic got verified number on that)
    **Also, we might want to check out about bench results from the Everest ultimate :
    well, how about Opteron? To be contiuned...
    Here are some results just verified what I said from above, ultra-D looks like no need that much vdimm and not that confused DS/DDS setting
    than either Expert or Venus
    before I post my 1m, 8m, 16m, and 32m, I also sure no problem to share the bios setting here:
    actually, you can see the timings I used under ultra-D are even tighter then Venus
    1m:
    So for the 2 dimm DDR600 1t , we now have rough idea how this ram is if you treat it correctly. let's see next, full dimm
    4x 1gb on DDR617 stability test.
    TO be next...
    4Dimm 1g x4 fully stable for DDR617 ; current WR
    Actually , you can see I was pretty closed to what I figured out the paten of 5bf later on, because what I thought at that moment of running 4 dimms
    is this merely just for 2t timings, so I can let the timings as tight as it could be, so if you look at that carefully even DDR617 2t timing like that will not be too
    bad though.
    CPU verified:
    windows captured screeny:
    Digital camera pics , took during running .
    Again, hopefully, this will clear some confusion,!! If you want to play micron 5bf, you gotta put a lot of effort, I mean a lot. Seriously.
    OPB
    Dec 2004
    Seattle
    Just insane numbers your putting up and a big thanks for helping everyone figure out how to set timings for 5bf. Congrats on the WR aswell
    Tim
    May 2005
    Camping your spawn :)
    Wow 4g @ 617 is sick, I cant wait OPB...
    Id like to see how the expert can do with 4 sticks as well, supposedly it can run 4 sticks @ 1t correct?
    Im guessing 1T would be about 280ish if that..
    Definately a TON of work youve put into these 5b F, hopefully this will help out some of the people here trying to acheive such milestones..
    Also gratz on ANOTHER WR... blah blah blah
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
    The un-extreme XIP
    Jul 2004
    nice work as always, OPB
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by Philosophy
    the only 4dimm 1t is around 200mhz, it can't be over 205 I think
    May 2005
    Quote Originally Posted by Onepagebook
    I see, looks as if my asumption was wayyyyyyyyyyyyyyy off then :P
    Either way, nice effort for the cronus..
    Their publicity is getting better every day..
    -Emo Philips
    Love and Peace!
    Dec 2004
    hiding somewhere!
    wow. i knew you've been busy lately, but..
    looks like i've got something to try now, see if i can get that last 3 mhz out of my sticks and hit 300mhz once and for all
    edit: 2T, but still. i'm having fun
    Got a fan over those memory sticks? No? Well get to it before you kill them
    Xtreme Mentor
    Oct 2002
    boston,ma
    very nice will have to try that on my venus
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Xtreme Cruncher
    Jun 2005
    MA, United States
    Great results OPB
    Is there an expert equiv to the 406 Ultra-D BIOS?
    Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Kevin
    Not to put down your clock here but was you running odd divisor correct enabled?
    If you were you are running the ram on a down clock, not unlike 180 mode.
    Please check and confirm?
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by Tony
    Kevin
    what exactly does that do, round up the odd memory dividers to the nearest even one?
    if this is the case, my results are incorrect
    i just checked with everest, getting around 7000mb/s. seems more in line with 300mhz, so i suppose that my assumption is correct
    the jedi master
    Jun 2002
    Quote Originally Posted by ozzimark
    http://www.xtremesystems.org/forums/...30#post1389430
    Tony AKA BigToe
    Xtreme X.I.P.
    Dec 2003
    Kevin
    I think you're right, Tony...
    This BIOS shot
    shows ODC as ENABLED so in fact memory is running at DDR540, not DDR600 I would assume (as he mentioned already) same goes for ozzimark's case and they both run ODD multiplier (x9 and x11) as well...
    Oh well, I don't like that new option at all (Odd Divisor Correct)
    Banned
    Jan 2004
    Land of Buckeye
    what you talking about?
    then I think Michael, you got to understand 2 things.
    1. Also correct CPUZ is wrong, so email Franck
    2. Regardless that is NOT DDR600, according you said is DDR540 and who said it can't be DDR500 before?
    I understand what you mean very clearly
    Oh, I forgot to say,
    I can run 329 bios with DDR600 as well, want me to run that?
    How many photo or video tape? up to you
    or you wanna come to Columbus Ohio?
    Dec 2005
    Brooklyn, New York
    If you can run with that bios which doesn't have the ODC option, then congrats! GJ!
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    May 2005
    This I wanna see.
    So 308 woth this option would make the ram = what exactly, im a bit confused here..
    would the multi round up or down?
    -Emo Philips
    Aug 2005
    Perth, Western Australia
    Mmm bandwidth, give me?
  18. #18
    May 2004
    Netherlands
    Hi OPB,
    i tried your settings and got to DDR600, but this was with ODC on i later verified. With ODC off and multi 9x, the mem runs REAL DDR600 and doesn't make it into windows. I would really like to know how you succeed in getting DDR600 on any bios without ODC option.
    thanks!
    Simon-Paul
  19. #19
    May 2004
    Netherlands
    * bump *
    OPB, could you please test again with newest CPU-Z? You'll see that your mem doesn't run CPU/11 = 300, but CPU/12 (~275).
    I think most of us would really appreciate if you show us REAL DDR600!
    go go!
  20. #20
    "I eat motherboards"
    Dec 2004
    Topeka, KS
    OPB is in Florida until tommorow or the next day..
    杰森
    I can picture in my mind a world without hate, a world without violence.
    And I can picture us attacking that world, because they'd never expect it.
  21. #21
    Love and Peace!
    Dec 2004
    hiding somewhere!
    and i am *certain* he knows that the ODC option changed the speed and didn't show in programs
  22. #22
    May 2004
    Netherlands
    then what's the point of this whole thread?
  23. #23
    Dec 2005
    Brooklyn, New York
    Quote Originally Posted by SPivX
    Hehe, I don't know if he was sarcastic or what, but either way, it isn't good.
    Heatware: 50-0-0
  24. #24
    Oct 2005
    Milton Keynes, UK
    So ODC was indeed enabled.
    Guys start posting A64Info shots instead of A64Tweaker.
    OPB....
  25. #25
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by kidoman
    OPB....
    the new cpu-z, 1.33.1, correctly reports speed with ODC on now.. in part due to OPB's testings. also, if the thread is read:...
    Quote Originally Posted by OPB
    SPivX, we didn't realize at first the implications of ODC, and posted the results (which happened to be wrong), with excitement. honest mistake, nothing more.
